  3. Vera
  4. Issue with temperature units
23 Posts 9 Posters 11.8k Views 2 Watching
  • T
    TroyF
    Hello everyone,
    I'm just starting out with MySensors, but think it's just amazing. Thanks to Hek and everyone else who has contributed for putting this together. I recently tried to setup a v1.4 serial gateway and a simple temperature sensor but for some reason I'm having trouble with the temperature reporting back to imperial, despite Metric being selected in the gateway device within Vera. I've tried toggling the switch back and forth, restarting Vera etc., but the temperature keeps being reported in Fahrenheit. Does anyone have any suggestions?
    Thanks,
    Troy.
    RJ_MakeR 1 Reply Last reply
    • JohnJ
      JohnJ
      John
      Are you sure that the temperature sensor if it is an digital one, is not reporting Fahrenheit? I think 1.4 is set to SI and fahrenheit isn't.
        @TroyF
        Strange. Try clearing eeprom an re-include sensor.
        • T TroyF
          Hello everyone,
          Thanks,
          Troy.
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          wrote on last edited by RJ_Make
          @TroyF
          I have the same problem (but reverse), and the only fix is to hard code the conversion..
          Replace this (for the Temperature sketch) from @hek
           float temperature = static_cast<float(static_cast<int((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
          With this
           float temperature = static_cast<float>(static_cast<int>((sensors.getTempFByIndex(i)) * 10.)) / 10.;
          and this is what I used for the Humidity & Temp. Sketch
          	//float temperature = dht.getTemperature();
          	float temperature = dht.getTemperature()*9/5 + 32;
          	if (isnan(temperature)) {
          	lastTemp = temperature;
          	if (!metric) {
          		temperature = dht.getTemperature()*9/5 + 32;   //dht.toFahrenheit(temperature);
          	Serial.print("T: ");
          	Serial.println(temperature);
          EDIT: Keep in mind you will need to make the changes necessary to convert to Celsius
          RJ_Make
          • T
            TroyF
            Strange. I actually just left it alone and a few hours later it was reading in Celsius like it should have been. Not sure why it took a while to start reading that way, but it's fine now. Thanks to everyone for their responses.
            • L
              L
              legeantvert
              I have seen the same issue with 1.4 when using DHT or Dallas ...
              I have try to clean EEPROM, change on Vera from metric to Imperial and back to metric without any succes...
              So hardcode temperature in C was the solution for me...
              Legeantvert
              -Oregon Scientific meteo sensors 433mhz
              -Vera3 fw:1.5.408fr
              -Zwave 3HSM02 1Duwi5457 2*AD142-6
              -IPX800v3
              -3 X Foscam
              -Synology DS413
              -Domoticz on Raspberry => on progress
              -MySensors Serial Gw + some arduino sensors => on progress
              • jocke4uJ
                jocke4uJ
                jocke4u
                I have the same problem with DallasSensor
                Startup says:
                sensor started, id 2
                send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=3,st=ok:1.4
                send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                read: 0-0-2 s=255,c=3,t=6,pt=0,l=2:M                          <<<==== Metric <<<
                send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=17,st=ok:Light+Temp Sensor
                send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                send: 2-2-0-0 s=0,c=0,t=16,pt=0,l=3,st=ok:1.4
                And I trace:
                Serial.println(gw.getConfig().isMetric);
                which output 0, not 1
                Switching to Imperial I get:
                read: 0-0-2 s=255,c=3,t=6,pt=0,l=2:I                          <<<==== Imperial <<<
                and the trace says 0 as expected.
                Then I tried to trace in MySensors.cpp and added (not workin though ;) ):
                } else if (type == I_CONFIG) {
                    // Pick up configuration from controller (currently only metric/imperial)
                    // and store it in eeprom if changed
                    isMetric = msg.getByte() == 'M' ;
                    debug(PSTR("isMetric=%s\n"), isMetric);
                    debug(PSTR("cc.isMetric=%s\n"), cc.isMetric);
                    if (cc.isMetric != isMetric) {
                But then it started to work :D
                Removed the lines above and the problem is back....so something there...
                Don't have time right now to test....
                  @jocke4u
                  Are you saying adding debug prints makes it work?
                  jocke4uJ 1 Reply Last reply
                    @jocke4u
                    jocke4uJ
                    jocke4uJ
                    jocke4u
                    @hek
                    Yes for some strange reason :)
                    However I used %s and not %d in the debug but have now used %d as below
                        debug(PSTR("isMetric=%d\n"), isMetric);
                        debug(PSTR("cc.isMetric=%d\n"), cc.isMetric);
                            cc.isMetric = isMetric;
                            debug(PSTR("Updating EEPROM\n"));
                            eeprom_write_byte((uint8_t*)EEPROM_CONTROLLER_CONFIG_ADDRESS, isMetric);
                            //eeprom_write_block((const void*)&cc, (uint8_t*)EEPROM_CONTROLLER_CONFIG_ADDRESS, sizeof(ControllerConfig));
                    Gives the output
                    isMetric=0
                    cc.isMetric=1
                    Updating EEPROM
                    isMetric=0
                    cc.isMetric=0
                    So it seems that "metric" flag is not unpacked correctly, or?
                    • YveauxY
                      YveauxY
                      @jocke4u said:
                      l=2:M
                      I find it strange that length is reported as 2 while only a single character seems to be sent. The protocol version 1.4 is correctly reported as length 3.
                      hekH 1 Reply Last reply
                      • YveauxY Yveaux
                        @jocke4u said:
                        l=2:M
                        @Yveaux
                        uint8_t MyMessage::getByte() const {
                        	if (miGetPayloadType() == P_BYTE) {
                        		return data[0];
                        	} else if (miGetPayloadType() == P_STRING) {
                        		return atoi(data);
                        	} else {
                        		return 0;
                        Payload type will be P_STRING when controller sends the data. Yes, why does it get size 2?!
                          @Yveaux
                          		return data[0];
                          		return atoi(data);
                          	} else {
                          		return 0;
                          wrote on last edited by hek
                          Hmm.. we should probably not use atoi in case of String. Payload type should not matter in the getByte.
                            Yep, this is a bug.
                            I've also found that the newline character is included and transmitted on all outgoing messages from gateway! So payload length 2 was correct, and wrong ;)
                            How is it possible no one has seen this before (me included)?
                            YveauxY 1 Reply Last reply
                            • jocke4uJ
                              jocke4uJ
                              jocke4u
                              Sounds good anyway....one bug less :)
                              I just setup a sensor with DHT22/AM2302 and get the same results here.
                                Fix checked in. I'm creating a more comprehensive release note in the 1.4 thread.
                                  Yep, this is a bug.
                                  YveauxY
                                  YveauxY
                                  At least I saw it ;-)
                                  I personally tend to read over all the details in the serial api... This time I noticed.
                                  Be glad you nailed it!
                                  • jocke4uJ
                                    jocke4uJ
                                    jocke4u
                                    Thanks @hek and @Yveaux I can confirm it's working on both Dallas sensor and DHT22.
                                    Great support!!
                                    • NuubiN
                                      NuubiN
                                      Nuubi
                                      Hmmm... how can one override this statement to be METRIC?
                                      float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?TemperatureSensors.getTempCByIndex(CHILD_ID_TEMPERATURE_FIRST+i):TemperatureSensors.getTempFByIndex(CHILD_ID_TEMPERATURE_FIRST+i)) * 10.)) / 10.;
                                      • H
                                        H
                                        hexenmeister
                                        hello,
                                        I must confess I have not read this thread completely. Too much for my bad english)
                                        We try MySensors support for FHEM (www.fhem.de) to impementieren. I noticed that when the I_CONFIG message is answered correctly with 'M' for metric, then the sensor sends in Imperial. Is not surprising, everything is interpreted as a string from Gateway, but also byte checked. My solution proposal: In MySensors.cpp:
                                        (isMetric = msg.getString()[0] == 'M' ; instead of isMetric = msg.getByte() == 'M' ;)
                                        				//isMetric = msg.getByte() == 'M' ;
                                        			} else if (type == I_CHILDREN) {
                                        Best regards,
                                        Alexander
                                          Welcome @hexenmeister!
                                          What version of MySensors library did you download? The current version in gihub/master already has getString()[0].
