  3. My Slim 2AA Battery Node
498 Posts 71 Posters 584.6k Views 69 Watching
    A couple of more questions. In one of the pictures at the top the electrulyte 4,.7 uf capacitator is placed closer to the atmel chip and the 0.1 uf (c5) is placed closest to the edge does it matter witch capacitator goes where?
    The 10k resistor should be 1/4 or 1/8 W according to the bom. I had some small 1/6 W 10k resistors can I use them? I also have some bigger blue 10k resistor that I do not know the W rating on.
    Where did you purchase the female pin-header that are used for the chips? I have some atmega chip-sockets that are quite narrow and it is hard to fit the components underneath. I also have some other female pin-headers but they are atleast twice as high than the ones in the pictures.
    AWIA
    AWIA
    AWI
    @Cliff-Karlsson You can swap the capacitors and use all resistor dissipation values. The pin headers you can find here for example
    • GertSandersG GertSanders
      @Yveaux I tried to find an email address on the website, but apart from a LinkIn link I could not find anything. Also, in LinkedIn you need a paying version to be able to send InMail, and I do not have a paid account. Would you care to tell me how you were able to send Stijn a message ?
      YveauxY
      YveauxY
      @GertSanders It's been a while, but my first contact was through his Twitter account. Try that first, otherwise ping me.
      • YveauxY Yveaux
        GertSandersG
        GertSandersG
        GertSanders
        @Yveaux I do not have a twitter account, so no joy. And I feel stupid to say so, but how do you ping someone on this forum ?
        • YveauxY Yveaux
          @AWI said:
          panelized design
          If you're struggling with panelizing boards I can recommend the excellent gerber tools from Stijn Kuipers.
          It allows you to create designs like this (10x10cm, DirtyPCBs):
          Drop him a message and he'll send you a download link.
          ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          @Yveaux i remember once that i read that dirtypcbs does not allow for different designs in their panelized boards. Am i correct ?
          YveauxY 1 Reply Last reply
          • ahmedadelhosniA ahmedadelhosni
            YveauxY
            YveauxY
            @ahmedadelhosni apparently not :blush:
            The board above was produced by ditypcb's. In fact they're one of the few (only?) cheap PCB manufacturers that allow panelization.
            ahmedadelhosniA 1 Reply Last reply
            • YveauxY Yveaux
              ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              @Yveaux aha. I thought that this means multiple (same) design not different. Thanks :)
              • m26872M
                m26872M
                m26872
                Updated first post with share stats and info.
                Feature requests and example links will come asap.
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  This post is deleted!
                  • D
                    D
                    drock1985
                    Just ordered my first set of boards; v2.0 in Red; can't wait to try these out!
                    Thanks @m26872
                    My Projects
                    2 Door Chime Sensor
                    Washing Machine Monitor
                    • Matt PittsM
                      Matt PittsM
                      Matt Pitts
                      Hi
                      I've just ordered a set of the PCB boards and looking forward to putting these together mainly into reed switches and motion sensors
                      I have scanned the whole thread and there doesn't seem to be a comprehensive list of exactly which components are required anywhere here, well not all in one place at least.
                      Can I just confirm exactly what is required to build a senor node.
                      1 x PDB board
                      1 x ATMega328p 28pin PDIP
                      1 x NRF24L01+ radio module
                      1 x 4.7uF Decoupling-Capacitor for radio (I assume these are still required??)
                      1 x right angle pin header for connecting to program and connect batteries
                      1 x Length of cable ducting for housing
                      2 x AA batteries
                      Cables for connecting batteries
                      Battery connector
                      1 x senor of choice
                      I notice there seem to be an assortment of capacitors/regulators in most of the photos on this thread, but no definitive list of which are needed. (I am very new to all this so please excuse my ignorance)
                      Extras needed
                      1 x FTDI USB to TTL Serial Adapter
                      Have I missed anything of my list? Also I would be really grateful for links to some of the above components.
                      Sorry these are very basic noob questions, but I feel it would really helpful for people such as myself to have everything clearly listed in one place, as the main mysensors build pages do. So people know exactly what is needed.
                      • GertSandersG
                        GertSandersG
                        GertSanders
                        @Matt-Pitts You can find a BOM for the board here:
                        https://www.openhardware.io/view/10/My-Slim-2AA-Battery-Node
                        • SoloamS
                          SoloamS
                          Soloam
                          A nice additions would be a place to solder a ATSHA204A on board like the Sensebender! I'll try to make the change in KiCad!
                          M 1 Reply Last reply
                          • SoloamS Soloam
                            meddie
                            @Soloam
                            and a flash module for OTA Sketch Uploads :-)
                            • Matt PittsM
                              Matt PittsM
                              Matt Pitts
                              Thanks @GertSanders for showing me the BOM I hadn't realised it was there, but do I need everything listed there to get it working properly?
                              • Matt PittsM Matt Pitts
                                GertSandersG
                                GertSandersG
                                GertSanders
                                wrote on last edited by GertSanders
                                #255
                                @Matt-Pitts
                                I'm assuming that if a designer goes through the trouble of listing items on a bom, they are needed.
                                But you are right, that is not always the case. I'm not at my Mac (using a miniscreen now), so i can not multitask.
                                • Tom71T
                                  Tom71T
                                  Tom71
                                  I have problems to upload the scatch to the bare Amtel. I use an USB-TTL FTL Adaper and connect, RX/TX and Reset Pin with 100n->DTR. But I got always errors on uploading.
                                  The bootloader I have successfull burned with an raspberry pi and gpio (http://www.lxccu.com/hb-raspberry-bootloader-update):
                                  sudo bin/avrdude -Cbin/avrdude.conf -p m328p -P gpio -c gpio -U lfuse:w:0x62:m -U hfuse:w:0xde:m -U efuse:w:0x07:m -U lock:w:0x2F:m -e -Uflash:w:1443392692398-atmega328_1a.hex:i
                                  avrdude: safemode: Fuses OK
                                  How can I got it working?
                                  Thank you
                                  Thomas
                                  • bjacobseB
                                    bjacobseB
                                    bjacobse
                                    Have you tried to upload a standard arduino bootloader?, are you using correct baud settings for uploading?
                                    • Tom71T
                                      Tom71T
                                      Tom71
                                      @bjacobse No, used the bootloader from here (http://forum.mysensors.org/uploads/files/1443392692398-atmega328_1a.hex). This is an bootloader for the internal clock.
                                      Baud settings to upload the sketch or the bootloader?
                                      m26872M 1 Reply Last reply
                                      • Tom71T Tom71
                                        m26872M
                                        m26872M
                                        m26872
                                        @Tom71 I think the question was if you have been successful with programming a standard bootloader to a standard Arduino board and then uploading and running a sketch?
                                        • Tom71T
                                          Tom71T
                                          Tom71
                                          wrote on last edited by Tom71
                                          #260
                                          @m26872 Sure, but not with an bootloader (optiboot with intenal clock) on an bare Atmega. Later I will try this: http://forum.mysensors.org/uploads/files/1454449901412-7.png
                                          I build some MySensors with an Arduino Micro, but not with only an Atmega.
                                          Update: I don't know what's different, but this works. Perhaps I forget to connect Reset from FDL -> Pin 1.
                                          Now I can upload simple sketches.
