  3. Home Assistant
  4. 'Bad byte' error
'Bad byte' error
34 Posts 2 Posters 8.6k Views 2 Watching
  • ? Offline
    ? Offline
    A Former User
    Hi.
    I have justed connected my USB mysensors gateway. But im getting the 'bad byte' error. At first i didnt know that i should had installed the pyserial. But still after the install to pyserial 3.0.1. Im still getting the 'bad byte' error can some help, this is the log.
    6-03-12 01:20:43 mysensors.mysensors: Trying to connect to /dev/ttyUSB1
    16-03-12 01:20:43 mysensors.mysensors: /dev/ttyUSB1 is open...
    16-03-12 01:20:43 mysensors.mysensors: Connected to /dev/ttyUSB1
    16-03-12 01:20:46 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
    • ? A Former User
      Hi.
      martinhjelmareM Offline
      martinhjelmare
      @fleshfear
      Hi!
      Have you tried to keep running HA after the error to see if the next message comes through alright?
      For me this error usually goes away after a restart of HA.
      • ? Offline
        ? Offline
        A Former User
        Yes now the ha have been runing all night, with the gateway connected. And the 'bad byte' error is the last thing there is logge from mysensor.
        • martinhjelmareM Offline
          martinhjelmare
          First try to disconnect and reconnect the usb to the arduino. Start hass. Make sure you connect to the correct port after reconnecting the usb. Sometimes the arduino will change port name.
          If this doesn't help try another version of pyserial. 2.5 has been the least buggy for me. You can also try 2.7.
          • ? Offline
            ? Offline
            A Former User
            I have tried connecthing and reconnecthing multiple times. But how do I down grade to 2.5, right now I have just installed 3.0.1?
            • ? A Former User
              martinhjelmare
              @fleshfear
              pip3 install pyserial==2.5
              • ? Offline
                ? Offline
                A Former User
                now i have 2.5. But still no luck. What to do.
                • ? Offline
                  ? Offline
                  A Former User
                  now i allso have this in my log
                  16-03-12 19:45:33 mysensors.mysensors: Error decoding message from gateway, probably received partial data before connection was complete.
                  • ? A Former User
                    martinhjelmare
                    @fleshfear
                    Nothing else is accessing the serial port?
                    • ? Offline
                      ? Offline
                      A Former User
                      no that i know of. Its a virtual machine dedicated to only ha. And i have just testet if it was the virtual enviroment there was to blame. But on indigo domistic the plugin for mysensors works and can talk to the gateway.
                      Im i missing something else like pyserial or?
                      Is the only thing needed ha and pyserial?
                        martinhjelmare
                        Have you rebooted the machine after installing pyserial 2.5?
                        You can also check that there's no remains of other pyserial versions where the python packages are installed on your machine.
                        What distribution are you running?
                        • ? Offline
                          ? Offline
                          A Former User
                          yep have rebooted, many times after that.
                          How do i check if there are any other version installed? I could not install pyserial just like you said, i had to run a
                          pip3 uninstall pyserial
                          first.
                          it' a ubuntu 15.10
                            martinhjelmare
                            Python library files on Ubuntu are usually found in:
                            /usr/local/lib/pythonX.X/site-packages
                            • ? Offline
                              ? Offline
                              A Former User
                              ls -la /usr/local/lib/python3.4/dist-packages/
                              homeassistant/                  MarkupSafe-0.23.egg-info/       pytz-2015.7.dist-info/          vincenty/
                              homeassistant-0.15.0.dist-info/ pip/                            PyYAML-3.11.egg-info/           vincenty-0.1.3.egg-info/
                              jinja2/                         pip-8.1.0.dist-info/            requests/                       yaml/
                              Jinja2-2.8.dist-info/           pyserial_py3k-2.5.egg-info/     requests-2.9.1.dist-info/
                              markupsafe/                     pytz/                           serial/
                              • ? Offline
                                ? Offline
                                A Former User
                                also don't know if, it is related.
                                but i had this in the configuration:
                                persistence_file: 'mysensors.json'
                                But every time i started the HA, the log said it couldnt find the file. But efter i removed it, and create the new file i couldnt find. the new log have this:
                                16-03-12 22:26:47 homeassistant.bootstrap: Error during setup of component mysensors
                                Traceback (most recent call last):
                                  File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 105, in _setup_component
                                    if not component.setup(hass, config):
                                  File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 111, in setup
                                    port, persistence, persistence_file, version, baud_rate)
                                  File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 75, in setup_gateway
                                    baud=baud_rate)
                                  File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 277, in __init__
                                    persistence_file, protocol_version)
                                  File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 32, in __init__
                                    self._load_sensors()
                                  File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 162, in _load_sensors
                                    self._perform_file_action(self.persistence_file, 'load')
                                  File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 177, in _perform_file_action
                                    func(filename)
                                  File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 133, in _load_pickle
                                    self.sensors = pickle.load(file_handle)
                                EOFError: Ran out of input
                                • ? Offline
                                  ? Offline
                                  A Former User
                                  the new config looks like this
                                  mysensors:
                                    gateways:
                                      - port: '/dev/ttyUSB0'
                                        baud_rate: 38400
                                    debug: true
                                    persistence: true
                                    version: '1.5'
                                    optimistic: true
                                    martinhjelmare
                                    Which arduino model are you using for the gateway?
                                    • ? Offline
                                      ? Offline
                                      A Former User
                                      Its a nano.
                                        martinhjelmare
                                        Did you change baudrate in MyConfig.h to 38400? Otherwise I think we've found the problem.
                                        Nano can use the default 115200 baudrate in MyConfig.h. The baudrate in HA config has to match. You can remove that line and hass will default to 115200.
                                        • ? Offline
                                          ? Offline
                                          A Former User
                                          no i haven't, so i have just removed the line, and restarted HA.
                                          But no luck. im still getting this.
                                              baud=baud_rate)
                                              func(filename)
                                          11.8k
                                          113.2k
