  3. How To - Doorbell Automation Hack
106 Posts 29 Posters 125.9k Views 26 Watching
  • A
    A
    arjen
    Hello all,
    I'm trying to hook this doorbell sensor up, what I've found is that when I connect it, I must connect it to NC. The downside is that when I reset the Arduino, the doorbell keeps ringing until pin4 is pulled up. How can I change that in the sketch?
    Also I can ring it once, it rings and then it stops working. Connection to the gateway is lost and it won't ring either.
    been trying to fix it for 3 days now, but I can't seem to figure out what I've done wrong.
    Hooked up pin 4 to the input pin of the relay. The relay is directly powered by 5v coming from a usb hub with 2A.
    The Arduino is powered using the same 5V, with a regulator to the radio to give it 3.3V. Connected a 4.7uF cap directly on the radio.
    When I reset the arduino this comes to the gateway:
    0;0;3;0;9;read: 16-16-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
    0;0;3;0;9;read: 16-16-0 s=255,c=3,t=11,pt=0,l=16,sg=0:Doorbell Monito
    0;0;3;0;9;read: 16-16-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
    0;0;3;0;9;read: 16-16-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
    0;0;3;0;9;read: 16-16-0 s=0,c=0,t=1,pt=0,l=0,sg=0:
    0;0;3;0;9;read: 16-16-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;0;3;0;9;send: 0-0-16-16 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
    I can connect perfectly to the gateway using MyMQTT on Android so I think it is failing on the side of the doorbell any help would be greatly appreciated!
    petewillP 1 Reply Last reply
    • korttomaK
      korttomaK
      korttoma
      For the NC problem change:
      #define RELAY_ON 1
      #define RELAY_OFF 0
      to:
      #define RELAY_ON 0
      #define RELAY_OFF 1
      • Tomas
      korttomaK 1 Reply Last reply
      • A arjen
        Hello all,
        petewillP
        petewillP
        petewill
        @arjen That's strange. You shouldn't need to connect it to NC. That means you are normally sending power to your doorbell unless it is rung. Are you sure you have the wires from your doorbell correct? You may want to double check them with a multimeter.
        • A
          A
          arjen
          Just to make sure I've took some photo's.
          When I take a multimeter and place it on the bottom two wires of the trafo I get zero rating. doorbel.jpg
          There is no difference between blue and red, neither does it make a difference if I change the wires in what ever way. Tried all possibilities I can think of.
            You know that it is AC current coming out of that power supply right?
            • A
              A
              arjen
              Yeah i know. Does it matter? It's seperated by the relay from the rest right?
              Or am I saying something stupid here.... :confused:
              • A arjen
                petewillP
                petewillP
                petewill
                @arjen Can you post pictures of the rest of the wiring? It's still strange that you have to have it connected to normally closed. That is most likely why your doorbell is ringing when it's first powered on.
                • A
                  A
                  arjen
                  Sure, no prob.
                  This is the relay, at the moment a 6 port, didn't had a one port available.
                  The green wire is connected to IN1 on the relay and pin4 on the arduino.
                  the backside of the print. The bottom row 'S' is pin 9 on the arduino, 'M' and 'K' is pin3 and Ground to doorbellbutton.
                  front side. The brown and blue on the left are 5V to the relay, on the right red and blue are input doorbellbutton.
                  • korttomaK korttoma
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    to:
                    #define RELAY_ON 0
                    #define RELAY_OFF 1
                    korttomaK
                    korttomaK
                    korttoma
                    Did you try my suggestion?
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    to:
                    #define RELAY_ON 0
                    #define RELAY_OFF 1
                    • Tomas
                    • petewillP
                      petewillP
                      petewill
                      Yeah, try @korttoma's suggestion. If that doesn't work, can you post a pic of the relay connections (all)?
                      • D
                        D
                        drock1985
                        Huh, I have the same problem as @arjen is describing too, the only difference is i'm using a 2x raly vs. his 4. I don't have an issue with the relay being on, since my node is always powered on, the pull always goes high. Might just change it in the code/wiring though when I get the Arduino IDE working again.
                        Quick question: do you have the relay board powered by the Arduino, or another 5V source?
                        My Projects
                        2 Door Chime Sensor
                        Washing Machine Monitor
                        • A
                          A
                          arjen
                          Made the changes to the sketch as suggested, and now I can connect it to NO.
                          Just to make sure I didn't made a mistake while soldering, used a fresh nano and made all connections again. In the sketch the changes still need to be made, however as far as i could test this morning all is working fine now!
                          Thanks for all the tips!
                          The relay is powered by the same powersource as the arduino (6 port powered usb hub 2A).
                          • D drock1985
                            petewillP
                            petewillP
                            petewill
                            @drock1985 the relay should be powered by the same 5v power source as the Arduino but not from the arduino. It can draw too much power and cause issues when connected to the arduino.
                            @arjen Great! I just noticed the selection pin (can't think of the correct name right now) on your relay. I wonder if switching that would allow you to use the original code as well as the NO connections?
                            • N
                              N
                              Newzwaver
                              Excellent project, great work.. So I need to pick your mind.... I have a doorbell that can change music and volume. I hope to be able to fully control it by zwave using this app with Vera...Any ideas.....
                              • N Newzwaver
                                petewillP
                                petewillP
                                petewill
                                @Newzwaver Hmm. I doubt this would work for you to fully control it but you may still be able to trigger it. How do you control it now? Through an app or something?
                                • Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  Hello all - sorry I have been away for so long...
                                  This bring back memories http://forum.mysensors.org/topic/1620/mysensored-doorbell
                                  I wish I found a way of triggering the notification from the ring and not the other way around, as this way when something happen to your arduino the doorbell will not ring. Didn't happen yet - it works perfectly for 6 months but I would feel more relaxed if it was the other way around. Oh well...
                                  • Moshe LivneM Moshe Livne
                                    petewillP
                                    petewillP
                                    petewill
                                    @Moshe-Livne Cool! You can look at it the other way around on the Arduino processing the ring issue you raised. I now have the ability to turn off the ring if I want to. So I guess there is some give and take :)
                                    • petewillP petewill
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @petewill ummmm you could still cut the ring even if it was the other way around with a relay. Sorry to be a pain :-) can't fight my mold hehehe. generally I find the reliability of dorrbells (especially the old wired kind) to be excellent. mine has been working flawlessly for at least 35 years.
                                        petewillP
                                        petewillP
                                        petewill
                                        @Moshe-Livne Ok, I must have misunderstood. I thought you wanted the bell to ring no matter what then just detect the signal so you could send it to your gateway. Either way, that's why MySensors is so great, you can do pretty much what ever YOU want, not what someone else wants :)
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @petewill My original plan was to unintrusively detect the ring and trigger the arduino without effecting the bell circuit. However, it proved to be a bit more complicated and 2 dead arduinos and several other fried components later I gave up.
