  3. Ethernet Gateway and Window Sensor dont communicate.
6 Posts 3 Posters 2.0k Views 1 Watching
    meddie
    Hi together,
    yesterday i soldered an ethernet controller and a window sensor. But it seems not to work, and i ask me how to check. It looks like the modules dont send. But i dont know how to check this.
    When i connect the Controller and the Sensor to my computer on serial console i see only this output:
    Controller:
    Window Sensor:
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bd, id=255, parent=255, distance=255
    find parent
    send: 255-255-255-27,pt=0,l=0,sg=0,st=bc:
    find parent
    send: 255-255-255-255 s=255,c=3,=0,st=bc:
    I used on them the API 1.5. On both i used the sample Sketches.
    Can you help me please, how can i check the radio is working.
    I have on both modules an arduine nano. And on the controller i have a NRF24l01p with PA and sma Connector. On the Window Sensor i have a small nrf24l01 (modell 3629)
    Thank you in Advance
    Greets Eddie
    • E
      E
      ericvdb
      Your sensor is requesting an ID. What controller are you using?
        meddie
        sorry i mean the ethernet gateway.
        this one: http://www.mysensors.org/build/ethernet_gateway
        OK, but i have read at the api that the sensor get automaticaly an id from gateway.
        If not where i can configure the id?
        thank you
        • E
          E
          ericvdb
          wrote on last edited by ericvdb
          No, you are getting it wrong.
          The gateway never assigns ID to sensors, thats the task of a controller:
          sensor ---> gateway ---> controller (where controller is one of the controllers listed here
          Alternatively, you can set a static ID on your sensornode by doing
          // Assign ID 6 to sensor node
          gw.begin(NULL,6,false);
          instead of
          gw.begin(NULL,AUTO,false);
            meddie
            Ah, ok. I use FHEM. In FHEM i have defined the gateway. In FHEM i see this:
            DEF	 10.0.0.253:5003
            DeviceName  10.0.0.253:5003
            FD 5
            NAME CUL_MySensors
            NOTIFYDEV global
            NR 41
            NTFY_ORDER 50-CUL_MySensors
            PARTIAL
            STATE startup complete
            TYPE MYSENSORS
            ack 0
            inclusion-mode 1
            outstandingAck 0
            version 1.5.1
            Readings:
            connection  startup complete  2015-12-18 16:43:30
            state  opened  2015-12-18 16:43:30
            Attributes
            autocreate 1
            stateFormat connection
            that is what i see on serial monitor of the sensor:
            find parent
            send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
            sensor started, id=255, parent=255, distance=255
            find parent
            find parent
            • alexsh1A
              alexsh1A
              alexsh1
              I am not familiar with FHEM, but I think you problem is in the FHEM settings - the controller is not assigning the ID to the sensor.
              Did you try to assign the node ID manually in gw.begin?
