  3. Scrolling Text sensor node with new V_TEXT
51 Posts 17 Posters 35.5k Views 13 Watching
  • HoffanH Hoffan
    What am i missing, Because i get this when i try to compile it
    Arduino:1.6.5 (Mac OS X), Kort:"Arduino Nano, ATmega328"
    ScrollingText:55: error: 'V_TEXT' was not declared in this scope
    ScrollingText.ino: In function 'void setup()':
    ScrollingText:166: error: 'S_INFO' was not declared in this scope
    ScrollingText:170: error: 'V_TEXT' was not declared in this scope
    ScrollingText.ino: In function 'void loop()':
    ScrollingText:191: error: 'V_TEXT' was not declared in this scope
    ScrollingText.ino: In function 'void incomingMessage(const MyMessage&)':
    ScrollingText:210: error: 'V_TEXT' was not declared in this scope
    AWIA
    AWIA
    AWI
    @Hoffan V_TEXT is still in the development branch...
    • HoffanH
      HoffanH
      Hoffan
      Okey, That can explain, Byt when i use the Dev Branch
      I get this Errors
      ScrollingText:52: error: 'MyTransportNRF24' does not name a type
      ScrollingText:53: error: 'MySensor' does not name a type
      ScrollingText:163: error: 'gw' was not declared in this scope
      ScrollingText:177: error: 'gw' was not declared in this scope
      AWIA 1 Reply Last reply
      • HoffanH Hoffan
        I get this Errors
        AWIA
        AWIA
        AWI
        @Hoffan you best read the instructions for the development branch. The syntax changed a little. I'm typing on a phone right now. Best to search yourself
          wrote on last edited by hek
          #24
          How to convert a sketch to 1.6 is described here (until it has been posted somewhere more sticky..) :
          https://docs.google.com/document/d/1NKq5uuNdnxF5jWnum7VT32mbKLjuvqlx2A5D1qQ-H3Q/edit#heading=h.t5sdmpn6jz2i
          Basically a few search/replace... The above sketch would look something like this (untested)
           PROJECT: MySensors / Scrolling Text display
           PROGRAMMER: AWI
           DATE: september 12, 2015/ last update: september 12, 2015
           FILE: AWI_scroll_MAX.ino
           LICENSE: Public domain
           Hardware: tbd ..Ceech - ATmega328p board w/ NRF24l01
              and MySensors 1.5 ()
          Special:
              Need to use MySensors development edition
          SUMMARY:
              3 S_xx devices for scrolling text
              - Displays a scrolling text from a "V_TEXT" variable
              - additional dimmer sensor for controlling display brightness
              - 'Alarm' switch. If "On", overrides the text display to display ALARM message
              - You can also input messages from the Serial monitor (testing)
              Uses excellent MD_MAX72XX library
           Remarks:
              Fixed node-id
          // Use the MD_MAX72XX library to scroll text on the display with the use of the callback function
          // to control what is scrolled on the display text.
          // You need to set the used display in the library MD_MAX72XX.h
          // User can enter text on the serial monitor and this will display as a
          // Speed for the display is controlled by a pot on SPEED_IN analog in.
          #include <MD_MAX72xx.h>                     // multipurpose library for MAX72xx diaplay driver  https://parola.codeplex.com/
          #include <MySensor.h>                       // Mysensor network
          #include <Time.h>                           //http://playground.arduino.cc/Code/Time
          #define USE_POT_CONTROL 0                   // enable Scroll speed  potentiometer
          #define PRINT_CALLBACK  0
          // Macro to simplify serial print
          #define PRINT(s, v) { Serial.print(F(s)); Serial.print(v); }
          // Define the number of devices we have in the chain and the hardware interface
          // need to be adapted to your setup
          const int MAX_DEVICES = 8 ;                 // number of 8x8 displays
          const int CLK_PIN = 7 ;                     // SPI like clock
          const int DATA_PIN = 8 ;                    // SPI like data
          const int CS_PIN = 6 ;                      // SPI like select
          // Parola is able to use SPI hardware interface, not testted in combination with MySensors
          // MD_MAX72XX mx = MD_MAX72XX(CS_PIN, MAX_DEVICES);
          // now use Arbitrary pins
          MD_MAX72XX mx = MD_MAX72XX(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES); // instantiate one display chain
          // Scrolling parameters, you can attach normal potentiometer to A5, Vcc, Gnd
          #if USE_POT_CONTROL
          const int SPEED_IN = A5 ;
          #else
          const int SCROLL_DELAY = 20 ;               // in milliseconds
          #endif // USE_POT_CONTROL
          const int CHAR_SPACING = 1 ;                // pixels between characters
          // MySensors constants & variables
          const byte nodeId = 51 ;                    // MySensors fixed node id
          const byte messageCHILD = 8 ;               // Text from ControllerLCD
          const byte brightnessChild = 9 ;            // Brightness of display
          const byte alarmChild = 10 ;                // Display Alarm text (overrides normal text)
          boolean timeReceived = false ;              // Flag to indicate time received
          // Display constants & variables
          byte textBrightness = 1 ;                   // brightness of display (between 0 - MAX_INTENSITY (0xF)
          byte textOnOff = true ;                     // textOnOff = ! shutdown
          boolean textAlarm = false ;                 // Alarm (switch S_BINARY)
          // Global message buffers shared by MySensors and Scrolling functions
          const int BUF_SIZE = 25 ;                   // max payload for MySensors(NRF24l01)
          char curMessage[BUF_SIZE];                  // current displayed message
          char newMessage[BUF_SIZE];                  // next message to be displayed if available
          bool newMessageAvailable = false ;          // new message available flag
          uint16_t    scrollDelay;                    // in milliseconds
          // *** Definition and initialisation
          // define the MySensor network (1.5)
          // Initialize messages for sensor network
          MyMessage textMsg(messageCHILD, V_TEXT);    // message for Sending Text to Controller
          /* MD_MAX72XX functions: can be found in the documentation for the library,
           * no need to customtize callback & scroll routines (unless you want to...)
          uint8_t scrollDataSource(uint8_t dev, MD_MAX72XX::transformType_t t)
          // Callback function for data that is required for scrolling into the display
            static char       *p = curMessage;
            static uint8_t    state = 0;
            static uint8_t    curLen, showLen;
            static uint8_t    cBuf[8];
            uint8_t colData;
            // finite state machine to control what we do on the callback
            switch(state)
              case 0: // Load the next character from the font table
                showLen = mx.getChar(*p++, sizeof(cBuf)/sizeof(cBuf[0]), cBuf);
                curLen = 0;
                state++;
                // if we reached end of message, reset the message pointer
                if (*p == '\0')
                  p = curMessage;         // reset the pointer to start of message
                  if (newMessageAvailable)    // there is a new message waiting
                    strcpy(curMessage, newMessage);   // copy it in
                    newMessageAvailable = false;
                // !! deliberately fall through to next state to start displaying
              case 1: // display the next part of the character
                colData = cBuf[curLen++];
                if (curLen == showLen)                // end of character insert interchar space
                  showLen = CHAR_SPACING;
                  curLen = 0;
                  state = 2;
                break;
              case 2: // display inter-character spacing (blank column)
                colData = 0;
                curLen++;
                  state = 0;
                break;
              default:
                state = 0;
            return(colData);
          // Callback (not used here)
          void scrollDataSink(uint8_t dev, MD_MAX72XX::transformType_t t, uint8_t col){
          // Callback function for data that is being scrolled off the display
          #if PRINT_CALLBACK
              Serial.print("\n cb ");
              Serial.print(dev);
              Serial.print(' ');
              Serial.print(t);
              Serial.print(' ');
              Serial.println(col);
          // non-blocking text display to be used in loop (call frequently)
          void scrollText(void){
              static uint32_t prevTime = 0;
              if (millis()-prevTime >= scrollDelay){                  // Is it time to scroll the text?
                  mx.transform(MD_MAX72XX::TSL);                      // scroll along - the callback will load all the data
                  prevTime = millis();                                // starting point for next time
          // sets the scroll delay (read from potentiometer if enabled)
          uint16_t getScrollDelay(void){
          #if USE_POT_CONTROL
              uint16_t t = analogRead(SPEED_IN);
              t = map(t, 0, 1023, 25, 250);
              return(t);
          #else
              return(SCROLL_DELAY);
          void setup(){
              // set up the display first
              mx.begin();                                             // initialize display chain
              mx.setShiftDataInCallback(scrollDataSource);            // define function to get the scrolldata (returned as int8)
              //mx.setShiftDataOutCallback(scrollDataSink);           // not used
              mx.control(MD_MAX72XX::INTENSITY, 0x01);
          #if USE_POT_CONTROL                                         // initialize speed potentiometer if enabled
              pinMode(SPEED_IN, INPUT);
          #else
              scrollDelay = SCROLL_DELAY;
              strcpy(curMessage, "I \x03 MySensors ");                // first message on display
              newMessage[0] = '\0';                                   // new message initialized to empty
              // Setup MySensors
             //Serial in Sensor network = 115200
              //Send the sensor node sketch version information to the gateway
          void presentation() {
              sendSketchInfo("AWI Scroll MAX 51", "1.1");
              present(messageCHILD, S_INFO, "Text line Scroll");   // new S_type 20150905 (not know by domoticz)
              present(alarmChild, S_BINARY, "Alarm display");      // to display alarm text
              present(brightnessChild, S_DIMMER, "Text brightness"); // new S_type 20150905 (not know by domoticz)
              //send(textMsg.set("-"));                            // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
              request(messageCHILD, V_TEXT, 0);                    // request value from controller
              // Initializations
              requestTime();                            // get the time from controller (handled by receiveTime)
          // loop only uses non-blocking functions
              static unsigned long lastUpdate ;                       // Static hold the last update time
              unsigned long now = millis();
              scrollDelay = getScrollDelay();                         // update scroll delay from potentiometer
              readSerial();
              // Check for new conditions & ask for new information from controller every 10 seconds
              if (now-lastUpdate > 10000){
                  if (textAlarm){                                     // if alarmstatus: override all text and set max intensity
                      strcpy(curMessage, "   ALARM   ");
                      mx.control(MD_MAX72XX::INTENSITY, MAX_INTENSITY);   // set current brightness
                      mx.control(MD_MAX72XX::SHUTDOWN, false) ;
                  } else {                                            // standard (non Alarm actions)
                      mx.control(MD_MAX72XX::INTENSITY, textBrightness);  // set current brightness
                      mx.control(MD_MAX72XX::SHUTDOWN, textOnOff) ;
                      request(messageCHILD, V_TEXT, 0);                // request new value from controller
                  lastUpdate = now;
              scrollText();
          // This is called when a new time value was received
          void receiveTime(unsigned long controllerTime) {
              Serial.print("Time value received: ");
              Serial.println(controllerTime);
              setTime(controllerTime);                                // time from controller
              timeReceived = true;
          // This is called when a message is received
              Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
              if (message.sensor == messageCHILD){
                  if (message.type==V_TEXT) {                     // Text content
                  strcpy(newMessage, message.getString());        // copy it in
                      newMessageAvailable = true ;
              } else if (message.sensor == alarmChild) {
                  if (message.type==V_STATUS) {                   // True/ false content
                      textAlarm = message.getBool()?true:false ;  // set alarmflag
                      Serial.print("TextAlarm: ");
                      Serial.println(textAlarm);
              } else if (message.sensor == brightnessChild){
                  if (message.type==V_PERCENTAGE) {               // Level 0..100  content
                      textBrightness = map(message.getInt(),0, 100, 0, MAX_INTENSITY ) ;  // map to brightnesslevel
                      Serial.print("TextBrightness: ");
                      Serial.println(textBrightness);
                  } else if (message.type==V_STATUS) {            // Display on/off
                      textOnOff = message.getBool()?false:true ;      // set shutdown/ !on/off
                      Serial.print("Text on/off: ");
                      Serial.println(textOnOff);
          // Testing purposes: input routine character buffer. Reads serial characters in buffer newMessage.
          // sets flag newMessageAvailable to true if completed
          void readSerial(void)
            static uint8_t    putIndex = 0;
            while (Serial.available())
              newMessage[putIndex] = (char)Serial.read();
              if ((newMessage[putIndex] == '\n') || (putIndex >= BUF_SIZE-3)) // end of message character or full buffer
                // put in a message separator and end the string
                newMessage[putIndex++] = ' ';
                newMessage[putIndex] = '\0';
                // restart the index for next filling spree and flag we have a message waiting
                putIndex = 0;
                newMessageAvailable = true;
              else
                // Just save the next char in next location
                newMessage[putIndex++];
          • D
            D
            dayve218
            ive spent a couple of hours on this, and i cant get it to work. any help?
            • D
              D
              dayve218
              @AWI are you able to help me convrt this to1.6? i cant get it
                Fixed a couple of thing in the sketch. Now it compiles on 1.6 but you have to install the MD_MAX72xx library which it uses.
                • HoffanH
                  HoffanH
                  Hoffan
                  Where did you put the new sketch??
                  hekH 1 Reply Last reply
                  • HoffanH Hoffan
                    @Hoffan
                    I updated my post above.
                    • HoffanH
                      HoffanH
                      Hoffan
                      Okey... Strange because i test to compile that i Dev Branch and i get this error
                      Build options changed, rebuilding all
                      Scrolltext.ino: In function 'void presentation()':
                      Scrolltext:205: error: too many arguments to function 'void requestTime()'
                      In file included from /Users/Hoffan/Documents/Arduino-development/libraries/MySensors/MySensor.h:205:0,
                      from Scrolltext.ino:34:
                      /Users/Hoffan/Documents/Arduino-development/libraries/MySensors/core/MySensorCore.cpp:234:6: note: declared here
                      void requestTime() {
                        Ok, how about now then..
                        • HoffanH
                          HoffanH
                          Hoffan
                          Now the compile is working...
                          Now i will test it in real :)
                          • Lawrence HelmL
                            Lawrence HelmL
                            Lawrence Helm
                            @Hoffan - how did you get on? Interested to know before I order some components :)
                            • HoffanH
                              HoffanH
                              Hoffan
                              @Lawrence-Helm
                              It didn't work all the way for me... And i didn't have the time to check whats wrong
                              It thing its some thing withe the display settings
                              • AWIA AWI
                                Another experiment for the V_TEXT variable/ sensor. Including brightness & speed setting and special Alarm function.
                                upload-3aa973f9-d6cf-41a5-8b59-2241311896b0
                                A scrolling display to let the family now that the dog needs walking... nothing more than 1 nano, 8 (or whatever number) of displays with max7219 controller upload-f2290f64-a15d-48c9-8420-ab65e481a492 a radio and a few cables
                                upload-4c163020-edac-4bc5-b3bf-50f1f3cccd24
                                Total cost: €18 (with 8 displays)
                                in Domoticz:
                                upload-868a0c0c-a44d-480f-940c-e0378716ebd3
                                Built around the very versatile "Parola" driver library
                                (I will upload a video when I know how to .. ;-))
                                https://www.youtube.com/watch?v=gCKTm427_Zc
                                 PROGRAMMER: AWI
                                Special:
                                SUMMARY:
                                 Remarks:
                                	Fixed node-id
                                #if USE_POT_CONTROL
                                #else
                                MyTransportNRF24 transport(9,10); 			// Sensoduino (8,7) Ceech board, 3.3v (7,8)  (pin default 9,10)
                                MySensor gw(transport);
                                  uint8_t colData;
                                  switch(state)
                                      curLen = 0;
                                      state++;
                                      if (*p == '\0')
                                        curLen = 0;
                                        state = 2;
                                      break;
                                      colData = 0;
                                      curLen++;
                                        state = 0;
                                      break;
                                    default:
                                      state = 0;
                                  return(colData);
                                #if PRINT_CALLBACK
                                	Serial.print(dev);
                                	Serial.print(' ');
                                	Serial.print(t);
                                	Serial.print(' ');
                                #if USE_POT_CONTROL
                                	return(t);
                                #else
                                void setup(){
                                #else
                                	// Setup MySensors
                                    gw.begin(incomingMessage, nodeId); 						// this node is 51 fixed
                                    gw.sendSketchInfo("AWI Scroll MAX 51", "1.1");
                                 	gw.present(messageCHILD, S_INFO, "Text line Scroll");	// new S_type 20150905 (not know by domoticz)
                                 	gw.present(alarmChild, S_BINARY, "Alarm display");		// to display alarm text
                                	gw.present(brightnessChild, S_DIMMER, "Text brightness"); // new S_type 20150905 (not know by domoticz)
                                    //gw.send(textMsg.set("-"));							// initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
                                	gw.request(messageCHILD, V_TEXT, 0); 					// request value from controller
                                	// Initializations
                                    gw.requestTime(receiveTime);							// get the time from controller (handled by receiveTime)
                                	gw.process();
                                	readSerial();
                                			gw.request(messageCHILD, V_TEXT, 0); 				// request new value from controller
                                		lastUpdate = now;
                                	scrollText();
                                      putIndex = 0;
                                    else
                                korttomaK
                                korttomaK
                                korttoma
                                Hi @AWI do you stil have this setup in use? I tried to convert this to 2.0 and hock it up but there is something wrong with the order of the LED elements. They are somehow scrolling in the wrong direction. With part of the code handles this? Might be that I have the wrong library for the MD_MAX72XX where did you get the lib?
                                • Tomas
                                • korttomaK korttoma
                                  AWIA
                                  AWIA
                                  AWI
                                  Hi @korttoma I have it somewhere in the (large) pile of 'old and/or unfinished' projects :blush:
                                  What I remember is that there are difference between the MAX displays in orientation. Below a picture off mine..
                                  0_1480017878576_upload-bc9926a9-cff8-4d9d-b745-1e44384856c8
                                  You can change the display type in the MD_MAX72xx.h file of the library.
                                  From line #212 you can choose various display types (only select one). Have fun and let us know your progress..
                                  korttomaK 1 Reply Last reply
                                  • AWIA AWI
                                    korttomaK
                                    korttomaK
                                    korttoma
                                    #37
                                    Thanks @AWI , the back of my displays are identical to yours and removing the LED element reviles the MAX7219EWG driver underneath.
                                    I will look in to the file you mentioned, maybe I can work something out.
                                    • Tomas
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      Chose the FC-16 from the .h file and now it is working! Thanks again @AWI
                                      • Tomas
                                      ? 1 Reply Last reply
                                        A Former User
                                        Thomas, could/would you please share the 2.0 version of the sketch as i also want to use the max7219 modules with mysensors. I already tried them with the md_parola library examples and there are pretty nice animations and effects in there.
                                        Any chances to use those effects other than the scrolling examples with a node red/mqtt gateway combination?
                                        • ? A Former User
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          Sure I can do that, I will share it when I get home to the computer where it is located.
                                          • Tomas
