  3. 💬 Very narrow and minimal switch node
mysensorsbinary switchesi2cnrf24l01
66 Posts 19 Posters 33.7k Views 16 Watching
  • G Offline
    G Offline
    GertSanders
    @Carl H If the 1/4w resistor can fit in pads 7mm apart from each other, then should be no problem. But they need to stay flat to fit under the processor.
    • J Offline
      J Offline
      jacikaas
      Hello, @GertSanders I would like to ask. How I understand it is possible to load different sketch type to this board and then I could use it like one of MySensors sketches? For example could I load MyS humidity sketch? Thanks!
      G 1 Reply Last reply
      • J jacikaas
        G Offline
        G Offline
        GertSanders
        @jacikaas: to program the processor, you need to remove it from the board and program it on a breadboard or another board with ftdi interface.
        But you can load a sketch like the humidity sensor sketch if you add a I2C sensor like a SI7021. I plan to do just that.
        • G Offline
          G Offline
          GertSanders
          wrote on last edited by GertSanders
          #24
          The very narrow boards v1-1 have arrived :-)
          • G Offline
            G Offline
            GertSanders
            The latest member of my growing sensor family, a reedswitch sensor with wakeup from power down by change on pin 2, wakeup every 23 hours to report battery voltage, and of course a blinky light when these things happen :-)
            Just tested and found to be OK. Next board will be set up for using a I2C module (will be my smallest temperature sensor yet). Time for a glas of WestVleeteren and rest.
            alexsh1A 1 Reply Last reply
            • C Offline
              C Offline
              carlierd
              Very nice !!
              I just started learning Eagles to modify your board for RFM69 compatibility. The road will be long ;)
              Could be good also to add ATSHA204A but in a second time !
              David.
              • G GertSanders
                alexsh1A Offline
                alexsh1A Offline
                alexsh1
                @GertSanders
                Westvleteren Blonde is very nice :)
                Can you please remind me the difference berwrrn v1 and 1-1?
                I think it would be good to add FTDI connection, but the space is very limited
                G 2 Replies Last reply
                • alexsh1A alexsh1
                  @GertSanders
                  G Offline
                  G Offline
                  GertSanders
                  #28
                  @alexsh1 FTDI would be nice to reprogram more easily, but in my case I have a stable sketch which is loaded 1 time, and then the node is deployed. No point in providing extra pins or using boardspace if it is only used once or twice.
                  I saw that @AWI mentioned pogo-pins to make connections. Also a nice idea. In any case, my node is not designed to be flexible, and after programming I want to forget it. These nodes are sitting on doors and windows and need to do 1 thing only: show status of the reed-switched that are connected to them.
                  But adding some pads so that pogo pins can make contact to RX, TX and !RESET would still be possible.
                  It will be nice to see if a RFM69 radio can be connected by @carlierd . Looking forward to some pictures :-)
                  • alexsh1A alexsh1
                    @GertSanders
                    G Offline
                    G Offline
                    GertSanders
                    #29
                    @alexsh1
                    The difference between v1-0 and V1-1:
                    V1-0:
                    has 4 pins connected to VCC, GND, D2, D3 (in this sequence).
                    LED is connected to D8
                    V1-1:
                    has 4 pins, of which 2 are fixed. Vcc and GND are at the outside (closest to board edge).
                    The two pins in the middle (pin1 and pin2) can be connected to two different pins each by using the solder jumper.
                    pin1 can be connected to SDA/A4 or to D2
                    pin2 can be connected to SCL/A5 or to GND
                    LED is connected to D6
                    • G GertSanders
                      A Offline
                      A Offline
                      AWI
                      @GertSanders A bit off a hassle, but I don't need pads... ;-)
                      0_1457102582398_upload-7fc04aa0-f360-48dd-b170-601e208392ee
                      • A AWI
                        G Offline
                        G Offline
                        GertSanders
                        @AWI very nice, where did you buy the pins ?
                        • G GertSanders
                          A Offline
                          A Offline
                          AWI
                          @GertSanders I used these pins. These work for me but there are many other types in the same store which could serve your needs better.
                          • alexsh1A Offline
                            alexsh1A Offline
                            alexsh1
                            @GertSanders - my idea to use exactly for windows. I was thinking about z-wave ones, but £32 a pot is just way too expensive given I need quite a few. How do you power them?
                            • alexsh1A alexsh1
                              G Offline
                              G Offline
                              GertSanders
                              @alexsh1 I power them similar to @m26872 , but with AAA batteries. They fit the 16x16mm cable guide by Legrand (which is a known brand for this in Belgium), available is most DIY stores.
                              • Dombo71D Offline
                                Dombo71D Offline
                                Dombo71
                                Dear
                                I ordered a few...:-)
                                Do you have a working sketch that is using less power?
                                Perhaps wit a motionsensor and a DHt ore something
                                I hope i get you hardware working..
                                alexsh1A G 3 Replies Last reply
                                • Dombo71D Dombo71
                                  Dear
                                  alexsh1A Offline
                                  alexsh1A Offline
                                  alexsh1
                                  @Dombo71 said:
                                  Dear
                                  @Dombo71
                                  You can find a few working sketches in the 'Build' section of the website. However, don't you have an idea what it is exactly you'd like to build? I would be useful to know before throwing any sketch.
                                  FYG DHT is by far not a favourite one for a battery use in my view. There are others - SI7120 or BME280
                                  • Dombo71D Dombo71
                                    Dear
                                    G Offline
                                    G Offline
                                    GertSanders
                                    @Dombo71
                                    What do you mean with "using less power"?
                                    D 1 Reply Last reply
                                    • Dombo71D Dombo71
                                      Dear
                                      G Offline
                                      G Offline
                                      GertSanders
                                      @Dombo71
                                      Motion sensors are also not so low power and as mentioned before, DHT are power hungry. SI7021 is much better for low power/low voltage use.
                                      • G GertSanders
                                        @Dombo71
                                        Dylano
                                        @GertSanders said:
                                        SI7021
                                        I hope i can make a 3 in 1 sensor
                                        Motion / contact.
                                        temp and humanity
                                        Better should be a multisensor, with a lot of option so we can choose .
                                        The examples on my sensor are most 1 sensor...
                                        And then work on a battery[s] for a year
                                        Thanks for the SI7021 tip..
                                        Domoticz, with a lot of working hardware, include mysensors :-)
                                        OpenPLI, RuneAudio, Solarmeter, etc......
                                        Not a great builder of software and hardware, more a user...
                                        Only i try to do my best :-(
                                        • D Dylano
                                          @GertSanders said:
                                          SI7021
                                          Motion / contact.
                                          temp and humanity
                                          G Offline
                                          G Offline
                                          GertSanders
                                          #40
                                          @Dylano
                                          This board is not meant for more then 1 function.
