  3. LED name wrong in 2.0.0 beta
7 Posts 3 Posters 2.2k Views 3 Watching
  • L
    L
    lafleur
    In MyConfig.h names are:
    #define MY_DEFAULT_ERR_LED x
    #define MY_DEFAULT_TX_LED x
    #define MY_DEFAULT_RX_LED x
    In MyLeds.ccp they are:
    #define MY_DEFAULT_TX_LED_PIN
    #define MY_DEFAULT_ERR_LED_PIN
    #define MY_DEFAULT_RX_LED_PIN
      Thanks for reporting, will fix the comment.
      • L
        L
        lafleur
        Variable name is wrong, not the comments
          MY_DEFAULT_TX_LED _PIN
          Is the correct suffix. I could only find a commented section in MyConfig.h without the correct suffix. Or what do you mean? Show me a link/line number to github where you found the incorrect declaration.
          • L
            L
            lafleur
            My pull from the development hub is a few weeks old, I'll check my pull from current master when I get home tonight ....
            • L
              L
              lafleur
              I pulled the current development version... on 3 Mar 2016
              In myconfig.h at line 167, we have the block below:
              if you un comment one of the LED define, they do NOT enable the LED, only if you use the 2nd versions as defined in MyLeds.ccp.
              #define MY_DEFAULT_ERR_LED 15 <--- not working
              #define MY_DEFAULT_ERR_LED_PIN 15 <--- working
              *  Information LEDs blinking
              // This feature enables LEDs blinking on message receive, transmit
              // or if some error occurred. This was commonly used only in gateways,
              // but now can be used in any sensor node. Also the LEDs can now be
              // disabled in the gateway.
              //#define MY_LEDS_BLINKING_FEATURE
              // The following setting allows you to inverse the blinking feature MY_LEDS_BLINKING_FEATURE
              // When MY_WITH_LEDS_BLINKING_INVERSE is enabled LEDSs are normally turned on and switches
              // off when blinking
              // The following defines can be used to set the port pin, that the LED is connected to
              // If one of the following is defined here, or in the sketch, MY_LEDS_BLINKING_FEATURE will be
              // enabled by default. (Replace x with the pin number you have the LED on)
              //#define MY_DEFAULT_ERR_LED x
              //#define MY_DEFAULT_TX_LED x
              //#define MY_DEFAULT_RX_LED x
              • tbowmoT
                tbowmoT
                tbowmo
                @lafleur
                You could create a PR to change this (We would love to get contributions to the code)
