  3. Home Assistant
  4. 'Bad byte' error
'Bad byte' error
34 Posts 2 Posters 9.8k Views 2 Watching
  • martinhjelmareM Offline
    martinhjelmare
    First try to disconnect and reconnect the usb to the arduino. Start hass. Make sure you connect to the correct port after reconnecting the usb. Sometimes the arduino will change port name.
    If this doesn't help try another version of pyserial. 2.5 has been the least buggy for me. You can also try 2.7.
    • ? Offline
      ? Offline
      A Former User
      I have tried connecthing and reconnecthing multiple times. But how do I down grade to 2.5, right now I have just installed 3.0.1?
      • ? A Former User
        martinhjelmare
        @fleshfear
        pip3 install pyserial==2.5
        • ? Offline
          ? Offline
          A Former User
          now i have 2.5. But still no luck. What to do.
          • ? Offline
            ? Offline
            A Former User
            now i allso have this in my log
            16-03-12 19:45:33 mysensors.mysensors: Error decoding message from gateway, probably received partial data before connection was complete.
            • ? A Former User
              martinhjelmare
              @fleshfear
              Nothing else is accessing the serial port?
              • ? Offline
                ? Offline
                A Former User
                no that i know of. Its a virtual machine dedicated to only ha. And i have just testet if it was the virtual enviroment there was to blame. But on indigo domistic the plugin for mysensors works and can talk to the gateway.
                Im i missing something else like pyserial or?
                Is the only thing needed ha and pyserial?
                  martinhjelmare
                  Have you rebooted the machine after installing pyserial 2.5?
                  You can also check that there's no remains of other pyserial versions where the python packages are installed on your machine.
                  What distribution are you running?
                  • ? Offline
                    ? Offline
                    A Former User
                    yep have rebooted, many times after that.
                    How do i check if there are any other version installed? I could not install pyserial just like you said, i had to run a
                    pip3 uninstall pyserial
                    first.
                    it' a ubuntu 15.10
                      martinhjelmare
                      Python library files on Ubuntu are usually found in:
                      /usr/local/lib/pythonX.X/site-packages
                      • ? Offline
                        ? Offline
                        A Former User
                        ls -la /usr/local/lib/python3.4/dist-packages/
                        homeassistant/                  MarkupSafe-0.23.egg-info/       pytz-2015.7.dist-info/          vincenty/
                        homeassistant-0.15.0.dist-info/ pip/                            PyYAML-3.11.egg-info/           vincenty-0.1.3.egg-info/
                        jinja2/                         pip-8.1.0.dist-info/            requests/                       yaml/
                        Jinja2-2.8.dist-info/           pyserial_py3k-2.5.egg-info/     requests-2.9.1.dist-info/
                        markupsafe/                     pytz/                           serial/
                        • ? Offline
                          ? Offline
                          A Former User
                          also don't know if, it is related.
                          but i had this in the configuration:
                          persistence_file: 'mysensors.json'
                          But every time i started the HA, the log said it couldnt find the file. But efter i removed it, and create the new file i couldnt find. the new log have this:
                          16-03-12 22:26:47 homeassistant.bootstrap: Error during setup of component mysensors
                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 105, in _setup_component
                              if not component.setup(hass, config):
                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 111, in setup
                              port, persistence, persistence_file, version, baud_rate)
                            File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 75, in setup_gateway
                              baud=baud_rate)
                            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 277, in __init__
                              persistence_file, protocol_version)
                            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 32, in __init__
                              self._load_sensors()
                            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 162, in _load_sensors
                              self._perform_file_action(self.persistence_file, 'load')
                            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 177, in _perform_file_action
                              func(filename)
                            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 133, in _load_pickle
                              self.sensors = pickle.load(file_handle)
                          EOFError: Ran out of input
                          • ? Offline
                            ? Offline
                            A Former User
                            the new config looks like this
                            mysensors:
                              gateways:
                                - port: '/dev/ttyUSB0'
                                  baud_rate: 38400
                              debug: true
                              persistence: true
                              version: '1.5'
                              optimistic: true
                              martinhjelmare
                              Which arduino model are you using for the gateway?
                              • ? Offline
                                ? Offline
                                A Former User
                                Its a nano.
                                  martinhjelmare
                                  Did you change baudrate in MyConfig.h to 38400? Otherwise I think we've found the problem.
                                  Nano can use the default 115200 baudrate in MyConfig.h. The baudrate in HA config has to match. You can remove that line and hass will default to 115200.
                                  • ? Offline
                                    ? Offline
                                    A Former User
                                    no i haven't, so i have just removed the line, and restarted HA.
                                    But no luck. im still getting this.
                                        baud=baud_rate)
                                        func(filename)
                                    • ? Offline
                                      ? Offline
                                      A Former User
                                      okay putting
                                      Will get the gateway started. but will result in a file not found. if i put the correct path in like
                                      persistence_file: '/var/opt/homeassistant/mysensors.json'
                                      i get this in the log.
                                      16-03-13 02:11:26 homeassistant.bootstrap: Error during setup of component mysensors
                                          baud=baud_rate)
                                          func(filename)
                                        File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 145, in _load_json
                                          self.sensors = json.load(file_handle, cls=MySensorsJSONDecoder)
                                        File "/usr/lib/python3.4/json/__init__.py", line 268, in load
                                          parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
                                        File "/usr/lib/python3.4/json/__init__.py", line 331, in loads
                                          return cls(**kw).decode(s)
                                        File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
                                          obj, end = self.raw_decode(s, idx=_w(s, 0).end())
                                        File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
                                          raise ValueError(errmsg("Expecting value", s, err.value)) from None
                                      ValueError: Expecting value: line 1 column 1 (char 0)
                                        martinhjelmare
                                        #22
                                        If you check the content of
                                        What does it show?
                                        • ? Offline
                                          ? Offline
                                          A Former User
                                          That's where all my configuration is. And there is a mysensors.json file present.
