  3. How to read a seven segment display?
6 Posts 4 Posters 2.7k Views 3 Watching
  • karl261K
    karl261K
    karl261
    Hi there,
    I hope this is the right place to ask. I have this wireless remote control for my heating system and I would like to control it even more remotely (over the internet). :-) Hence I am planning a project on this.
    What I would like to do is to simulate the buttons being pressed on the remote for in-/decreasing the temperature and hence change the temperature via the internet. I suppose that can be done using optocouplers or relays or similar.
    Now, the real question: The set temperature is displayed using this 3-digit 7-segment display. As far as I understand these 7-segment displays are driven by a 4 Bit digital code that is converted by a display driver IC to the abcdefg code of 0s and 1s.
    I would like to read the temperature and display it on the pimatic software. How would I read this temperature? It cannot be too difficult I imagine, because it is already a digital binary code of 0000 for 0 and 0010 for 2 etc.
    Could anyone point me in the right direction on how to tackle this project?
    Thanks for any advice!
    Karl
    • snowS
      snowS
      snow
      I think it would be easier to make and use an additional temperature sensor.
      • T
        TimO
        Did you search for something like "your heating system + arduino"? Maybe someone already did the trick! :)
        • karl261K
          karl261K
          karl261
          Hi, thanks for your replies. I checked a little bit around on the web, but could not find anything specific to my heating system. I just found out that if the 7-segment display is somehow multiplexed, it might be indeed very difficult to read these things, because it seems that the segments are only powered on for some microseconds and there is some fast switching between them, so if the temperature is 22, it is not permanently on, but switching through various states very quickly.
          I guess I will have to open the thing and look what's really inside.
          My original idea, to read the T via a small camera might be the easiest solution...
          DwaltD 1 Reply Last reply
          • karl261K karl261
            DwaltD
            DwaltD
            Dwalt
            @karl261 Have you checked this post?
            • karl261K
              karl261K
              karl261
              wrote on last edited by karl261
              I think it does not look too complicated. Finally got around to open the thing. I am surprised by its simplicity, at least it looks like. Plenty of space. But I am scared that the display is just pressed into the board. I hope I won't kill it. So know I have to find out how it works...
              It should be also super easy to control the four buttons (only two are actually needed) with optocouplers...
              I wonder if it is possible to hack the radio transmission...
              Comments?
