  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 121.2k Views 58 Watching
  • AndurilA
    AndurilA
    Anduril
    @tekka I tried to upload a sketch after flashing the new bootloader to an nano. I got te this:
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4b
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x4b
    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x4b
    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4b
    avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x4b
    avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x4b
    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x4b
    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x4b
    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x4b
    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x4b
    What is going on?
    OTA update still testing. Updating for several minutes now (I thought the old bootloader and OTA update did not take that long).
    tekkaT 1 Reply Last reply
    • AndurilA Anduril
      What is going on?
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      #82
      @Anduril without additional information it's hard to troubleshoot - looks like a baud rate problem: please post logs from flashing (output when flashing bootlader), fuse settings, mysontroller log during node reboot, and other helpful information.
      • AndurilA
        AndurilA
        Anduril
        OK, I will post that information as soon as possible, today or tomorow.
        Another thing, is it possible that OTA is much faster with the old BL? It took me few 10 minutes still sending firmware updates when I decided to flash the old one and try again. With the old one it was finished in about 5min. (times are only an estimation) Also frequency of new firmware requests in MYS Controller seemed much faster with old BL than with v1.3 pre. Is that normal or bug?
        • AndurilA
          AndurilA
          Anduril
          (had to split because of too long posts not allowed)
          here the infos for troubleshooting:
          board.txt:
          nano.menu.cpu.atmega328=ATmega328
          nano.menu.cpu.atmega328.upload.maximum_size=30720
          nano.menu.cpu.atmega328.upload.maximum_data_size=2048
          nano.menu.cpu.atmega328.upload.speed=57600
          nano.menu.cpu.atmega328.bootloader.low_fuses=0xFF
          nano.menu.cpu.atmega328.bootloader.high_fuses=0xDA
          nano.menu.cpu.atmega328.bootloader.extended_fuses=0x05
          nano.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
          nano.menu.cpu.atmega328.build.mcu=atmega328p
          ## Arduino Nano w/ ATmega328 MYSBootloader
          nano.menu.cpu.MYSBLatmega328=ATmega328 MYSBootloader
          nano.menu.cpu.MYSBLatmega328.upload.maximum_size=30720
          nano.menu.cpu.MYSBLatmega328.upload.maximum_data_size=2048
          nano.menu.cpu.MYSBLatmega328.upload.speed=57600
          nano.menu.cpu.MYSBLatmega328.bootloader.low_fuses=0xFF
          nano.menu.cpu.MYSBLatmega328.bootloader.high_fuses=0xDA
          nano.menu.cpu.MYSBLatmega328.bootloader.extended_fuses=0x05
          nano.menu.cpu.MYSBLatmega328.bootloader.file=MySensors/MYSBootloaderV13pre.hex
          nano.menu.cpu.MYSBLatmega328.build.mcu=atmega328p
          ## Arduino Nano w/ ATmega328 MYSBootloaderold
          nano.menu.cpu.MYSBLoldatmega328=ATmega328 MYSBootloader old
          nano.menu.cpu.MYSBLoldatmega328.upload.maximum_size=30720
          nano.menu.cpu.MYSBLoldatmega328.upload.maximum_data_size=2048
          nano.menu.cpu.MYSBLoldatmega328.upload.speed=57600
          nano.menu.cpu.MYSBLoldatmega328.bootloader.low_fuses=0xFF
          nano.menu.cpu.MYSBLoldatmega328.bootloader.high_fuses=0xDA
          nano.menu.cpu.MYSBLoldatmega328.bootloader.extended_fuses=0x05
          nano.menu.cpu.MYSBLoldatmega328.bootloader.file=MySensors/MYSBootloader.hex
          nano.menu.cpu.MYSBLoldatmega328.build.mcu=atmega328p
          I copied the original entry for the Nano 328p and only changed bootloader files to old and new MYS Bootloader.
          During flashing there is no debug output, only "Der Bootloader wurde gebrannt" ("burning bootloader finished) when done.
          When powering node up I get these messages:
          1	10.05.2016 21:00:36	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_GATEWAY_READY	Gateway startup complete.
          2	10.05.2016 21:00:37	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_VERSION	2.0.0-beta
          3	10.05.2016 21:00:51	RX	BROADCAST	INTERNAL	C_INTERNAL	NO	I_ID_REQUEST
          4	10.05.2016 21:00:51	TX	BROADCAST	INTERNAL	C_INTERNAL	NO	I_ID_RESPONSE	3
          5	10.05.2016 21:00:55	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFF2CC30102
          6	10.05.2016 21:00:58	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFF2CC30102
          7	10.05.2016 21:01:01	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFF2CC30102
          8	10.05.2016 21:01:09	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFF2CC30102
          9	10.05.2016 21:01:13	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFF2CC30102
          10	10.05.2016 21:01:16	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFF2CC30102
          11	10.05.2016 21:01:20	TX	3	N/A	C_INTERNAL	NO	I_REBOOT	0
          12	10.05.2016 21:01:27	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFF2CC30102
          13	10.05.2016 21:01:27	TX	3	N/A	C_STREAM	NO	ST_FIRMWARE_CONFIG_RESPONSE	0A0001005000D446
          14	10.05.2016 21:01:28	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004F00
          15	10.05.2016 21:01:28	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004F00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          16	10.05.2016 21:01:28	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004E00
          17	10.05.2016 21:01:28	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004E00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          18	10.05.2016 21:01:31	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004D00
          19	10.05.2016 21:01:31	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004D00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          20	10.05.2016 21:01:35	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004C00
          21	10.05.2016 21:01:35	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004C00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          22	10.05.2016 21:01:35	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004B00
          23	10.05.2016 21:01:35	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004B00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          24	10.05.2016 21:01:36	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004A00
          25	10.05.2016 21:01:36	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004A00FFCFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          26	10.05.2016 21:01:39	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004900
          27	10.05.2016 21:01:39	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A00010049008B002097E1F30E940000F9CF0895F894
          28	10.05.2016 21:01:43	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004800
          29	10.05.2016 21:01:43	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A00010048006B010E943E020E947000C0E0D0E00E94
          30	10.05.2016 21:01:43	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004700
          31	10.05.2016 21:01:43	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A00010047000F90DF91CF911F910F91089508950E94
          32	10.05.2016 21:01:47	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004600
          33	10.05.2016 21:01:47	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004600611103C01095812301C0812B8C939FBF
          34	10.05.2016 21:01:50	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004500
          35	10.05.2016 21:01:50	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004500FF1FEC55FF4FA591B4919FB7F8948C91
          36	10.05.2016 21:01:50	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004400
          37	10.05.2016 21:01:50	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A000100440021F069830E94A6016981E02FF0E0EE0F
          38	10.05.2016 21:01:54	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004300
          39	10.05.2016 21:01:54	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A00010043001491F901E057FF4F04910023C9F08823
          40	10.05.2016 21:01:57	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004200
          41	10.05.2016 21:01:57	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A000100420030E0F901E859FF4F8491F901E458FF4F
          42	10.05.2016 21:02:01	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004100
          43	10.05.2016 21:02:01	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A00010041000F931F93CF93DF931F92CDB7DEB7282F
          44	10.05.2016 21:02:05	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004000
          45	10.05.2016 21:02:05	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004000F8948C91822B8C939FBFDF91CF910895
          46	10.05.2016 21:02:05	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003F00
          47	10.05.2016 21:02:05	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001003F00322F309583238C938881822B888304C0
          48	10.05.2016 21:02:08	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003E00
          49	10.05.2016 21:02:08	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001003E008C93888182230AC0623051F4F8948C91
          50	10.05.2016 21:02:12	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003D00
          51	10.05.2016 21:02:12	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001003D00D4919FB7611108C0F8948C9120958223
          52	10.05.2016 21:02:12	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003C00
          53	10.05.2016 21:02:12	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001003C00E255FF4FA591B4918C559F4FFC01C591
          54	10.05.2016 21:02:13	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003B00
          55	10.05.2016 21:02:13	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001003B00FF4F8491882349F190E0880F991FFC01
          56	10.05.2016 21:02:16	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003A00
          57	10.05.2016 21:02:16	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001003A00DF9390E0FC01E458FF4F2491FC01E057
          58	10.05.2016 21:02:16	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003900
          59	10.05.2016 21:02:16	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A000100390003C08091B0008F7D8093B0000895CF93
          60	10.05.2016 21:02:17	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003800
          61	10.05.2016 21:02:17	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A000100380002C084B58F7D84BD08958091B0008F77
          62	10.05.2016 21:02:17	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003700
          63	10.05.2016 21:02:17	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001003700809180008F7780938000089584B58F77
          64	10.05.2016 21:02:21	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003600
          65	10.05.2016 21:02:21	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A00010036008830B9F08430D1F4809180008F7D03C0
          66	10.05.2016 21:02:24	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003500
          67	10.05.2016 21:02:24	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A000100350028F4813099F08230A1F008958730A9F0
          68	10.05.2016 21:02:24	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003400
          69	10.05.2016 21:02:24	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A00010034008081806880831092C1000895833081F0
          70	10.05.2016 21:02:28	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003300
          71	10.05.2016 21:02:28	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A00010033008460808380818260808380818E7F8083
          72	10.05.2016 21:02:29	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003200
          73	10.05.2016 21:02:29	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001003200E0EBF0E0808181608083EAE7F0E08081
          74	10.05.2016 21:02:30	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003100
          75	10.05.2016 21:02:30	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001003100808181608083E1EBF0E0808184608083
          76	10.05.2016 21:02:31	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001003000
          77	10.05.2016 21:02:31	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001003000808182608083808181608083E0E8F0E0
          78	10.05.2016 21:02:31	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001002F00
          79	10.05.2016 21:02:31	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001002F00EEE6F0E0808181608083E1E8F0E01082
          80	10.05.2016 21:02:35	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001002E00
          81	10.05.2016 21:02:35	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001002E00816084BD85B5826085BD85B5816085BD
          which seem to be working OTA update, but not very fast (about 75 messages in 1 minute). Here to MYSController debug of that period:
          10.05.2016 21:01:16	RX	3;255;4;0;0;FFFFFFFFFFFF2CC30102
          10.05.2016 21:01:16	DEBUG	Undefined firmware/type for node=3
          10.05.2016 21:01:16	INFO	BL version=258
          10.05.2016 21:01:16	INFO	No FW assigned
          10.05.2016 21:01:20	TX	3;0;3;0;13;0
          10.05.2016 21:01:20	INFO	FW "Blink" assigned to node 3
          10.05.2016 21:01:27	RX	3;255;4;0;0;FFFFFFFFFFFF2CC30102
          10.05.2016 21:01:27	CHILD	New child discovered, node id=3, child id=internal
          10.05.2016 21:01:27	DEBUG	Undefined firmware/type for node=3
          10.05.2016 21:01:27	INFO	BL version=258
          10.05.2016 21:01:27	INFO	Send FW info to node 3: type=A, version=1, blocks=0x0050, CRC=0x46D4
          10.05.2016 21:01:27	TX	3;0;4;0;1;0A0001005000D446
          10.05.2016 21:01:28	RX	3;255;4;0;2;0A0001004F00
          10.05.2016 21:01:28	DEBUG	FW update started, node id = 3
          10.05.2016 21:01:28	TX	3;255;4;0;3;0A0001004F00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          10.05.2016 21:01:28	RX	3;255;4;0;2;0A0001004E00
          10.05.2016 21:01:28	TX	3;255;4;0;3;0A0001004E00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          10.05.2016 21:01:31	RX	3;255;4;0;2;0A0001004D00
          10.05.2016 21:01:31	TX	3;255;4;0;3;0A0001004D00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          10.05.2016 21:01:35	RX	3;255;4;0;2;0A0001004C00
          10.05.2016 21:01:35	TX	3;255;4;0;3;0A0001004C00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          10.05.2016 21:01:35	RX	3;255;4;0;2;0A0001004B00
          10.05.2016 21:01:35	TX	3;255;4;0;3;0A0001004B00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          10.05.2016 21:01:36	RX	3;255;4;0;2;0A0001004A00
          10.05.2016 21:01:36	TX	3;255;4;0;3;0A0001004A00FFCFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          10.05.2016 21:01:39	RX	3;255;4;0;2;0A0001004900
          10.05.2016 21:01:39	TX	3;255;4;0;3;0A00010049008B002097E1F30E940000F9CF0895F894
          10.05.2016 21:01:43	RX	3;255;4;0;2;0A0001004800
          10.05.2016 21:01:43	TX	3;255;4;0;3;0A00010048006B010E943E020E947000C0E0D0E00E94
          10.05.2016 21:01:43	RX	3;255;4;0;2;0A0001004700
          10.05.2016 21:01:43	TX	3;255;4;0;3;0A00010047000F90DF91CF911F910F91089508950E94
          10.05.2016 21:01:47	RX	3;255;4;0;2;0A0001004600
          10.05.2016 21:01:47	TX	3;255;4;0;3;0A0001004600611103C01095812301C0812B8C939FBF
          10.05.2016 21:01:50	RX	3;255;4;0;2;0A0001004500
          10.05.2016 21:01:50	TX	3;255;4;0;3;0A0001004500FF1FEC55FF4FA591B4919FB7F8948C91
          10.05.2016 21:01:50	RX	3;255;4;0;2;0A0001004400
          10.05.2016 21:01:50	TX	3;255;4;0;3;0A000100440021F069830E94A6016981E02FF0E0EE0F
          10.05.2016 21:01:54	RX	3;255;4;0;2;0A0001004300
          10.05.2016 21:01:54	TX	3;255;4;0;3;0A00010043001491F901E057FF4F04910023C9F08823
          10.05.2016 21:01:57	RX	3;255;4;0;2;0A0001004200
          10.05.2016 21:01:57	TX	3;255;4;0;3;0A000100420030E0F901E859FF4F8491F901E458FF4F
          10.05.2016 21:02:01	RX	3;255;4;0;2;0A0001004100
          10.05.2016 21:02:01	TX	3;255;4;0;3;0A00010041000F931F93CF93DF931F92CDB7DEB7282F
          10.05.2016 21:02:05	RX	3;255;4;0;2;0A0001004000
          10.05.2016 21:02:05	TX	3;255;4;0;3;0A0001004000F8948C91822B8C939FBFDF91CF910895
          10.05.2016 21:02:05	RX	3;255;4;0;2;0A0001003F00
          10.05.2016 21:02:05	TX	3;255;4;0;3;0A0001003F00322F309583238C938881822B888304C0
          10.05.2016 21:02:08	RX	3;255;4;0;2;0A0001003E00
          10.05.2016 21:02:08	TX	3;255;4;0;3;0A0001003E008C93888182230AC0623051F4F8948C91
          10.05.2016 21:02:12	RX	3;255;4;0;2;0A0001003D00
          10.05.2016 21:02:12	TX	3;255;4;0;3;0A0001003D00D4919FB7611108C0F8948C9120958223
          10.05.2016 21:02:12	RX	3;255;4;0;2;0A0001003C00
          10.05.2016 21:02:12	TX	3;255;4;0;3;0A0001003C00E255FF4FA591B4918C559F4FFC01C591
          10.05.2016 21:02:13	RX	3;255;4;0;2;0A0001003B00
          10.05.2016 21:02:13	TX	3;255;4;0;3;0A0001003B00FF4F8491882349F190E0880F991FFC01
          10.05.2016 21:02:16	RX	3;255;4;0;2;0A0001003A00
          10.05.2016 21:02:16	TX	3;255;4;0;3;0A0001003A00DF9390E0FC01E458FF4F2491FC01E057
          10.05.2016 21:02:16	RX	3;255;4;0;2;0A0001003900
          10.05.2016 21:02:16	TX	3;255;4;0;3;0A000100390003C08091B0008F7D8093B0000895CF93
          10.05.2016 21:02:17	RX	3;255;4;0;2;0A0001003800
          10.05.2016 21:02:17	TX	3;255;4;0;3;0A000100380002C084B58F7D84BD08958091B0008F77
          10.05.2016 21:02:17	RX	3;255;4;0;2;0A0001003700
          10.05.2016 21:02:17	TX	3;255;4;0;3;0A0001003700809180008F7780938000089584B58F77
          10.05.2016 21:02:21	RX	3;255;4;0;2;0A0001003600
          10.05.2016 21:02:21	TX	3;255;4;0;3;0A00010036008830B9F08430D1F4809180008F7D03C0
          10.05.2016 21:02:24	RX	3;255;4;0;2;0A0001003500
          10.05.2016 21:02:24	TX	3;255;4;0;3;0A000100350028F4813099F08230A1F008958730A9F0
          10.05.2016 21:02:24	RX	3;255;4;0;2;0A0001003400
          10.05.2016 21:02:24	TX	3;255;4;0;3;0A00010034008081806880831092C1000895833081F0
          10.05.2016 21:02:28	RX	3;255;4;0;2;0A0001003300
          10.05.2016 21:02:28	TX	3;255;4;0;3;0A00010033008460808380818260808380818E7F8083
          10.05.2016 21:02:29	RX	3;255;4;0;2;0A0001003200
          10.05.2016 21:02:29	TX	3;255;4;0;3;0A0001003200E0EBF0E0808181608083EAE7F0E08081
          10.05.2016 21:02:30	RX	3;255;4;0;2;0A0001003100
          10.05.2016 21:02:30	TX	3;255;4;0;3;0A0001003100808181608083E1EBF0E0808184608083
          10.05.2016 21:02:31	RX	3;255;4;0;2;0A0001003000
          10.05.2016 21:02:31	TX	3;255;4;0;3;0A0001003000808182608083808181608083E0E8F0E0
          10.05.2016 21:02:31	RX	3;255;4;0;2;0A0001002F00
          10.05.2016 21:02:31	TX	3;255;4;0;3;0A0001002F00EEE6F0E0808181608083E1E8F0E01082
          10.05.2016 21:02:35	RX	3;255;4;0;2;0A0001002E00
          10.05.2016 21:02:35	TX	3;255;4;0;3;0A0001002E00816084BD85B5826085BD85B5816085BD
          • AndurilA
            AndurilA
            Anduril
            When uploading standard BlinkWithoutDelay sketch I get this:
            C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Mat\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Mat\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Mat\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=MYSBLatmega328 -ide-version=10607 -build-path "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files (x86)\Arduino\examples\02.Digital\BlinkWithoutDelay\BlinkWithoutDelay.ino"
            C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Mat\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Mat\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Mat\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=MYSBLatmega328 -ide-version=10607 -build-path "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files (x86)\Arduino\examples\02.Digital\BlinkWithoutDelay\BlinkWithoutDelay.ino"
            WARNUNG: Kategorie '' in der Bibliothek UIPEthernet ist ungültig und wird auf 'Uncategorized' festgelegt
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\sketch\BlinkWithoutDelay.ino.cpp" -o "nul"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\sketch\BlinkWithoutDelay.ino.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
            "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino5/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\sketch\BlinkWithoutDelay.ino.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\sketch\BlinkWithoutDelay.ino.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.S" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_pulse.S.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\WInterrupts.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WInterrupts.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\hooks.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\hooks.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_analog.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_analog.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_digital.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_digital.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_pulse.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_shift.c" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_shift.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\CDC.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\CDC.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial0.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial0.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial1.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial1.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial2.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial2.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\HardwareSerial3.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial3.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\IPAddress.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\IPAddress.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\PluggableUSB.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\PluggableUSB.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\Print.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Print.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\Stream.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Stream.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\Tone.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Tone.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\USBCore.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\USBCore.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\WMath.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WMath.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\WString.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WString.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\abi.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\abi.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\main.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\main.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\new.cpp" -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\new.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_pulse.S.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WInterrupts.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\hooks.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_analog.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_digital.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_pulse.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\wiring_shift.c.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\CDC.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial0.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial1.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial2.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\HardwareSerial3.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\IPAddress.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\PluggableUSB.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Print.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Stream.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\Tone.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\USBCore.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WMath.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\WString.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\abi.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\main.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-ar" rcs  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\core.a" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\core\new.cpp.o"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.elf" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp\sketch\BlinkWithoutDelay.ino.cpp.o" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/core\core.a" "-LC:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp" -lm
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.elf" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.eep"
            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.elf" "C:\Users\Mat\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.hex"
            Der Sketch verwendet 1.006 Bytes (3%) des Programmspeicherplatzes. Das Maximum sind 30.720 Bytes.
            Globale Variablen verwenden 15 Bytes (0%) des dynamischen Speichers, 2.033 Bytes für lokale Variablen verbleiben. Das Maximum sind 2.048 Bytes.
            I noticed that the baudrate in my boards.txt was not set to 115200 as in your guide. I changed this and reburned the bootloader, still the same result.
            With the old bootloader flashing works the same way. When powered up the log is as normal:
            82	10.05.2016 21:11:11	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_GATEWAY_READY	Gateway startup complete.
            83	10.05.2016 21:11:12	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_VERSION	2.0.0-beta
            84	10.05.2016 21:11:28	RX	BROADCAST	INTERNAL	C_INTERNAL	NO	I_ID_REQUEST
            85	10.05.2016 21:11:28	TX	BROADCAST	INTERNAL	C_INTERNAL	NO	I_ID_RESPONSE	3
            86	10.05.2016 21:11:28	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFFFFFF0101
            87	10.05.2016 21:11:30	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFFFFFF0101
            88	10.05.2016 21:11:32	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFFFFFF0101
            89	10.05.2016 21:11:34	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFFFFFF0101
            90	10.05.2016 21:11:36	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFFFFFF0101
            91	10.05.2016 21:11:37	TX	3	N/A	C_INTERNAL	NO	I_REBOOT	0
            92	10.05.2016 21:11:41	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	FFFFFFFFFFFFFFFF0101
            93	10.05.2016 21:11:41	TX	3	N/A	C_STREAM	NO	ST_FIRMWARE_CONFIG_RESPONSE	0A0001005000D446
            94	10.05.2016 21:11:42	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004F00
            95	10.05.2016 21:11:42	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004F00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            96	10.05.2016 21:11:42	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004E00
            97	10.05.2016 21:11:42	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004E00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            98	10.05.2016 21:11:42	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001004D00
            99	10.05.2016 21:11:42	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A0001004D00FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
            250	10.05.2016 21:12:21	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001000200
            251	10.05.2016 21:12:21	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A00010002000C946E000C946E000C946E000C946E00
            252	10.05.2016 21:12:21	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001000100
            253	10.05.2016 21:12:21	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A00010001000C946E000C946E000C946E000C946E00
            254	10.05.2016 21:12:22	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_REQUEST	0A0001000000
            255	10.05.2016 21:12:22	TX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_RESPONSE	0A00010000000C945C000C946E000C946E000C946E00
            256	10.05.2016 21:12:23	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	0A0001005000D4460101
            257	10.05.2016 21:12:23	TX	3	N/A	C_STREAM	NO	ST_FIRMWARE_CONFIG_RESPONSE	0A0001005000D446
            258	10.05.2016 21:12:43	RX	3	INTERNAL	C_STREAM	NO	ST_FIRMWARE_CONFIG_REQUEST	0A0001005000D4460101
            259	10.05.2016 21:12:43	TX	3	N/A	C_STREAM	NO	ST_FIRMWARE_CONFIG_RESPONSE	0A0001005000D446
            with all messages transfered in about 40s (about 150 messages, ~3 times faster)
            Hope this helps to find the problem. If you need more information just let me know.
            • AndurilA Anduril
              tekkaT
              tekkaT
              tekka
              @Anduril Is your nano running at 16 or 8Mhz? Also, is the node next to the GW or is a repeater in between?
              • AndurilA
                AndurilA
                Anduril
                @tekka I only copied the standard fuses (no 1/8 divider) and I think it is running on 16Mhz. Might be good to try with different baudrate for the 8Mhz version.
                But still, do you know why the OTA transfer is slower by a factor of 3?
                The sketch for my current project is quite big and needs several minutes to transfer. With serial upload working this would be much faster, but I have to unplug the nano from the circuit to reach the usb port. So fast OTA upload would be best.
                • D
                  D
                  Dirk_H
                  @Anduril I had problems with 8MHz with 3,3V and 115200kBPS. I only use 38400kBPS with my 8MHz nodes. (Of cause your Bootloader must also be set to the same Baudrate as specified in the board.txt, they must match, i.e. you cannot just change the Boards.txt and have another Baudrate for programming.)
                  I'm not sure if @tekka is providing a Bootloader hex file with 38400kBPS and 8MHz. From his first post I'm assuming he ueses a 57600kBPS with 8MHz. This might also work, however 57600kBPS with 8MHz introduces a baud rate error of 3.5% which sometimes causes problems with my PC/FTDI Dongle. So I personally use 38400kBPS which only has 0.2% Error: http://wormfood.net/avrbaudcalc.php (fosc=8MHz)
                  • pebri86P
                    pebri86P
                    pebri86
                    Hi. @tekka thanks for your works, OTA fw updates works very well (using MYSBootloader 1.3pre), but i've one question, after OTA updates successful and node running the sketch without error, how to update the fw using new ones? e.g an updated version of the sketch.
                    I'm using MyController.org for controller by @jkandasa . So I ask to both of you.
                    thanks.
                    • AndurilA Anduril
                      tekkaT
                      tekkaT
                      tekka
                      #90
                      @Anduril a factor 3 slower is a bit surprizing, in my hands the new bootloader performs even better than the old one. Do you have a repeater in between or are GW and the node close together? As @Dirk_H pointed out, the current .hex was compiled for 16Mhz (and is also compatible with 8Mhz) but I
                      will prepare a separate 8Mhz version and 38.4kBaud for testing.
                      AndurilA 1 Reply Last reply
                      • ErrKE
                        ErrKE
                        ErrK
                        I have just started to update all my nodes to 2.0.0 dev.
                        Started to update my serial gateway then update MYSController to 1.0.0beta and use the bootloader MYSBootloaderV13pre.hex
                        First i could't burn the bootloader to my Arduino Pro Mini 5v, needed to changed the values in board.txt:
                        From this:
                        proMYSBL16.bootloader.low_fuses=0xFF
                        proMYSBL16.bootloader.high_fuses=0xD2
                        proMYSBL16.bootloader.lock_bits=0x3F
                        To this:
                        proMYSBL16.bootloader.low_fuses=0xF7
                        proMYSBL16.bootloader.high_fuses=0xDA
                        proMYSBL16.bootloader.lock_bits=0x0F
                        It took about 50min to use OTA to upload a simple sketch for a humidity sensor with MYSController.
                        I have the gateway and the sensor very close (about 10cm from each other).
                        • ErrKE ErrK
                          From this:
                          To this:
                          tekkaT
                          tekkaT
                          tekka
                          @ErrK Fuses have to be adjusted according to HW specifications, e.g. crystal vs. internal RC oscillator settings etc. Your new high fuse (clearing EESAVE) cleared the node settings in the eeprom after flashing the new bootloader (did you use your node as GW before?). 10cm between node and GW is far too close causing radio interferences - you may get better results by moving them further away.
                          ErrKE 1 Reply Last reply
                          • tekkaT tekka
                            ErrKE
                            ErrKE
                            ErrK
                            @tekka Thanks. It's working when i move them further away.
                            • tekkaT tekka
                              AndurilA
                              AndurilA
                              Anduril
                              @tekka did some testing again. I don't have a repeater inbetween, but maybe they were to close to each other (~30cm).
                              I repeated the tests a few times:
                              when on my desk the new bootloader is significantly slower than the old one.
                              When 2m away I don't see many messages arriving. Maybe my power suply used when not at my pc was not stable enough to give the current for sending with pa-lna. I will repeat the tests with a improved setup the next days.
                              Can I give you specific information where the problem is? Maybe a special log or anything else to help find the problem?
                              • AndurilA Anduril
                                tekkaT
                                tekkaT
                                tekka
                                @Anduril hmm...I'm not experiencing any speed issues with the new bootloader. Can you activate debug on your GW and post the log while running OTA updates?
                                • AndurilA
                                  AndurilA
                                  Anduril
                                  @tekka here the serial monitor while OTA upload with #define MY_DEBUG
                                  0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                                  0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102
                                  0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5
                                  0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5
                                  0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0
                                  0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                                  0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=ok:0
                                  0;255;3;0;9;read: 3-3-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=15,pt=0,l=2,sg=0,st=fail:
                                  0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706
                                  0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                  0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                  • AndurilA Anduril
                                    tekkaT
                                    tekkaT
                                    tekka
                                    #97
                                    @Anduril There are some communication issues here, i.e. the node radio doesn't not appear to receive msgs. If you put GW and node further away, different position, away from interference sources (wifi, speaker, monitor, etc.) do you see any improvements? Also you should try with different radios, larger caps, decoupling caps, stable PSU or batteries. What type of nRF24 are you using? Genuine, Clones (blob-version?).
                                    • AndurilA
                                      AndurilA
                                      Anduril
                                      @tekka I tried a few combinations: different positions (nearest ~20cm, farest ~5m with walls), radios (probably clones, but no blobs, nRF from mysensors store and others, also pa+lna for gateway) and different caps with no success. Still quite a lot of packages lost during transmision.
                                      I then reflashed the old bootloader again and it worked flawless for 5m and 20cm.
                                      • AndurilA Anduril
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Anduril Can you re-test this version of MYSBootloader (16Mhz, CH76, 250kbp) with the most recent dev 2.0.0 version (i.e. GW), clearing EEPROM before flashing is advisable. In my setup, I get pretty decent data rates for OTA updates...
                                        • tekkaT tekka
                                          AndurilA
                                          AndurilA
                                          Anduril
                                          @tekka I will test this asap (hopefully this weekend). One point for clearing EEPROM: do you know if the sketch also works on the ESP8266? Because I thought to have cleared the EEPROM and uploaded a sketch without wifi config, but it still connected to my wifi.
