  3. 💬 NRF2RFM69
💬 NRF2RFM69
rfm69adapterconverternrf24l01
113 Posts 29 Posters 59.6k Views 24 Watching
    I ordered 10 from Seeed Studio and I had no problems; I am waiting for delivery.
    B
    B
    bilbolodz
    @gohan Seeed Studio ask 11.16 for delivery :-(
    • B
      B
      bilbolodz
      I've uploaded (I hope all will be fine with PCB) on PCBs.io: https://pcbs.io/share/zZAMk
      3.10 USD for 4 pieces free shipment
        I had other pcb in order so shipping cost was not that bad, in addition 10 pcbs are 4.90$
        • B bilbolodz
          @tbowmo How about PCBs.io? Any chance for direct link? I've trying to upload it but got an error about "Gerber normalization for Layer: Drill Holes". I'm a quite newbie for designing/uploading files for PCB factories so sorry for maybe stupid question.
          tbowmoT
          tbowmoT
          tbowmo
          @bilbolodz
          There is also a link to dirtypcbs somewhere in this thread, where you can order pcb's.
          GertSandersG J 2 Replies Last reply
          • tbowmoT tbowmo
            @bilbolodz
            GertSandersG
            GertSandersG
            GertSanders
            @tbowmo
            http://dirtypcbs.com/store/pcbs
            • tbowmoT tbowmo
              @bilbolodz
              J
              J
              jeti
              wrote on last edited by jeti
              #46
              @tbowmo i have some left over. If you are interested just shoot me a pm
              Jeti
              tbowmoT 1 Reply Last reply
              • J jeti
                Jeti
                tbowmoT
                tbowmoT
                tbowmo
                @jeti
                Thanks, but I still have a couple left in my parts bin :)
                  Is it just me or there are some pins that are not exactly the same order as a normal 8 pins nrf24?
                    tbowmoT
                    tbowmoT
                    tbowmo
                    @gohan what do you mean?
                      Like CE pin is actually connected to the CSN pin on the 2x4 pin side
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        #51
                        @gohan
                        On NRF24 CSN is equivalent of CE signal on the SPI bus. While CE is a global on/off switch for the TX/RX on the NRF (Check page 11 in the nrf24 datasheet
                        On RFM69 CE is actually called NSS (pin 15). Datasheet are here
                        I don't have the schematics of this project at hand right now, as someone has forgotten to add a pdf of it to the repository ;)
                          I haven't mapped all the pins because yesterday I was a little tired, maybe tonight I'll check, but the fact is that I can't initialize the radio while the nrf24 works. 😕
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            I have used the board with a couple of sensebender micros.. and they worked fine..
                              Looking at the https://www.mysensors.org/build/raspberry page I have the current mapping on the board rfm69 side:
                              pin above DI00 is connected to CE pin
                              DI00 is connected to IRQ
                              NSS is connected to CSN
                              MOSI to MOSI ok
                              MISO to MISO ok
                              SCK to SCK ok
                              Do you think is correct?
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                RFM69 NSS is equivalent of NRF24 CSN
                                DIO0 act as interrupt line, and is attached in accordance with connecting the radio.
                                the pin above DIO0 is actually the reset line for the RFM69 module.. Which might come in handy, if you want to do a hardware reset at some point in time :)
                                  So why isn't it working then? Did I fry the radio?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @gohan
                                    Could you have added it to a 5V arduino? RFM is not 5V tolerant, so that could fry the radio..
                                      No, I used it only on the raspberry
                                        wrote on last edited by gohan
                                        #59
                                        New update: I used the module on the EasyPCB, nrf24 version, from @sundberg84 and recompiled the sketch to use the rfm69 and it is able to initialize the radio. So there must be something wrong with the compiled gateway on the RPI as it should be a direct swap from a NRF24. I am moving to the RPI thread
                                        PS Now it seems to be working... I haven't changed anything.... must have been a bad connection then
                                        mysgw: MCO:BGN:INIT CP=RPNG----
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: TSM:INIT:TSP OK
                                        mysgw: TSM:INIT:GW MODE
                                        mysgw: MCO:REG:NOT NEEDED
                                        mysgw: Listening for connections on 0.0.0.0:5003
                                        mysgw: MCO:BGN:STP
                                        mysgw: MCO:BGN:INIT OK,TSP=1
                                          Markus.
                                          Hi all,
                                          which size of cap should be used on this board and is it possible to connect a SMA Antenna ?
                                          Many thanks
                                          Markus
