  3. MQTT Broker gateway
MQTT Broker gateway
132 Posts 34 Posters 147.5k Views 7 Watching
  • DammeD
    DammeD
    Damme
    Code Contributor
    I just wanted to say hello again to everyone. I had to disappear for a while. Just had too much for my brain to handle. So all my automation project were on halt but will be continued again.
    I know there are lot of bugs in this GW and I will hopefullt start developing soon again. Just write your experience you had so far and I'll try to keep up :)
    //Damme
    CARSTENC 1 Reply Last reply
    • JohnJ
      JohnJ
      John
      @Damme Good luck!
      • DammeD Damme
        //Damme
        CARSTENC
        CARSTENC
        CARSTEN
        @Damme I tried today the mysensor 1.4.1 library, uploaded with Arduino 1.5.8 to UNO with Ethernet Shield (W5100) and an NRF24L01+pa+lna. Compilation and upload worked fine.
        I can ping the IP address defined in the MQTTGateway.ino sketch.
        I maintained on my RPI the openhab.cfg file with the url and port number from the gateway.
        When starting the openhab it shows:
        ... - MQTT Service initialization completed.
        ... - Starting MQTT broker connection 'mysensor'.
        Then a couple of message later:
        ...Mqtt Exception
        Caused by: java.net.SocketTimeoutException: connect timed out
        Any suggestion what I could look at.
        I also tried to work with the development library of Mysensors but did not get very far with that. My ultimate goal is to something like a moteino with the RFM69HW radio module in connection with either openhab or pidome.
        I have a quite a bit of hardware lying around here so I am happy to do any testing if somebody gives me some guidance.
        Thanks.
        • CARSTENC CARSTEN
          ...Mqtt Exception
          Thanks.
          C
          C
          C.r.a.z.y.
          This post is deleted!
          • V
            V
            viking
            Thanks for the mqtt broker. Just a tip to people who might fall in to the same pit as I:
            The mqtt broker gateway doesn't distribute node ids unless you're connected to it using a mqtt client. I.e. if you did what I did, installed the gateway and wanted to test that the sensors found the gateway and was distributing the code then it doesn't work until you've connected to it. I had to go through the source code to figure it out.
            If you don't have openhab or simply want to test, this is what I did on my raspberry (but should work similarly on others)
            // install mosquitto client
            sudo apt-get install mosquitto-clients
            // Start the client, replace the 10.0.0.200 with your ip. The port will default to 1883
            mosquitto_sub -h 10.0.0.200 -d -t hello/world -v
            You should be able to see messages:
            Received PUBLISH (d0, q0, r0, m0, 'MyMQTT/20/0/V_LIGHT_LEVEL', ... (2 bytes))
              A Former User
              wrote on last edited by [[global:former-user]]
              #66
              Hi All
              Just a simple question:
              Are there any limitation in how many MQTT connections/sessions the MQTT Gateway can handle?
              If so, can this be changed?
              A 1 Reply Last reply
              • G
                G
                Gambituk
                Hello. I am new to Mysensors, openhab and mosquitto.. I have a working knowledge of arduino and nrf24l01, and currently am running a wireless(nrf) twitter controlled heating scheduler, and am sending multiple temp (ds18b20) sensors to Xively feed.
                I am really hooked on the idea of mqtt and openhab, and i thought that mysensors seemed like a good solution for implementing that idea.
                My progress so far is to install the DallasTemperatureSensor by MySensors node to one nano, and the ethernet gateway sketc as a first step, and now i have installed the mqttgateway again from the build page, and i have a working install of mosquitto and openhab on a rasp pi b+.
                I am just having difficulty getting it all stuck together. I have created the sitemap items and transform files as above and can access the openhab sitemap for the above configuration. i just don't know if i need to configure other items? how can i test each step? and can i use mosquitto with the setup that i have outlined. There seems to be conflicting info about what can and cannot be done with mosquitto and mysensors.
                1 do i need to modify the sketch of the temp node? i have some output from the serial that suggests that it is communicating with the gateway.
                2 do i need to modify the gateway with info of the mosquitto server?
                3 what can i do to test each step of the transit from temp sensor to openhab?
                Thanks for any and all responses.
                • X
                  X
                  xefil
                  Hello!
                  I've downloaded the 1.4.1 version of the library and tested it via OpenHab.
                  I'm still not getting the sketch_name correctly via MQTT and Openhab. Is it still an open bug?
                  Thanks!
                  Simon
                  • I
                    I
                    igorvin2
                    Hi Simon,
                    I had the same problem
                    I tried several time clean Eeprom and flash sketch again but with no results
                    Only after cleaning of Eeprom with the following scratch my sensor is starting work correctly
                    I recommend to try it:
                    Clearing EEPROM
                    Igor
                    • ? A Former User
                      Hi All
                      A
                      A
                      alexeinz
                      @mwhansen Hi, I am also struggling with this, seems it can only handle one connection now which makes it extremely hard to debug or check node ids
                      mqtt gw 1.4 /openhab / zwave
                        marceloaqno
                        Code Contributor
                        @Gambituk To connect to a external MQTT server (mosquitto) use this MQTT gateway version:
                        http://forum.mysensors.org/topic/524/mqtt-client-gateway/
                        • G
                          G
                          Gambituk
                          Thanks @celonunes I eventually found that version of gateway via somebody else. i have another post with some issues i found with that version. http://forum.mysensors.org/topic/921/strange-value-being-sent-from-controller-using-mixed-temp-relay-node it's not really resolved, but i have some kind of workaround.
                            marceloaqno
                            Code Contributor
                            #73
                            @mwhansen @alexeinz The MQTT gateway can handle up to four simultaneous socket connections, this is the limit of Arduino ethernet shield (Wiznet W5100).
                            The problem is that openhab don't get along with the way the gateway handles multiple client packages. I will send a fix for this problem in the next few days.
                            • M marceloaqno
                              A
                              A
                              alexeinz
                              @celonunes actually, i figured a way around it using mosquitto bridge
                              that way its much more robust too, so I am good :-)
                              can post my conf if anyone interested.
                                marceloaqno
                                Code Contributor
                                Those are the most recent changes to MQTT gateway:
                                • Fixed node id distribution by the gateway (reported by @viking)
                                • Fixed the problem with openhab and multiple MQTT clients
                                • Fixed the appearance of garbage in messages sent from MQTT to a node
                                • C
                                  C
                                  C.r.a.z.y.
                                  wrote on last edited by C.r.a.z.y.
                                  #76
                                  I can't change on-off manually for button with relay sketch, if i try, connection is lost, switching from screen never works again until restart everything.
                                  2015-03-05 15:51:29.200 [INFO ] [runtime.busevents ] - node2_sw2 received command OFF
                                  2015-03-05 15:51:32.624 [INFO ] [runtime.busevents ] - node2_sw2 received command ON
                                  Openhab 1.6.2 or 1.7.0 same result.
                                  **My main problem is losing connections with nodes. I also tried serial binding and same result.
                                  Mysensors+Openhab useless with mqtt and also serial binding
                                  M hekH 2 Replies Last reply
                                  • C C.r.a.z.y.
                                    marceloaqno
                                    Code Contributor
                                    @C.r.a.z.y. Could you send the serial output from the gateway? And a more complete log from openhab showing errors?
                                    • C C.r.a.z.y.
                                      Are you sure it isn't a powering issue of the "button-node" where radio shuts down when you press the button? Are you controlling a physical relay?
                                      • M marceloaqno
                                        C
                                        C
                                        C.r.a.z.y.
                                        @celonunes You can find MQTT and serial logs in the zip files openhab 1.6.2 and 1.7.0 logs-1.7.0.zip logs-1.6.2.zip
                                        @hek My nodes are working perfect when i only plug serial usb to any usb socket of a computer-printer-usb hub even a mobile phone charger :) they are good without server/controller
                                        • C
                                          C
                                          C.r.a.z.y.
                                          @hek My relay powered from nano icp headers maybe this makes trouble for wifi , i will change this and give update.
                                          My button is not normal button , its an ir distance sensor which trigers the relay.
