  3. PiDome
  4. PiDome Domotica/Home Automation
Scheduled Pinned Locked Moved PiDome
controllerserialgatewayraspberrymqttpidome
199 Posts 17 Posters 146.1k Views 5 Watching
  • JohnJ
    JohnJ
    John
    Would you by accident also have the vid and pid from this device?
    • A
      A
      Arielpod
      This post is deleted!
      • A
        A
        Arielpod
        wrote on last edited by Arielpod
        #63
        I'll check that when I get home.
        • JohnJ
          JohnJ
          John
          That would be cool, it then could be included as a default "considered good and save to use" device if it performs as it should. The interface will also be added though, but in a later stage
          • A
            A
            Arielpod
            Ok, it's 1a86:7523
            JohnJ 1 Reply Last reply
            • JohnJ
              JohnJ
              John
              Thanks, i will add this one to the safe list (for the time being). I will notify you when it is available.
              • A Arielpod
                Ok, it's 1a86:7523
                JohnJ
                JohnJ
                John
                @Arielpod said:
                Ok, it's 1a86:7523
                I have included the mentioned device in the latest build. I do have to say that this is a quick build for testing purposes so some functionalities may be broken.
                The build for now is only available on the build server at: http://builder.pidome.org/job/PiDome Server platform snapshot build/lastSuccessfulBuild/
                This build does require a clean installation though, but is update safe so when newer builds are available you won't loose any data.
                • A
                  A
                  Arielpod
                  #68
                  I'm not quite sure what you meant by "clean installation" but I just removed the directory of the previous installation and downloaded the one you've given the link to. Every time I connect the device I get an error:
                  • JohnJ
                    JohnJ
                    John
                    Resolved on the build server and available in the link posted above.
                    • A
                      A
                      Arielpod
                      Great, it's working! Thanks a lot.
                      • J
                        J
                        jonnyfishman
                        Hi, looking for some advice on connecting sensor to PiDome. Think I've followed the instructions correctly but when connecting sensor under 'Devices' I get this message 'New device: Possible new address: 1 if not occupied before adding (Restart node after assigning).' and nothing to choose.
                        My custom device settings are as follows with the Arduino CHILD_ID set to 1. Is there something obvious I've missed or is S_MOTION not included yet?
                        Thanks, Jon
                        • JohnJ
                          JohnJ
                          John
                          @jonnyfishman
                          If you use S_MOTION in the Arduino code then the group id should be 1 and the data control should correspond with the V_ value used in the Arduino code.
                          With the motion detection you can use the boolean data type (the integers 1 and 0 will be correctly handled). This will make it easier in triggers and automation rules where you can select "true" or "false" from a drop down instead of filling in the 1 or 0.
                          By clicking on the "Add sensor node" you will get a popup where you can choose the device created in the device editor.
                          • J
                            J
                            jonnyfishman
                            Thanks for the reply. I have checked the settings and changed the Group ID to 1 and the Data field ID to V_TRIPPED, using the Boolean option.
                            The problem I have is that when I click 'Add sensor node' I get the message 'Done (no choice of device)' and nothing is added in devices and the error log shows the following:
                            10-10-2014 21:59:53 0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=4,pt=0,l=1,st=fail:1
                            10-10-2014 21:57:50 Trying assigning address '1' to a new node
                            Thanks, Jon
                            • JohnJ
                              JohnJ
                              John
                              Do you see the device back in the "New nodes presentation" with an address when you restart the node? this would mean that the node did not got it's address assigned. I have understood from @hek that the line:
                              does not say if that it has failed or succeeded.
                              The system needs a Node with an address before it can be added, the reason why there is no device selection is because of the above line can not guarantee a success or a failure. So after "Add sensor node" you have to restart the node, because only then the address is known. I should change the name of the button though to "Assign address" for making it more obvious.
                              • J
                                J
                                jonnyfishman
                                Awesome, that sorted it! Thanks. Think I was leaving to long a time (or to short) between restarting the node. Really enjoying the Server interface, the macros and automation rules are really powerful (just need to get some more nodes to really have a play).
                                I saw on one of your posts that battery monitoring is a to do, has that happened or is it still in the pipeline. Also is there a way to trigger an email as I don't have a SMS dongle (thinking I could do it with a sensor set as RelayActuator on a GPIO pin on the pi that would trigger a PHP mail function but there's probably a more efficient way to do it).
                                Sorry for all the questions...
                                • JohnJ
                                  JohnJ
                                  John
                                  Sorry for the late response, had a meeting with my (hardware) development partner in crime this weekend...
                                  Yes this still is in the pipeline, i think it has slipped between all the other work currently going on, as the same is with the email notification. You would help me a lot if you would make a feature request for the both above at: https://bitbucket.org/pidome/pidome-server/issues?status=new&status=open (via the create issue link). It is our main global to do list ;).
                                  No problem, all questions are welcome!
                                  • F
                                    F
                                    fogsvans
                                    First of all - great work with PiDome!
                                    I've been trying to create a Custom device with a color picker but I always get following message:
                                    and in appLog this appears:
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      #78
                                      Tried to use the xbmc 13 media plugin, but after enabling it, it shows up as XBMC 12 in media plugins. Also my XBMC box tells me that a version 12 client is connecting to it.
                                      Also, I noticed that it only shows "playing" state, when I'm watching a movie from local storrage. If I watch live tv, or use a streaming plugin, it seems that pidome doesn't know about it. Is this because of lack of functionality in xbmc protocol?
                                      / Thomas
                                      • JohnJ
                                        JohnJ
                                        John
                                        wrote on last edited by John
                                        #79
                                        The above both are correct, As long as the server is an Alpha version all supplied downloads are automated this also means any test build is also supplied.
                                        The color picker error is due to the fact the color picker is currently being modified to support different color schemes and color set possibilities. It was set to only accept hex parameters. This is being changed to HEX, RGB, HSB and Kelvin with color modes: HSB, HSL, CIE and RGB. So this control is currently heavily being overhauled and also in snapshot state.
                                        The functionalities of XBMC 12 and 13 regarding exposed for base XBMC 12/13 functionalities are the same. It is correct that the streams and live TV are not included yet. I have created a request at: https://bitbucket.org/pidome/pidome-server/issue/133/extend-xbmc-plugin-func to extend the features. The build server does have an updated version where correct plugin usage is shown.
                                        I do suggest to keep an eye on http://builder.pidome.org/view/Snapshot builds/job/PiDome Server platform snapshot build/ and report bugs/issues found not related to MySensors on https://bitbucket.org/pidome/pidome-server/issues?status=new&status=open
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @John
                                          I tried the "latest" snapshot (downloaded today at 20:30 CET).
                                          After starting pidome up, went to the peripherals page, I then connected the mysensors gateway (arduino nano with the default serial gateway sketch) to my raspberry. Nothing happens in pidome at all..
                                          Shouldn't it popup with something about the new peripheral that was attached?
                                          Regards
                                          Thomas
