  3. Home Assistant
  4. 'Bad byte' error
'Bad byte' error
34 Posts 2 Posters 9.8k Views 2 Watching
  • ? Offline
    ? Offline
    A Former User
    okay putting
    persistence_file: 'mysensors.json'
    Will get the gateway started. but will result in a file not found. if i put the correct path in like
    persistence_file: '/var/opt/homeassistant/mysensors.json'
    i get this in the log.
    16-03-13 02:11:26 homeassistant.bootstrap: Error during setup of component mysensors
    Traceback (most recent call last):
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 105, in _setup_component
        if not component.setup(hass, config):
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 111, in setup
        port, persistence, persistence_file, version, baud_rate)
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 75, in setup_gateway
        baud=baud_rate)
      File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 277, in __init__
        persistence_file, protocol_version)
      File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 32, in __init__
        self._load_sensors()
      File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 162, in _load_sensors
        self._perform_file_action(self.persistence_file, 'load')
      File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 177, in _perform_file_action
        func(filename)
      File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 145, in _load_json
        self.sensors = json.load(file_handle, cls=MySensorsJSONDecoder)
      File "/usr/lib/python3.4/json/__init__.py", line 268, in load
        parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
      File "/usr/lib/python3.4/json/__init__.py", line 331, in loads
        return cls(**kw).decode(s)
      File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
        obj, end = self.raw_decode(s, idx=_w(s, 0).end())
      File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
        raise ValueError(errmsg("Expecting value", s, err.value)) from None
    ValueError: Expecting value: line 1 column 1 (char 0)
    • martinhjelmareM Offline
      martinhjelmare
      #22
      If you check the content of
      What does it show?
      • ? Offline
        ? Offline
        A Former User
        That's where all my configuration is. And there is a mysensors.json file present.
          martinhjelmare
          #24
          Try deleting the json file and have the full path to the json file in the config, as before. Restart hass.
          Edit: Also delete any pickle files, if any.
          • ? Offline
            ? Offline
            A Former User
            wrote on last edited by A Former User
            #25
            full path and no file, gets me
            File does not exist or is not readable: /var/opt/homeassistant/mysensors.json
            but will get me a gateway started.
              martinhjelmare
              #26
              That's fine, I think. If you check the contents of the folder again, you should see a json file again. It creates the file the first time.
              • ? Offline
                ? Offline
                A Former User
                nope no file
                  martinhjelmare
                  Oh yeah, I think it will create it when the first sensor is added.
                  Do you get the gateway started message now?
                  • ? Offline
                    ? Offline
                    A Former User
                    Yes i have the gateway started, so i should try to start a sensor to see if it will make the json. and be present in the webgui
                      martinhjelmare
                      Yes. Make sure you follow the presentation guide in the docs for mysensors on the HA web.
                      • ? Offline
                        ? Offline
                        A Former User
                        thank you so much, that seem to do the trick. the gate way was started and the sensor was add, as soon as it was turned on.
                          martinhjelmare
                          :thumbsup:
                          I'll think about updating the docs at HA web, to explain things a bit more.
                          • ? Offline
                            ? Offline
                            A Former User
                            Maybe also put in about the pyserial?
                              martinhjelmare
                              Well pyserial should be installed automatically when you run hass the first time with mysensors activated in the config. There shouldn't be a need to do that on your own.
                              Are you sure it wasn't installed for you?
