  3. 💬 NRF2RFM69
💬 NRF2RFM69
rfm69adapterconverternrf24l01
113 Posts 29 Posters 59.6k Views 24 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    use a 4.7uF capacitor, or there about..
    There is no pads for a SMA connector, but you could attach one with a pigtail..
    M 1 Reply Last reply
    • tbowmoT tbowmo
      Markus.
      @tbowmo Thanks for the Information... One stupid question about the SMA conenctor :-) Is it enough to connect only the Antenna Output conenction or must GND also conencted...?
        You can just solder the antenna only on pcb. I use a coil spring type
          Markus.
          wrote on last edited by Markus.
          #64
          just one more question... I have on the Gateway a RFM69HW and a node with a RFM69W module. In the Gateway Sketch is the HW type enabled
          #define MY_RFM69_FREQUENCY RF69_868MHZ
          #define MY_IS_RFM69HW
          But there is no comunication from the node... I use Mysensors 2.1.1.
          Any idea?
            What gateway is that? I'd suggest to try mysensors 2.2 development
              Markus.
              @gohan It at the Moment only a test. So I have one EasyPCB NRF board with FTDI as Gateway and another EasyPCB board with DHT22 Sensor attached as Node. On both is a 4,7uF electrolytic condensator attached Close to the NRF socket. Both boards are at the Moment with RFM69W 868. The sensor node is battey powered.
                Get latest 2.2 library and use new rfm69 driver. Did you remember to close the IRQ contact in the easypcb?
                  Markus.
                  #68
                  @gohan Oh Sh* must check this... I've tried it yesterday on both devices the 2.2 Dev. But will Keep ypu informed...
                  Don't find the jumperfor the IRQ on the Rev 9 board. can you please post a Picture. Seems that this one is definitly not closed...
                  --> Edit... found it in the documentation but still the same.
                  Think the next Point to check for me are the antennas... :-(
                    I'd suggest to buy the coil spring antennas for your frequency, they are cheap and compact.
                      Markus.
                      in principle there is traffic between node and Gateway..
                      159631 !TSM:FPAR:NO REPLY
                      159637 TSM:FPAR
                      169848 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      171868 !TSM:FPAR:NO REPLY
                      171874 TSM:FPAR
                      179087 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      181106 !TSM:FPAR:FAIL
                      181112 TSM:FAIL:CNT=4
                      181118 TSM:FAIL:DIS
                      181123 TSF:TDI:TSL
                      191131 TSM:FAIL:RE-INIT
                      191137 TSM:INIT
                      191143 TSM:INIT:TSP OK
                      191150 TSM:INIT:STATID=10
                      191158 TSF:SID:OK,ID=10
                      191164 TSM:FPAR
                      198377 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      200396 !TSM:FPAR:NO REPLY
                      200402 TSM:FPAR
                      207616 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      209635 !TSM:FPAR:NO REPLY
                      209641 TSM:FPAR
                      216854 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      218873 !TSM:FPAR:NO REPLY
                      218880 TSM:FPAR
                      226093 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      228112 !TSM:FPAR:FAIL
                      228118 TSM:FAIL:CNT=5
                      228124 TSM:FAIL:DIS
                      228128 TSF:TDI:TSL
                      238135 TSM:FAIL:RE-INIT
                      238141 TSM:INIT
                      238147 TSM:INIT:TSP OK
                      238153 TSM:INIT:STATID=10
                      238161 TSF:SID:OK,ID=10
                      238168 TSM:FPAR
                      248385 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      250404 !TSM:FPAR:NO REPLY
                      250411 TSM:FPAR
                      257624 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      259643 !TSM:FPAR:NO REPLY
                      259649 TSM:FPAR
                      269731 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      271751 !TSM:FPAR:NO REPLY
                      271757 TSM:FPAR
                      0;255;3;0;9;189196 TSF:PNG:SEND,TO=0
                      0;255;3;0;9;189206 TSF:CKU:OK
                      0;255;3;0;9;189214 TSF:MSG:GWL OK
                      0;255;3;0;9;191236 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      0;255;3;0;9;244555 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      0;255;3;0;9;244574 TSF:MSG:BC
                      0;255;3;0;9;244582 TSF:MSG:FPAR REQ,ID=10
                      0;255;3;0;9;244594 TSF:PNG:SEND,TO=0
                      0;255;3;0;9;244604 TSF:CKU:OK
                      0;255;3;0;9;244613 TSF:MSG:GWL OK
                      0;255;3;0;9;257744 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      0;255;3;0;9;269957 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      0;255;3;0;9;269977 TSF:MSG:BC
                      0;255;3;0;9;269985 TSF:MSG:FPAR REQ,ID=10
                      0;255;3;0;9;269996 TSF:PNG:SEND,TO=0
                      0;255;3;0;9;270006 TSF:CKU:OK
                      0;255;3;0;9;270014 TSF:MSG:GWL OK
                      0;255;3;0;9;281585 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      0;255;3;0;9;289732 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      0;255;3;0;9;289753 TSF:MSG:BC
                      0;255;3;0;9;289761 TSF:MSG:FPAR REQ,ID=10
                      0;255;3;0;9;289771 TSF:PNG:SEND,TO=0
                      0;255;3;0;9;289781 TSF:CKU:OK
                      0;255;3;0;9;289789 TSF:MSG:GWL OK
                      0;255;3;0;9;297015 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      0;255;3;0;9;306757 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      0;255;3;0;9;306776 TSF:MSG:BC
                      0;255;3;0;9;306784 TSF:MSG:FPAR REQ,ID=10
                      0;255;3;0;9;306796 TSF:PNG:SEND,TO=0
                      0;255;3;0;9;306806 TSF:CKU:OK
                      0;255;3;0;9;306814 TSF:MSG:GWL OK
                      0;255;3;0;9;316682 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      0;255;3;0;9;322084 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      0;255;3;0;9;322103 TSF:MSG:BC
                      0;255;3;0;9;322111 TSF:MSG:FPAR REQ,ID=10
                      0;255;3;0;9;322123 TSF:PNG:SEND,TO=0
                      0;255;3;0;9;322131 TSF:CKU:OK
                      0;255;3;0;9;322142 TSF:MSG:GWL OK
                      0;255;3;0;9;333180 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                        That's either the node not receiving or the gateway having problems when sending
                          Markus.
                          @gohan :-( any idea what else I can do/check ?
                          alexsh1A 1 Reply Last reply
                          • M Markus.
                            alexsh1A
                            alexsh1A
                            alexsh1
                            #73
                            @Markus. You have an RF issue. Typically for nrf24l01+ I'd use a different power supply or a different module.
                            Are you sure both modules are set to the same channel and frequency? What antennas are you using?
                            Do you have HW modules?
                            • alexsh1A alexsh1
                              Markus.
                              #74
                              @alexsh1 I use at the Moment RFm69W 868 modules not NRF. Because the RFMs are mounted on the NRF connector on an EasyPCB. I use at the Moment single wire antennas with a lenght of 8,3 cm.
                              • M Markus.
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @Markus and channel and freq? are they the same in your sketch?
                                • alexsh1A alexsh1
                                  Markus.
                                  @alexsh1 should be, becaus ist not defined explicit in the Sketch. By Default in the MYS Lib 2.2 dev is it 868 mhz. And when i try to define the frequency in the Sketch. Like #define MY_RFM69_FREQUENCY RF69_868MHZ
                                  I get the error message. 'RF69_868MHZ' was not declared in this scope
                                  • M Markus.
                                    @Markus. try RFM69_868MHZ (RF69 -> RFM69)
                                      Markus.
                                      @mfalkvidd you are right... Ist now added in the GW and node Sketch, but still the same Problem.
                                        Markus.
                                        I think at the end will it be a power problem. It seems that the sensor node powered with 2x AA cells can not handle the Radio on TX/RX. The same on the Gateway site which is also a Easy PBB powered fom the FTDI Connector connected to USB. The question now is how can i fix this power Problems ? Or more, how can i make sure that this is definitly not the reason.
                                          Try bigger capacitor
