  3. Is it possible to use ESP8266's OTA capabilities?
20 Posts 6 Posters 12.2k Views 10 Watching
  • AndurilA
    AndurilA
    Anduril
    Hey there,
    I just found out about the possibility to upload a new sketch to the ESP by using an OTA network port in the IDE. But therefore you have to configure your sketch to allow incoming connections for upload and have enough free space to store the new firmware before reboot.
    Is it possible to combine one of the multiple upload scenarios with the wifi gateway sketch? Has anyone tried to do this?
    That would make the ESP even more powerful, for example when changing to a new version of dev branch or when you have locally attached sensors on it.
    • AndurilA
      AndurilA
      Anduril
      Today I found an example in dev branch named GatewayESP8266OTA... does this mean it is already implemented? Or at least it's been worked on? Could please someone explain how to use?
      tekkaT 1 Reply Last reply
      • AndurilA Anduril
        tekkaT
        tekkaT
        tekka
        @Anduril yes, I've added the esp8266 OTA example, works nicely for sketch updates.
        Read here for instructions.
        AndurilA 1 Reply Last reply
        • tekkaT tekka
          AndurilA
          AndurilA
          Anduril
          @tekka thanks a lot for that info. I already tried that some time ago and gave up.
          I flashed the OTA gateway and it works fine. Only when trying to ota upload I get problems. The Arduino IDE says [ERROR]: No response from device and in the serial console I see the following:
          0;255;3;0;9;read: 1-1-0 s=1,c=1,t=1,pt=7,l=5,sg=0:39.1
          sleep disable
          Error[1]: Begin Failed
          0;255;3;0;9;read: 1-1-0 s=2,c=1,t=0,pt=7,l=5,sg=0:23.8
          Do you know whats happening there?
          • AndurilA
            AndurilA
            Anduril
            @tekka did you used password protection for OTA update or any other security feature? Did you change anything in the sketch except SSID and password for wifi?
            • AndurilA Anduril
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              @Anduril No, I simply followed these instructions:
              https://github.com/esp8266/Arduino/blob/master/doc/ota_updates/readme.md and used this sketch for testing:
              https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/GatewayESP8266OTA
              • AndurilA
                AndurilA
                Anduril
                @tekka do you have and NodeMCU Devkit 0.9 or 1.0? I have a 1.0 and get the error. But I use it with fixed IP on the gateway sketch, maybe that's a problem. It uploads ok via serial. But when uploading via wifi (changed static ip for testing) it stuck. Maybe I will try it with dhcp enabled.
                • AndurilA Anduril
                  tekkaT
                  tekkaT
                  tekka
                  @Anduril I'm using a NodeMCU 1.0 (MySensors 2.0.0beta and ESP8266 lib 2.1.0) with fixed IP. Both, OTA and serial FW updates work flawlessly...
                  • AndurilA
                    AndurilA
                    Anduril
                    @tekka thanks for that info, I'm also using MySensors 2 beta but ESP lib 2.0 (as far as I know, corrently at work). I will check that later and test with updated ESP library.
                    • AndurilA
                      AndurilA
                      Anduril
                      @tekka did you changed any of the standard settings for ESP flashing? I simply updated ESP8266 library and reflashed, but I get an reboot loop. In the serial monitor I see:
                      0‚~?–4“Ò¶£ÿOAaû0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
                      0;255;3;0;9;Radio init successful.
                      scandone
                      state: 0 -> 2 (b0)
                      state: 2 -> 3 (0)
                      state: 3 -> 5 (10)
                      add 0
                      aid 2
                      cnt
                      connected with mDjEKlujYacByG5JtxlY, channel 1
                      ip:192.168.38.19,mask:255.255.255.0,gw:192.168.38.1
                      .IP: 192.168.38.19
                      ¥üÊæ” ×Åü1¤ñþ0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
                      scandone
                      state: 0 -> 2 (b0)
                      When going back to 2.0.0 it works without problems. Here my settings for flashing:
                      • AndurilA Anduril
                        scandone
                        state: 0 -> 2 (b0)
                        state: 2 -> 3 (0)
                        state: 3 -> 5 (10)
                        add 0
                        aid 2
                        cnt
                        .IP: 192.168.38.19
                        scandone
                        state: 0 -> 2 (b0)
                        tekkaT
                        tekkaT
                        tekka
                        @Anduril I'm using the NodeMCU 1.0 (ESP-12E Module) settings / ESP 2.1.0 lib / and the latest MySensors dev (including PR#419 - there was indeed a rebooting issue before #419)...
                        • AndurilA
                          AndurilA
                          Anduril
                          thanks a lot, working with newest dev build and ESP8266 lib version 2.1.0 as you said.
                          • AndurilA Anduril
                            tekkaT
                            tekkaT
                            tekka
                            @Anduril excellent! Have fun :)
                            • R
                              R
                              Rasenheizung
                              wrote on last edited by Rasenheizung
                              I'm trying to use the serial monitor but I'm always ask entering a password? Although I didn't used one?
                              Reflashing sketch via OTA worked without any issues.
                              Edit: Tried to use a real OTA password and it's still not working although I'm using the correct. ESP8266 Tools 2.2.0
                              • AndurilA
                                AndurilA
                                Anduril
                                to my last knowledge this feature is implemented but not working. If you want to see the serial monitor you have to connect physically.
                                NeverDieN 1 Reply Last reply
                                • AndurilA Anduril
                                  NeverDieN
                                  NeverDieN
                                  @Anduril
                                  Regarding the bootloops: how you structure your code seems to have an effect. If you have busy-waits in your code, you're more likely to encounter the WDT timeout. I restructured my code to be more interrupt driven and to complete more frequent cycles through the main loop(). After doing that, the WDT timeouts stopped.
                                  That said, I don't know whether your bootloop is caused by a WDT timeout or something else. At least in my case, the debug messages being printed in the serial window specifically mentioned WDT being involved.
                                  • Mark SwiftM
                                    Mark SwiftM
                                    Mark Swift
                                    I presume debugging via network is not supported, I read some posts on Github but couldn't be sure if it was implemented?
                                    • Mark SwiftM Mark Swift
                                      NeverDieN
                                      NeverDieN
                                      @Mark-Swift
                                      By debugging, do you mean looking at the serial console output over the network, or something else?
                                      Mark SwiftM 1 Reply Last reply
                                      • NeverDieN NeverDie
                                        @Mark-Swift
                                        Mark SwiftM
                                        Mark SwiftM
                                        Mark Swift
                                        @NeverDie said:
                                        @Mark-Swift
                                        Yes, serial monitor via network within IDE...
                                          I haven't tried it yet but this plugin for serial monitor over network looks nice https://github.com/esp8266/Arduino/issues/1360
