  3. Curtain Control Node.
domoticzcurtain controlmysensors node
51 Posts 15 Posters 31.1k Views 22 Watching
  • AWIA AWI
    @Tore-André-Rosander I have defined it as "Blinds Percentage" in Domoticz. This send the V_STATUS and V_PERCENTAGE messages where the node should respond to...
    0_1458557025507_upload-d16cb932-d511-433f-9488-112b68d308f4
    Tore André RosanderT
    Tore André Rosander
    @AWI THanks again for your fast replys!
    This is what i get in serial monitor when i use the "up" "down" buttons for blinds percentage in domoticz.
    This is my very first MySensor setup so it might be some error with my setup, i will have a deeper look at it later tonight.
    Starting sensor (RNNNA-, 2.0.0-beta)
    Radio init successful.
    State read: -1
    State read: -1
    send: 13-13-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
    send: 13-13-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:2.0.0-beta
    send: 13-13-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-13 s=255,c=3,t=15,pt=0,l=2,sg=0:
    read: 0-0-13 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    send: 13-13-0-0 s=1,c=0,t=5,pt=0,l=7,sg=0,st=ok:Curtain
    send: 13-13-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Curtain control 13
    send: 13-13-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    Init complete, id=13, parent=0, distance=1
    read: 0-0-13 s=1,c=1,t=29,pt=0,l=0,sg=0:
    Message - valid: 1, Unrecognized read: 0-0-13 s=1,c=1,t=30,pt=0,l=0,sg=0:
    Message - valid: 1, Unrecognized read: 0-0-13 s=1,c=1,t=29,pt=0,l=0,sg=0:
    Message - valid: 1, Unrecognized```
    AWIA 1 Reply Last reply
    • Tore André RosanderT Tore André Rosander
      State read: -1
      State read: -1
      AWIA
      AWIA
      AWI
      @Tore-André-Rosander Nothing wrong with you interpretation. I have not written this sketch as a complete S_COVER implementation. Only the V_PERCENTAGE part (not V_UP/V_DOWN). If you define it in Domoticz as "Blinds percentage" (see my previous post) it will work. Sorry for the confusion.
      Tore André RosanderT 1 Reply Last reply
      • AWIA AWI
        Tore André Rosander
        @AWI Seems like my problem is with Domoticz itselfe.
        I have the same problem as described in this post https://www.domoticz.com/forum/viewtopic.php?f=6&t=7748
          AWIA
          AWIA
          AWI
          @Tore-André-Rosander You can probably solve it by deleting the sensor in Domoticz and let the sketch present itself as S_DIMMER (and use another sensor id)
            Tore André Rosander
            Maybe its because i have not calibrated it? I dont have any pushbuttons laying around, so im gonna make one with some wires. But i see that there is two pins defined as buttons. Should i use the buttonPin1 as VCC?
            So it would look something like buttonPin1 -> buttonPin2 -> button -> gnd?
              AWIA
              AWIA
              AWI
              @Tore-André-Rosander You can ignore buttonpin2. Just connect your "button" to buttonpin1 and ground.
              • AWIA AWI
                Looks good. I am curious to see the details... jealous for the speed :runner: your curtain is moving.
                I have been working on a similar project last week. The mechanics and ´looks´ are the most difficult part for me.
                For now I have used a ´tuned´ cheap & small stepper which makes it slooow but effective ;-) The rail and mounting is standard IKEA. The pro-mini has the jModule attached. Works like a charm (/snail)!
                0_1457980545567_upload-c50fc1e9-f23e-458d-a812-62ad4bf478e0
                0_1457981153586_upload-c7064209-3900-4e4b-b335-8c88721367c0
                TheoLT
                TheoLT
                TheoL
                @AWI I'm curious where you got the rails for the curtain. I wasn't been able to find them, but stumbled on this topic.
                • TheoLT TheoL
                  AWIA
                  AWIA
                  AWI
                  @TheoL Ikea :smile:
                  TheoLT 1 Reply Last reply
                  • AWIA AWI
                    @TheoL Ikea :smile:
                    TheoLT
                    TheoLT
                    TheoL
                    @AWI Really interested in the mechanics ;-)
                    • franzelareF
                      franzelareF
                      franzelare
                      I'm currently working on a similar project, only I got started with 24V DC motors that I got from my work (left overs from a test project) These motors are very strong (way way over rated) and have a big gearbox what unfortunately makes the movement a bit slow.
                      I started off with 1 motor to move 2 curtains at the same time, but will change this to 2 motors for either side since the better half of me likes to control the curtains separately in case she only wants to close 1.
                      Next to the automation there will also be a manual control switch be hidden behind the curtains in case the node is down and I'm not at home to fix the issue...
                      all running on an ESP8266 (ESP-12e) unit to have it over WiFi and have enough io
                      Currently the test setup is working fine and I'm ordering parts to start implementing this a bit bigger in the first room. the test setup I made with some old wood 1 meter of rail and a few old rugs as curtains...
                      I use a GT2 timing belt that is commently used for 3D printers and pully's are widely available as well as the belts in different lengths (I order them on rolls of 10 meters) and attached the timing belt to a carriage that is normally to pull the curtains with a rod.
                      the motor is mounted on a bracket with currently 2 end stop switches for open and close (but will be 1 switch for open and 1 for close in the final solution)
                      resulting in driving the curtain from 1 side
                      electronics are working fine now and need to be ported to a test print and later to a real PCB design
                      • R
                        R
                        romeok01
                        wrote on last edited by romeok01
                        #31
                        Hello.
                        To my project i use stepper motor JK42HS34-0404 and driver L298N.
                        This is a wiring diagram.
                        This is a program code that I use
                        #include <AccelStepper.h>
                        #define HALFSTEP 4  // Stepper uses "Halfstep" mode
                        #define CURTAIN_CLOSED 1000 // value when closed
                        #define CURTAIN_OPEN 0 // value when open
                        // MySensors definitions
                        // Initialize message
                        // Motor pin definitions
                        #define motorPin1  3     // IN1 on the ULN2003 driver 1
                        #define motorPin2  4     // IN2 on the ULN2003 driver 1
                        #define motorPin3  5     // IN3 on the ULN2003 driver 1
                        #define motorPin4  6     // IN4 on the ULN2003 driver 1
                        // Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper with 28BYJ-48
                        AccelStepper stepper1(HALFSTEP, motorPin1, motorPin2, motorPin3, motorPin4);
                        unsigned long current_position ; // remembers current position, need to be saved in EEPROM?
                          // MySensors
                          gw.begin(); // fixed node 13
                          gw.sendSketchInfo("Curtain control 13", "1.0"); // Send the sketch version information to the gateway and Controller
                          //pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
                          gw.present(CHILD_ID, S_COVER); // Window Cover sub-type, commands: V_UP, V_DOWN, V_STOP
                          stepper1.setMaxSpeed(500.0);
                          stepper1.setAcceleration(700.0);
                          stepper1.moveTo(CURTAIN_OPEN);
                          current_position = CURTAIN_OPEN ;
                        }//--(end setup )---
                          // if message = V_UP start moving until closed
                          // if message = V_DOWN start moving back until open
                          // if message = V_STOP stop moving
                          // Test: Change direction when the stepper reaches the target position
                          gw.process(); // check if message from controller
                          if (stepper1.distanceToGo() == 0){
                            if (stepper1.currentPosition() == CURTAIN_OPEN){
                              stepper1.moveTo(CURTAIN_CLOSED);
                              Serial.println("Curtain Open, now closing");
                              gw.request(CHILD_ID, V_UP, 0); // request new values from controller
                            else{
                              Serial.println("Curtain Closed, now opening");
                              gw.request(CHILD_ID, V_DOWN, 0); // request new values from controller
                          stepper1.run();
                        // This is called when a message is received
                          // We only expect few types of messages from controller, check which
                          stepper1.moveTo(message.getInt() * CURTAIN_CLOSED/100);
                          Serial.print("Message - valid: ");
                          Serial.print(message.sensor);
                          Serial.print(" , value: % ");
                          Serial.println(message.getInt());
                          switch (message.getInt()) {
                          case 100:
                            // Curtain should be opened
                             Serial.print(", Message UP ");
                             break;
                          case 0:
                            // Curtain should be closed
                             Serial.print(", Message DOWN ");
                            break;
                          case 50:
                            // Curtain action should be stopped
                             Serial.print(", Message STOP ");
                            break;
                          default:
                            // not recognizable message
                             Serial.print(", Unrecognized ");
                        When the program I have uploaded to my mysensors, the engine still turns, one left and one to the right and did not work the button blinds in Domoticz.
                        I cant turn off my stepper motor in Domoticz.
                        https://www.youtube.com/embed/1Wc1p_9YDQQ
                        Please help me.
                        • R
                          R
                          romeok01
                          I write a program on library Stepper not AccelStepper.
                          Now is working.
                          Program code:
                          #define MY_REPEATER_FEATURE
                          #include <Stepper.h>
                          #define CURTAIN_CLOSED 1000  // wartosc gdy kurtyna zamknieta
                          #define CURTAIN_OPEN -1000         // wartosc gdy kurtyna otwarta
                          #define CHILD_ID 1
                          // definicje MySensors
                          MyMessage message(CHILD_ID, S_COVER);
                          int in1Pin = 3;
                          int in2Pin = 4;
                          int in3Pin = 5;
                          int in4Pin = 6;
                          int lastState;
                          // liczba kroków na jeden obrót
                          #define stepsPerRevolution 200
                          //ustawienie szybkości silnika
                          int motorSpeed = 40;
                          Stepper myStepper(stepsPerRevolution, in1Pin, in2Pin, in3Pin, in4Pin);
                          // ustawienie pinów jako wyjście
                            pinMode(in1Pin, OUTPUT);
                            pinMode(in2Pin, OUTPUT);
                            pinMode(in3Pin, OUTPUT);
                            pinMode(in4Pin, OUTPUT);
                          // ustawienie szybkosci silnika
                            myStepper.setSpeed(motorSpeed);
                            // Wyslanie informacji o wersji programu
                            sendSketchInfo("Program kurtyna", "1.0");
                            if (message.type==V_UP) {
                               myStepper.step(CURTAIN_OPEN);
                               // Store state in eeprom
                           if (message.type==V_DOWN) {
                               myStepper.step(CURTAIN_CLOSED);
                          I use MySensors Library 2.0
                          Youtube film
                          https://www.youtube.com/embed/gm0r2kDXrt4
                          • franzelareF
                            franzelareF
                            franzelare
                            your wiring diagram is not accessable:
                            Error (403)
                            It seems you don't belong here! You should probably sign in. Check out our Help Center and forums for help, or head back to home.
                            i use a DC motor so can't help with stepper motors, but can you share an image of how you setup your rails?
                            • R
                              R
                              romeok01
                              Now the wiring diagram should be visible.
                              • R
                                R
                                romeok01
                                I write program with AccelStepper library
                                / Enable debug prints to serial monitor
                                #include <AccelStepper.h>      //import biblioteki AccelStepper
                                #define HALFSTEP 8
                                #define CURTAIN_CLOSED 2000  // wartosc gdy kurtyna zamknieta
                                #define CURTAIN_OPEN 0       // wartosc gdy kurtyna otwarta
                                #define CHILD_ID 1
                                // Definicja pinow silnika
                                #define IN1  3     // IN1 - zielony
                                #define IN2  4     // IN2 - czarny
                                #define IN3  5     // IN3 - niebieski
                                #define IN4  6     // IN4 - czerwony
                                AccelStepper stepper1(HALFSTEP, IN1, IN2, IN3, IN4);
                                  stepper1.setMaxSpeed(200.0);
                                  stepper1.setAcceleration(1000.0);
                                  stepper1.setSpeed(200);
                                  stepper1.run();  //Start
                                    if (message.type==V_STOP) {
                                        stepper1.setCurrentPosition(0);
                                        request(CHILD_ID, V_STOP, 0); // request new values from controller
                                I use MySensors library 2.0
                                Now i working.
                                • J
                                  J
                                  jacikaas
                                  I trying to adopt the code for 28BYJ-48 stepper motor with ULN2003 driver board for roller blinds control. Code is working, but when the stepper motor is always on - it gets hot. Because of it also its consumes more energy. So thats why I want to turn on ULN2003 board only when new action is started, and after that it should be shuted down again. I could do it, because ULN2003 has On/Off jumper:
                                  Question #1: I trying to use relay for that On/Off. Could I do it without relay and control On/Off jumper directly from arduino? Does relay is the best solution?
                                  Question #2: I suck at programming, but I trying to add theese lines to my code to control the relay SIL05-1A72-71D, which controls the ULN2003 driver board:
                                  int powerPin = 7; //before SETUP
                                  pinMode(powerPin, OUTPUT); // In SETUP
                                  digitalWrite(powerPin, LOW); // In SETUP
                                  digitalWrite(powerPin, HIGH); // In void receive function
                                  delay(CURTAIN_CLOSED); // In void receive function
                                  digitalWrite(powerPin, LOW); // In void receive function
                                  digitalWrite(powerPin, HIGH); - I think is in right position, but I don't know how to turn off relay when action is done. Please advise for coding, because I not good in it. Thank You! Below is the code:
                                  #define MY_NODE_ID 10
                                  //#define MY_REPEATER_FEATURE
                                  #define HALFSTEP 8
                                  #define CURTAIN_CLOSED 10000  // wartosc gdy kurtyna zamknieta
                                  #define CHILD_ID 1
                                  int powerPin = 7;
                                  AccelStepper stepper1(HALFSTEP, IN1, IN3, IN2, IN4);
                                    stepper1.setMaxSpeed(1000.0);
                                    stepper1.setAcceleration(100.0);
                                    sendSketchInfo("Roller blinds", "1.0");
                                   //   delay(CURTAIN_CLOSED);
                                   //   digitalWrite(powerPin, LOW);
                                  Suresh MaliS 1 Reply Last reply
                                  • J jacikaas
                                    #define HALFSTEP 8
                                    #define CHILD_ID 1
                                    int powerPin = 7;
                                    Suresh MaliS
                                    Suresh MaliS
                                    Suresh Mali
                                    @jacikaas said in Curtain Control Node.:
                                    You can enable and disable outputs and try. In the following function:
                                    //add the following at the begining of the function
                                    stepper1.enableOutputs ()
                                    //and add the following at the end in the same function.
                                    stepper1.disableOutputs ()
                                    I hope this helps haven't tried it myself.
                                    J 1 Reply Last reply
                                    • Suresh MaliS Suresh Mali
                                      J
                                      J
                                      jacikaas
                                      @suresh-mali Thank You Suresh for Your answer!
                                      I disconnect relay and delete it lines from the code.
                                      I add lines to code like You said:
                                      stepper1.enableOutputs ();
                                       // rest of code
                                      stepper1.disableOutputs ();
                                      It looks like it have to work because it is simple solution, but it doesn't... On driver board ULN2003, when motor is not rotating, A Led is always on. I think if command with disableOutputs would be activated, then the LED should not be on?
                                      • J jacikaas
                                         // rest of code
                                        Suresh MaliS
                                        Suresh MaliS
                                        Suresh Mali
                                        wrote on last edited by Suresh Mali
                                        #39
                                        @jacikaas Ok.
                                        //Remove this line from loop function
                                        stepper1.run();
                                        //Change this line
                                        //to
                                        stepper1.runToPosition(CURTAIN_CLOSED);
                                        I hope this works. Also make similar changes in block which closes curtains.
                                        Refernce article: https://www.pjrc.com/teensy/td_libs_AccelStepper.html
                                        • J
                                          J
                                          jacikaas
                                          @suresh-mali
                                          I now reading about that funktions in http://www.airspayce.com/mikem/arduino/AccelStepper/classAccelStepper.html#a344f58fef8cc34ac5aa75ba4b665d21c
                                          Did what You said, but getting error: no matching function for call to 'AccelStepper::runToPosition(int)'
                                          I paste here all code, but I think I did everything without mistakes:
                                          #define HALFSTEP 8
                                          #define CHILD_ID 1
                                          // int powerPin = 7;
                                            //stepper1.run();  //Start
                                          skywatchS 1 Reply Last reply
