  3. Run a script when virtual button is pushed
6 Posts 4 Posters 2.8k Views 4 Watching
  • Sander StolkS
    Sander StolkS
    Sander Stolk
    Hi there,
    I would like to know if it's possible to present an switch to my gateway / Domoticz and when this switch is pressed in Domoticz it activates a script on the Arduino node which sends a IR signal once.
    Maybe it is even possible to distinguish several virtual buttons so several different scripts can run?
    Because I would like to control my airco unit without the remote from downstairs. So I can turn it on and off or change the temp.
    Is there anybody with such a script as a example?
    Tnx!
    • BartEB
      BartEB
      BartE
      @Sander-Stolk You might want to use my RC record and playback project.
      http://forum.mysensors.org/topic/2413/ir-record-and-playback-module/7
      It works also under Domoticz, you might need to add additional switches for start recording.
      which sends a MySensor message of type V_IR_RECORD with the preset number as payload.
      I've just tried a pre programmed version of my RC module with Domoticz and when a preset value is decoded and received by Domitics it creates a Light switch for that code. And when pressing the light tile on Domiticz the RC modules receives back the V_IR_SEND message.
      W 1 Reply Last reply
      • tbowmoT
        tbowmoT
        tbowmo
        @Sander-Stolk
        There is an example sketch for controlling hvac units.
        They are a bit different, in that respect they don't use simple commands like on or off, like TVs do. They transfer a complete setup of temperature, fan speed etc with every button press. So they need a bit more than just record/playback of IR transmission.
        Sander StolkS 1 Reply Last reply
        • tbowmoT tbowmo
          @Sander-Stolk
          Sander StolkS
          Sander StolkS
          Sander Stolk
          @tbowmo said:
          "They transfer a complete setup of temperature, fan speed etc with every button press."
          This I noticed because when I remove the battery the next press of a button is indeed temp, flow, speed en dry etc.
          I've got the RAW data and I'm sending the RAW data and this works. So I've got a script but I only need a trigger to execute it.
          The trigger is the only problem I have.
          • tbowmoT
            tbowmoT
            tbowmo
            found the sketch here
            https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/HeatpumpIRController
            • BartEB BartE
              W
              W
              Wackid
              @BartE
              How do you record an IR in Domoticz? Can you explain in detail please? I tried several things bit can't get it working.
