  3. 💬 Easy/Newbie PCB for MySensors
mysensorsbatteryeasynewbiepcbmysx
716 Posts 111 Posters 700.4k Views 93 Watching
  • D
    D
    dakipro
    Ooops, my bad then :( I was pretty sure I checked readme.md file, but apparently I got confused.
    Thanks a million!
    • A
      A
      APL2017
      I am also looking for documentation for Rev. 9 that I purchased. The link with revisions that was provided: https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors#tabs-revisions
      lists revisions 1-7, but not 9. All I need is readable schematic and PCB layout in PDF. Thanks.
      • A APL2017
        @apl2017 I don't know where the revision numbering comes from, but I believe the rev9 you are talking about is called rev5 on the revisions tab.
        Rev 10 was created 2018-06-04. That date matches with rev6 on the revisions tab.
        Perhaps @sundberg84 knows why there are two sets of revision numbers?
        • A
          A
          APL2017
          What software was used to develop this board? My latest KiCad does not read schematic from Rev. 5 ZIP file. All I need is a simple PDF...
          • A APL2017
            #625
            @apl2017 - Rev 10 = Kicad, but all below is Eagles.
            This is Rev 9, Nrf24l01+
            @mfalkvidd - the rev tab in openhardware is the revision for the manufacturer. This doesnt match, because it starts at 0 and ticks up. If you have a board with rev 1 but make a small change without updating the revision number but still wants to upgrade it to the pcb manufacturer you need a new revision for them... so thats causes the confusion. But i think @hek named it M.Rev (Manufacturer revision) to try to keep them apart.
            • A
              A
              APL2017
              Sorry to bother you again (3rd time), still waiting for readable PDF of Rev. 9 schematic and board layout. Thank you
              • A APL2017
                #627
                @apl2017 - why pdf? The image above is just as good? It wont present any other info?
                The reason why I ask is that I dont have eagles installed anymore... so its a bit of hassle for me.
                • A
                  A
                  APL2017
                  sundberg84 Don't bother, I went through the hassle, downloaded Eagle and created readable PDF
                  D 1 Reply Last reply
                  • A APL2017
                    D
                    D
                    dakipro
                    @apl2017 care to share? :)
                    • E
                      E
                      ElCheekytico
                      Hey, @sundberg84 , I am trying to order the rfm69 version from ITEAD and their M.Rev1 file I downloaded looks to be your v9. Can you upload the v10 to them so I may place an order?
                      • P
                        P
                        Pierre1410
                        Hello, i have built my first sensor based on your PCB. I am of course in learning mode so it refuses to work so far. it is motion detector. I suspect a problem on the radio nrf24 but does not know how to monitor the node with Arduino IDE serial monitor. If i connect the board to the USB the radio is not powered (built the node on battery). and if i connect the battery i have no access to serial monitor. I am afraid to connect both the USB and the batteries and burn the all thing...
                        so far i know radio receives power/ PIR receives 3.3 Volts (have configured the PIR to 3.3)/ arduino mini pro led comes on with battery connected.
                        Any advice would be really welcome.
                        • S
                          Stephen205
                          wrote on last edited by Stephen205
                          #632
                          The radio is only powered by the battery, the battery must be connected to test. Connect both the usb (set to 3.3v) and the battery, no damage will be caused by this.
                          • P
                            P
                            Pierre1410
                            Thanks Stephen. connected both and i can now see what is going on :-)
                            • E ElCheekytico
                              @ElCheekytico - I dont know why they wont update to rev 10. I have uploaded the new revision to openhardware... nothing else I can do, sorry.
                              • P Pierre1410
                                @pierre1410 - I would suggest you connect the battery, and then the usb/ftdi cable, but only GND, TX and RX fro the usb connection. This will have the node running on the batteries VCC and get you closer to the real deal. Using VCC from the usb adapter might be higher VCC than the batteries, and in worst case scenario it works great with that connected but not when you deploy and only use battery power.
                                P 1 Reply Last reply
                                • sundberg84S sundberg84
                                  P
                                  P
                                  Pierre1410
                                  @sundberg84 that is exactly what i experienced. thanks for the tip. struggling in fact to have my PIR sensor running on 3.3V. when i connect to the pin on the right of the board (3rd from top).. Arduino IDE serial terminal does not outcome any coherent information.
                                  • P Pierre1410
                                    @pierre1410 ok - well not to get your hopes down but a motion detector on batteries are one of the harder builds. If you are using a booster with the batteries it's harder due to false triggers from the booster noice. Also I believe the quality of your motion detector module determine if it's possible..I've had detectors running fine on 3.3v but several which didn't.
                                    • P
                                      P
                                      Pierre1410
                                      Hello, Is there a way to solder a DC-DC booster 3.3V to 5V directly onto the Easy PCB or should it be connected separately to power a PIR for instance? and would that really prevent using 2xAA batteries to power the all thing? have tried to step down the PIR to work at 3.3V but it was not conclusive. Thanks a lot.
                                      • P Pierre1410
                                        @pierre1410 - you can always use the prototyping area for a 3.3 to 5v booster but... booster + PIR might cause false triggers, so choose your booster wisely.
                                        • P
                                          P
                                          Pierre1410
                                          @sundberg84, had to migrate my gateway to Ethernet in the meantime but now I am on the PIR/ battery case. i have my booster to 5V in.. will post the results of it...
                                          gohanG 1 Reply Last reply
