  3. Home Assistant
  4. 'Bad byte' error
'Bad byte' error
34 Posts 2 Posters 9.8k Views 2 Watching
  • ? A Former User
    Hi.
    I have justed connected my USB mysensors gateway. But im getting the 'bad byte' error. At first i didnt know that i should had installed the pyserial. But still after the install to pyserial 3.0.1. Im still getting the 'bad byte' error can some help, this is the log.
    6-03-12 01:20:43 mysensors.mysensors: Trying to connect to /dev/ttyUSB1
    16-03-12 01:20:43 mysensors.mysensors: /dev/ttyUSB1 is open...
    16-03-12 01:20:43 mysensors.mysensors: Connected to /dev/ttyUSB1
    16-03-12 01:20:46 mysensors.mysensors: Error decoding message from gateway, probably received bad byte.
    martinhjelmareM Offline
    martinhjelmare
    @fleshfear
    Hi!
    Have you tried to keep running HA after the error to see if the next message comes through alright?
    For me this error usually goes away after a restart of HA.
    • ? Offline
      ? Offline
      A Former User
      Yes now the ha have been runing all night, with the gateway connected. And the 'bad byte' error is the last thing there is logge from mysensor.
      • martinhjelmareM Offline
        martinhjelmare
        First try to disconnect and reconnect the usb to the arduino. Start hass. Make sure you connect to the correct port after reconnecting the usb. Sometimes the arduino will change port name.
        If this doesn't help try another version of pyserial. 2.5 has been the least buggy for me. You can also try 2.7.
        • ? Offline
          ? Offline
          A Former User
          I have tried connecthing and reconnecthing multiple times. But how do I down grade to 2.5, right now I have just installed 3.0.1?
          • ? A Former User
            martinhjelmare
            @fleshfear
            pip3 install pyserial==2.5
            • ? Offline
              ? Offline
              A Former User
              now i have 2.5. But still no luck. What to do.
              • ? Offline
                ? Offline
                A Former User
                now i allso have this in my log
                16-03-12 19:45:33 mysensors.mysensors: Error decoding message from gateway, probably received partial data before connection was complete.
                • ? A Former User
                  martinhjelmare
                  @fleshfear
                  Nothing else is accessing the serial port?
                  • ? Offline
                    ? Offline
                    A Former User
                    no that i know of. Its a virtual machine dedicated to only ha. And i have just testet if it was the virtual enviroment there was to blame. But on indigo domistic the plugin for mysensors works and can talk to the gateway.
                    Im i missing something else like pyserial or?
                    Is the only thing needed ha and pyserial?
                      martinhjelmare
                      Have you rebooted the machine after installing pyserial 2.5?
                      You can also check that there's no remains of other pyserial versions where the python packages are installed on your machine.
                      What distribution are you running?
                      • ? Offline
                        ? Offline
                        A Former User
                        yep have rebooted, many times after that.
                        How do i check if there are any other version installed? I could not install pyserial just like you said, i had to run a
                        pip3 uninstall pyserial
                        first.
                        it' a ubuntu 15.10
                          martinhjelmare
                          Python library files on Ubuntu are usually found in:
                          /usr/local/lib/pythonX.X/site-packages
                          • ? Offline
                            ? Offline
                            A Former User
                            ls -la /usr/local/lib/python3.4/dist-packages/
                            homeassistant/                  MarkupSafe-0.23.egg-info/       pytz-2015.7.dist-info/          vincenty/
                            homeassistant-0.15.0.dist-info/ pip/                            PyYAML-3.11.egg-info/           vincenty-0.1.3.egg-info/
                            jinja2/                         pip-8.1.0.dist-info/            requests/                       yaml/
                            Jinja2-2.8.dist-info/           pyserial_py3k-2.5.egg-info/     requests-2.9.1.dist-info/
                            markupsafe/                     pytz/                           serial/
                            • ? Offline
                              ? Offline
                              A Former User
                              also don't know if, it is related.
                              but i had this in the configuration:
                              persistence_file: 'mysensors.json'
                              But every time i started the HA, the log said it couldnt find the file. But efter i removed it, and create the new file i couldnt find. the new log have this:
                              16-03-12 22:26:47 homeassistant.bootstrap: Error during setup of component mysensors
                                File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 105, in _setup_component
                                  if not component.setup(hass, config):
                                File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 111, in setup
                                  port, persistence, persistence_file, version, baud_rate)
                                File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 75, in setup_gateway
                                  baud=baud_rate)
                                File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 277, in __init__
                                  persistence_file, protocol_version)
                                File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 32, in __init__
                                  self._load_sensors()
                                File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 162, in _load_sensors
                                  self._perform_file_action(self.persistence_file, 'load')
                                File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 177, in _perform_file_action
                                  func(filename)
                                File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 133, in _load_pickle
                                  self.sensors = pickle.load(file_handle)
                              EOFError: Ran out of input
                              • ? Offline
                                ? Offline
                                A Former User
                                the new config looks like this
                                mysensors:
                                  gateways:
                                    - port: '/dev/ttyUSB0'
                                      baud_rate: 38400
                                  debug: true
                                  persistence: true
                                  version: '1.5'
                                  optimistic: true
                                  martinhjelmare
                                  Which arduino model are you using for the gateway?
                                  • ? Offline
                                    ? Offline
                                    A Former User
                                    Its a nano.
                                      martinhjelmare
                                      Did you change baudrate in MyConfig.h to 38400? Otherwise I think we've found the problem.
                                      Nano can use the default 115200 baudrate in MyConfig.h. The baudrate in HA config has to match. You can remove that line and hass will default to 115200.
                                      • ? Offline
                                        ? Offline
                                        A Former User
                                        no i haven't, so i have just removed the line, and restarted HA.
                                        But no luck. im still getting this.
                                            baud=baud_rate)
                                            func(filename)
                                        • ? Offline
                                          ? Offline
                                          A Former User
                                          okay putting
                                          Will get the gateway started. but will result in a file not found. if i put the correct path in like
                                          persistence_file: '/var/opt/homeassistant/mysensors.json'
                                          i get this in the log.
                                          16-03-13 02:11:26 homeassistant.bootstrap: Error during setup of component mysensors
                                              baud=baud_rate)
                                              func(filename)
                                            File "/var/opt/homeassistant/lib/mysensors/mysensors.py", line 145, in _load_json
                                              self.sensors = json.load(file_handle, cls=MySensorsJSONDecoder)
                                            File "/usr/lib/python3.4/json/__init__.py", line 268, in load
                                              parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
                                            File "/usr/lib/python3.4/json/__init__.py", line 331, in loads
                                              return cls(**kw).decode(s)
                                            File "/usr/lib/python3.4/json/decoder.py", line 343, in decode
                                              obj, end = self.raw_decode(s, idx=_w(s, 0).end())
                                            File "/usr/lib/python3.4/json/decoder.py", line 361, in raw_decode
                                              raise ValueError(errmsg("Expecting value", s, err.value)) from None
                                          ValueError: Expecting value: line 1 column 1 (char 0)
