  3. 💬 MySensors Stable Node
mysensorscontest2016
103 Posts 29 Posters 71.3k Views 36 Watching
  • S Slorf
    Looks like what I have been looking for !
    Any progress on the gerber files ? ( so I can order pcb's )
    I was looking through the list of materials, but getting confusion while looking on Aliexpress, is it possible to share the links to the parts on Aliexpress/eBay ?
    Thanks !
    Alex
    KoreshK
    KoreshK
    Koresh
    @Slorf Sorry for delay. I've uploaded gerber files (100% correct - first batch was produced according to them).
    I ordered 0402 components in these shops:
    http://www.aliexpress.com/store/1171142
    http://www.aliexpress.com/store/821060
    • S
      Slorf
      Sorry, i am confused :-(
      How do i recognize the 4.7uf polarised capacitor ?
      Thanks !!
      Alex
      KoreshK 1 Reply Last reply
      • S Slorf
        Thanks !!
        Alex
        KoreshK
        KoreshK
        Koresh
        @Slorf https://en.wikipedia.org/wiki/Micro- :smiley:
        • S
          Slorf
          This would be the first pcb's i order, how do i know which component goes where on the pcb ?
          • S
            Slorf
            @Koresh
            How do i know it;s a polarized version ?
            There are these ( which i think are the wrong ones )
            http://www.aliexpress.com/item/Free-shipping-0805-SMD-capacitor-4-7uf-50V-475Z-100PCS/32376068362.html?spm=2114.01010208.3.40.rvV9hM&ws_ab_test=searchweb201556_9,searchweb201644_4_505_506_503_504_10020_502_10001_10002_10017_10010_10005_10011_10006_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201560_2,searchweb1451318400_-1,searchweb1451318411_6452&btsid=833ff5df-930f-4fd8-8530-cb280a1b9c7f
            and there are these:
            http://www.aliexpress.com/item/Free-shipping-100pcs-lot-475K-X7R-25V-0805-4-7UF-SMD-capacitor-Chip-Capacitor-Electronic-Components/32607720756.html?spm=2114.01010208.3.207.rx4LMW&ws_ab_test=searchweb201556_9,searchweb201644_4_505_506_503_504_10020_502_10001_10002_10017_10010_10005_10011_10006_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201560_2,searchweb1451318400_-1,searchweb1451318411_6452&btsid=0572ec4f-a6b5-44fb-aa59-70649256d584
            • S Slorf
              @Koresh
              KoreshK
              KoreshK
              Koresh
              @Slorf OK. Use non-polarized (ceramic) capacitor 0805 4.7uF and polarized 10uf (yellow 3216) capacitor. I've changed bom.
              I've uploaded assembly pdf too :).
              • S
                Slorf
                @Koresh
                Thanks, i found everything on Aliexpress, except:
                Push Button SPDT
                Resistor 1M ( which package size )
                Alex
                • S Slorf
                  @Koresh
                  Push Button SPDT
                  Alex
                  KoreshK
                  KoreshK
                  Koresh
                  @Slorf
                  Resistor 1M ( which package size ) - unnecessary element (R1 can be mounted for backward compatibility with nRF24L01, nevermind)
                  Push Button - use any buttons like these http://ru.aliexpress.com/item/10-Pcs-x-Sealed-SMD-Momentary-Tact-Tactile-Push-Button-Switch-3mm-x-6mm-x-2/32600602500.html?spm=2114.30010708.3.10.QkNxnX&ws_ab_test=searchweb201556_6,searchweb201644_3_505_506_503_504_301_10020_502_10001_10002_10017_10010_10005_10006_10011_10003_10021_10004_10022_10009_10007_10008_10018_10019,searchweb201560_3,searchweb1451318400_-1,searchweb1451318411_6451&btsid=efafd213-4a02-41ac-8d40-b5e9982a58f1 :wink:
                  • S
                    Slorf
                    @Koresh
                    Will search and find the cheapest offers on Aliexpress :-)
                    • S
                      Slorf
                      @Koresh
                      When I try and order the pcb's from dirtypcb I get the following error:
                      PCB #17568: No board outline (.GML/.GKO/.GBR) file found.
                      I made a zip file with cam.drl, main.gbl, main.gbo, main.gbs, main.gtl, main.gto, main.gts
                      when I try to upload this on dirtypcb I get the error message that there is no board outline.
                      regards
                      Alex
                      • S Slorf
                        @Koresh
                        regards
                        Alex
                        KoreshK
                        KoreshK
                        Koresh
                        @Slorf It's openhardware.io engine problem. Engine had removed some files from my zip. Use files from this complete archive (gm2 - mechanical layer, rename it if its nessesary).
                        0_1456686721977_nrf_17_01_fabr.zip
                          @Koresh
                          .gm2 was a new extension I didn't know about.
                          I've updated the file extraction engine. When you get a chance, please try uploading it again.
                            @Koresh
                            KoreshK
                            KoreshK
                            Koresh
                            @hek
                            Thanks for quick fix :)
                            gm2 = gerber mechanic layer2. So there are many variations of file extensions. I think it would be perfect to add ability to attach a file with custom extension or raw zip\rar without extraction.
                            • S
                              Slorf
                              @Koresh
                              I renamed the gm2 file to gml ( see: http://jrainimo.com/build/?p=642 ), and was able to order it from dirtypcb.
                              Alex
                              • S Slorf
                                @Koresh
                                Alex
                                KoreshK
                                KoreshK
                                Koresh
                                wrote on last edited by Koresh
                                #35
                                @Slorf One detail.... If it is not so late - please change your order (sorry...). Board thikness must be 1.6mm (antenna tunned for this value). I've changed board description.
                                • S
                                  Slorf
                                  @Koresh
                                  I mailed the people at dirtypcb, hopefully they can change it for me.
                                  If they cannot change it, would it be possible to get rid of the antenna and mount a pa/lna antenna ?
                                  Regards
                                  Alex
                                  • S Slorf
                                    @Koresh
                                    Regards
                                    Alex
                                    KoreshK
                                    KoreshK
                                    Koresh
                                    #37
                                    @Slorf Do not worry. Antenna will work with any board thikness, but with 1.6mm (with current geomerty configuration) it will be optimal. Almost all china nrf modules (I've seen) have non optimal antenna geometry.
                                    PS
                                    I'am sorry :( I hope dirtypcb will change you order.
                                    @Slorf said in MySensors Stable Node:
                                    It is possible, but its very non technologically...
                                    • ahmedadelhosniA
                                      ahmedadelhosniA
                                      ahmedadelhosni
                                      Great board.
                                      Did you test the performance ? Like number of recieved packets per second ?
                                      • S
                                        Slorf
                                        @Koresh
                                        Let's hope the change it :-)
                                        Would it be possible to mount something like this on the pcb ?
                                        http://www.aliexpress.com/item/New-SMA-female-jack-PCB-board-mount-right-angle-RF-coax-adapter-connector-converter/32588385730.html?spm=2114.01010208.3.2.S4UqzO&ws_ab_test=searchweb201556_7,searchweb201644_2_505_506_503_504_10020_502_10001_10002_10017_10010_10005_10011_10006_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201560_3,searchweb1451318400_-1,searchweb1451318411_6449&btsid=91e89a18-89b4-43d2-bbab-ea422e14d360
                                        • S
                                          Slorf
                                          @Koresh
                                          Couple of questions :-)
                                          How to mount the second Quartz crystal ?, there are no holes in the pcb
                                          The LDO regulators are mounted next to 4.7uf capacitors, is it correct that the regulators and capacitors are connected to eachother on both sides ?
                                          On the photo of the assembled pcb it looks like this, but on the photo of the plain pcb and the schematic it look different.
        | Pin 1
        IC3
        Pin2    |          | Pin 3
                                                  Are pin 2 and 3 also connected to the capacitor left and right pin ?
        Left pin   |    C14   | Right pin
                                          Thanks !!
                                          Alex
