  3. 433Mhz Garage opener projects
2 Posts 2 Posters 1.6k Views
  • R
    R
    ralf derope
    Hello
    This is my first post to the forum, I have been trying to find a way to controll my garage port using an arduino and a 433Mhz receiver and transistor. I have succesfully built a RF sniffer and I have got the code I need. It's a code that consists out of 52 bits (1 or 0) which is repeated as long as I press the button on my remote. I found out the code using this method.
    Now he says you should only get the first 24 bits of the code and you will be able to controll it. I can't however use his code because he uses VERA and I want to use it as a pure arduino program.
    My purpose is sending the code frome my arduino with a 433 Mhz transmitter when I press a button, what is the best way I could realize this? I tried some ways already but since I don't know how to progral that well and since I don't know how these radio's work it didn't work.
    Thanks in advance for your help!
    Greetings
    Reds Duty
    • HeinzH
      HeinzH
      Heinz
      Hi, as a start you could modify the following sketch: remove the flamingo.h include and all flamingo related stuff.
      https://github.com/windkh/flamingoswitch/blob/master/examples/mysensors/FlamingoSwitchSensor.ino
      Have a look at the function incommingMessage line 196. Here the message from the gateway is received. Replace 230 with your own code.
