  2. Announcements
  3. MySensors 1.5.2 Released
35 Posts 6 Posters 17.2k Views 4 Watching
    @Anticimex
    Yes, I'll have to update the codebender library manually.
    korttomaK 1 Reply Last reply
    • carlierdC carlierd
      I tried to compile with 1.5.2 and got these errors:
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::sendRoute(MyMessage&)':
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:27:25: error: '_doSign' was not declared in this scope
       #define DO_SIGN(node) (~_doSign[node>>3]&(1<<(node%8)))
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:356:6: note: in expansion of macro 'DO_SIGN'
        if (DO_SIGN(message.destination) && message.sender == nc.nodeId && !mGetAck(message) && mGetLength(message) &&
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp: In member function 'boolean MySensor::process()':
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:28:25: error: '_doSign' was not declared in this scope
       #define SET_SIGN(node) (_doSign[node>>3]&=~(1<<(node%8)))
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:670:6: note: in expansion of macro 'SET_SIGN'
            SET_SIGN(msg.sender);
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:29:27: error: '_doSign' was not declared in this scope
       #define CLEAR_SIGN(node) (_doSign[node>>3]|=(1<<(node%8)))
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:673:6: note: in expansion of macro 'CLEAR_SIGN'
            CLEAR_SIGN(msg.sender);
      /Users/carlierd/Arduino/libraries/MySensors/MySensor.cpp:682:40: note: in expansion of macro 'DO_SIGN'
            if (signer.requestSignatures() && DO_SIGN(msg.sender))
      Erreur lors de la compilation.
      No compilation issue with 1.5. And everything is working perfectly.
      David.
      AnticimexA
      AnticimexA
      Anticimex
      @carlierd I found a problem there. I have to make a new release. Sorry for the inconvenience!
      carlierdC 1 Reply Last reply
      • AnticimexA Anticimex
        carlierdC
        carlierdC
        carlierd
        @Anticimex No problem !! Thanks for the support :)
          @Anticimex
          korttomaK
          korttomaK
          korttoma
          @hek said:
          @Anticimex
          I have uploaded 1.5.2 library as a Personal Library in codebender. I have not had any trouble doing this before. Just tried 1.5.3 but I get the same error.
          • Tomas
          • korttomaK korttoma
            Is there "SOMETHING" missing like this??
            MySensor gw(transport, SOMETHING);
            candidate constructor not viable: requires 2 arguments, but 1 was provided
                    MySensor(MyTransport &radio =*new MyTransportNRF24(), MyHw &hw=*new MyHwDriver()
            How do I define "MyHwDriver"??
            Weird it finds the MySensors constructor, it has a default value (MyHwDriver) but doesn't use it. Darn compilers.
            • AnticimexA
              AnticimexA
              Anticimex
              And you have selected a atmega328-based target when you build?
                korttomaK
                korttomaK
                korttoma
                I take it you have managed to reproduce the situation or do you need some more information from me?
                Yes, I have an "Arduino Pro Mini 5V 16MHz w/ ATmega328" selected when compiling.
                • Tomas
                  No, I'm currently @work.
                    @korttoma
                    Updated codebender lib to 1.5.3 and it fails with the same error you got.
                    Seems like codebender doesn't define ARDUINO_ARCH_AVR for the Uno board... which is used to select the correct hw-driver here:
                    https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L47
                    I've tried to reach Vasilis over at codebender but I guess it's a bit late for a reply today.
                    • ferpandoF
                      ferpandoF
                      ferpando
                      I updated to 1.5.3 and I get 2 warnings just by opening arduino IDE
                      Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                      WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
                      I'm using IDE 1.6.6
                      It was working before with MySensors 1.5
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        Those warnings are no reason for concern. Everything works like before.
                        ferpandoF 1 Reply Last reply
                          ferpandoF
                          ferpandoF
                          ferpando
                          @Anticimex
                          Ok, but is there a way to remove them?
                          I can confirm it compiles and uploads correctly.
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            Should just be a matter of editing platform.txt I suppose. I have not worked with those aspects. The release only change signing related parts. Those warnings are probably relating to IDE and versions of board support packages.
                              @korttoma
                              1.5.3 in codebender compiles now.
                              They're only compatible with arduino IDE 1.0.5 currently. Which means they don't define ARDUINO_ARCH_AVR which MySensors relies on.
                              Patched the codebender library (manually defining this) as a workaround until they update their things.
                              • korttomaK
                                korttomaK
                                korttoma
                                @hek how do I Patch my copy of 1.5.3 or where can I download the Patched version? Seems like it is stil 1.4 that is used on codebender unless you upload your own version.
                                • Tomas
