  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 121.2k Views 58 Watching
  • DrJeffD
    DrJeffD
    DrJeff
    Does the gateway need the OTA firmware (flashed) written to it as well as the Nodes?
    tekkaT 1 Reply Last reply
    • n1ck1355N n1ck1355
      @tekka : do you have any clue whats wrong with my setup?
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      #42
      @n1ck1355 yes, probably there is a timing issue with serial uploads. Need to review the STK500 code. Can you confirm that OTA FW updates work fine?
      • DrJeffD DrJeff
        tekkaT
        tekkaT
        tekka
        @DrJeff No, only the nodes
        DrJeffD 1 Reply Last reply
        • tekkaT tekka
          DrJeffD
          DrJeffD
          DrJeff
          @tekka Cool thanks, can I use Arduino as ISP to program bootloader?
          • DrJeffD DrJeff
            tekkaT
            tekkaT
            tekka
            @DrJeff Yep :)
            • tekkaT tekka
              @DrJeff Yep :)
              DrJeffD
              DrJeffD
              DrJeff
              @tekka , Time to try Thanks! :)
              • n1ck1355N
                n1ck1355N
                n1ck1355
                @tekka yes ota fw updates works. Tried it with the Time fw
                • n1ck1355N
                  n1ck1355N
                  n1ck1355
                  wrote on last edited by n1ck1355
                  #48
                  @tekka i musst revert my previous post...
                  I've OTA uploaded the sketch from my first post:
                    Serial.begin(57600);
                    Serial.println("Setup Start");
                  and i connected the board over Serial with my computer. After uploading the sketch i did not noticed any output on the serial monitor in the Arduino IDE. Also checked the transfer rate.
                  However the time reporter firmware works fine.
                  • siklosiS
                    siklosiS
                    siklosi
                    Is there a way to send ota firmware to node using some cli (python or...) script? I'm using MySensors with domoticz on RPi and when flashing new firmware I usually disconnect gw from rpi plug it into notebook and send fw using MYSController. If I could just disable gw in domoticz and send fw using some script it would be great until (if) domoticz gets support for ota fw.
                    • rollercontainerR
                      rollercontainerR
                      rollercontainer
                      wrote on last edited by rollercontainer
                      #50
                      I've just tried two 3,3V Pro Minis. Flashed the 8MHz MYSBootloader without problems (Nano as ISP). After that I connected the FTDI Adapter and programmed Blink and ReadAnalogVoltage examples without error. Both didn't worked on both Pro Minis. With original Bootloaders, they work.
                      Where is my fault?
                      • rollercontainerR rollercontainer
                        Where is my fault?
                        tekkaT
                        tekkaT
                        tekka
                        #51
                        @rollercontainer You have to provide additional information such as logs, etc. for troubleshooting
                        • Thar0lT
                          Thar0lT
                          Thar0l
                          @tekka Serial not working after uploading MYSbootloader v1.3pre. ArduinoProMini 5v16Mhz. Is it normal?
                          • Thar0lT Thar0l
                            tekkaT
                            tekkaT
                            tekka
                            @Алексей-Гусаров please provide additional information such as config and logs.
                            Thar0lT 1 Reply Last reply
                            • tekkaT tekka
                              Thar0lT
                              Thar0lT
                              Thar0l
                              wrote on last edited by Thar0l
                              #54
                              @tekka
                              boards.txt:
                              ######## settings for ext XTAL 16Mhz, EESAVE, BOD1V8, no lock
                              proMYSBL16.name=ATmega328 external 16Mhz with MYSBootloader
                              proMYSBL16.upload.tool=avrdude
                              proMYSBL16.upload.protocol=arduino
                              proMYSBL16.upload.maximum_size=30720
                              proMYSBL16.upload.maximum_data_size=2048
                              proMYSBL16.upload.speed=115200
                              proMYSBL16.bootloader.tool=avrdude
                              proMYSBL16.bootloader.low_fuses=0xFF
                              proMYSBL16.bootloader.high_fuses=0xD2
                              proMYSBL16.bootloader.extended_fuses=0x06
                              proMYSBL16.bootloader.unlock_bits=0x3F
                              proMYSBL16.bootloader.lock_bits=0x3F
                              proMYSBL16.bootloader.file=MySensors/MYSBootloaderV13pre.hex
                              proMYSBL16.build.mcu=atmega328p
                              proMYSBL16.build.f_cpu=16000000L
                              proMYSBL16.build.board=AVR_UNO
                              proMYSBL16.build.core=arduino
                              proMYSBL16.build.variant=standard
                              ######## settings for 8Mhz internal clock, EESAVE, BOD1V8, no lock
                              proMYSBL8.name=ATmega328 internal 8Mhz with MYSBootloader
                              proMYSBL8.upload.tool=avrdude
                              proMYSBL8.upload.protocol=arduino
                              proMYSBL8.upload.maximum_size=30720
                              proMYSBL8.upload.maximum_data_size=2048
                              proMYSBL8.upload.speed=57600
                              proMYSBL8.bootloader.tool=avrdude
                              proMYSBL8.bootloader.low_fuses=0xE2
                              proMYSBL8.bootloader.high_fuses=0xD2
                              proMYSBL8.bootloader.extended_fuses=0x06
                              proMYSBL8.bootloader.unlock_bits=0x3F
                              proMYSBL8.bootloader.lock_bits=0x3F
                              proMYSBL8.bootloader.file=MySensors/MYSBootloaderV13pre.hex
                              proMYSBL8.build.mcu=atmega328p
                              proMYSBL8.build.f_cpu=8000000L
                              proMYSBL8.build.board=AVR_UNO
                              proMYSBL8.build.core=arduino
                              proMYSBL8.build.variant=standard
                              MyConfig.h:
                              #ifdef MY_DISABLED_SERIAL
                              #undef MY_DEBUG
                              #ifndef MY_BAUD_RATE
                              #define MY_BAUD_RATE 115200
                              //#define MY_DISABLE_REMOTE_RESET
                              //#define MY_RADIO_NRF24
                              //#define MY_RS485
                              #ifndef MY_NODE_ID
                              #define MY_NODE_ID AUTO
                              #ifndef MY_PARENT_NODE_ID
                              #define MY_PARENT_NODE_ID AUTO
                              // #define MY_REPEATER_FEATURE
                              #ifndef MY_SMART_SLEEP_WAIT_DURATION
                              #define MY_SMART_SLEEP_WAIT_DURATION 500
                              //#define MY_OTA_FIRMWARE_FEATURE
                              #ifndef MY_OTA_FLASH_SS
                              #define MY_OTA_FLASH_SS 8
                              #ifndef MY_OTA_FLASH_JDECID
                              #define MY_OTA_FLASH_JDECID 0x1F65
                              #ifndef MY_GATEWAY_MAX_RECEIVE_LENGTH
                              #define MY_GATEWAY_MAX_RECEIVE_LENGTH 100
                              #ifndef MY_GATEWAY_MAX_SEND_LENGTH
                              #define MY_GATEWAY_MAX_SEND_LENGTH 120
                              #ifndef MY_GATEWAY_MAX_CLIENTS
                              #define MY_GATEWAY_MAX_CLIENTS 1
                              //#define MY_LEDS_BLINKING_FEATURE
                              //#define MY_DEFAULT_ERR_LED x
                              //#define MY_DEFAULT_TX_LED x
                              //#define MY_DEFAULT_RX_LED x
                              #ifndef MY_INCLUSION_MODE_FEATURE
                              #undef MY_INCLUSION_BUTTON_FEATURE
                              #ifndef MY_INCLUSION_MODE_BUTTON_PIN
                              	#if defined(ARDUINO_ARCH_ESP8266)
                              		#define MY_INCLUSION_MODE_BUTTON_PIN 5
                              	#else
                              		#define MY_INCLUSION_MODE_BUTTON_PIN 3
                              #ifndef MY_INCLUSION_MODE_DURATION
                              #if defined(MY_INCLUSION_BUTTON_EXTERNAL_PULLUP)
                              #define MY_INCLUSION_BUTTON_PRESSED HIGH
                              #else
                              #define MY_INCLUSION_BUTTON_PRESSED LOW
                              //#define MY_SIGNING_ATSHA204
                              //#define MY_SIGNING_SOFT
                              //#define MY_SIGNING_REQUEST_SIGNATURES
                              #ifndef MY_VERIFICATION_TIMEOUT_MS
                              #define MY_VERIFICATION_TIMEOUT_MS 5000
                              //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
                              #ifndef MY_SIGNING_ATSHA204_PIN
                              #define MY_SIGNING_ATSHA204_PIN 17
                              #ifndef MY_SIGNING_SOFT_RANDOMSEED_PIN
                              #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
                              #ifndef MY_RS485_BAUD_RATE
                              #define MY_RS485_BAUD_RATE 9600
                              #ifndef MY_RS485_MAX_MESSAGE_LENGTH
                              #define MY_RS485_MAX_MESSAGE_LENGTH 40
                              //#define MY_RF24_ENABLE_ENCRYPTION
                              #ifndef MY_RF24_CE_PIN
                              		#define MY_RF24_CE_PIN 4
                              	#elif defined(ARDUINO_ARCH_SAMD)
                              		#define MY_RF24_CE_PIN 27
                              	#else
                              		#define MY_RF24_CE_PIN 9
                              #ifndef MY_RF24_CS_PIN
                              		#define MY_RF24_CS_PIN 15
                              		#define MY_RF24_CS_PIN 3
                              	#else
                              		#define MY_RF24_CS_PIN 10
                              #ifndef MY_RF24_PA_LEVEL
                              #ifndef MY_RF24_CHANNEL
                              #define MY_RF24_CHANNEL	76
                              #ifndef MY_RF24_DATARATE
                              #define MY_RF24_DATARATE RF24_250KBPS
                              #ifndef MY_RF24_BASE_RADIO_ID
                              #define MY_RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
                              //#define MY_SOFTSPI
                              #ifndef MY_SOFT_SPI_SCK_PIN
                              #ifndef MY_SOFT_SPI_MISO_PIN
                              #ifndef MY_SOFT_SPI_MOSI_PIN
                              #ifndef MY_RFM69_FREQUENCY
                              #define MY_RFM69_FREQUENCY   RF69_868MHZ
                              //#define MY_IS_RFM69HW
                              #ifdef MY_IS_RFM69HW
                              	#define MY_RFM69HW true
                              #else
                              	#define MY_RFM69HW false
                              #ifndef MY_RFM69_NETWORKID
                              #define MY_RFM69_NETWORKID     100
                              #ifndef MY_RF69_IRQ_PIN
                              #define MY_RF69_IRQ_PIN RF69_IRQ_PIN
                              #ifndef MY_RF69_SPI_CS
                              #define MY_RF69_SPI_CS RF69_SPI_CS
                              #ifndef MY_RF69_IRQ_NUM
                              		#define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
                              	#else
                              		#define MY_RF69_IRQ_NUM RF69_IRQ_NUM
                              //#define MY_RFM69_ENABLE_ENCRYPTION
                              //#define MY_GATEWAY_W5100
                              //#define MY_GATEWAY_ENC28J60
                              //#define MY_GATEWAY_ESP8266
                              #ifndef MY_PORT
                              #define MY_PORT 5003
                              //#define MY_USE_UDP
                              #ifndef MY_IP_RENEWAL_INTERVAL
                              #define MY_IP_RENEWAL_INTERVAL 60000
                              #ifndef MY_MAC_ADDRESS
                              //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
                              //#define MY_NODE_LOCK_FEATURE
                              #ifndef MY_NODE_UNLOCK_PIN
                              #define MY_NODE_UNLOCK_PIN 14
                              #ifndef MY_NODE_LOCK_COUNTER_MAX
                              #define MY_NODE_LOCK_COUNTER_MAX 5
                              In node scetch:
                              I have no logs from node because serial isn't working at all. Which logs should I attach?
                              • Thar0lT Thar0l
                                @tekka
                                boards.txt:
                                MyConfig.h:
                                #undef MY_DEBUG
                                //#define MY_RS485
                                #ifndef MY_NODE_ID
                                	#else
                                #else
                                	#else
                                	#else
                                #else
                                	#else
                                #ifndef MY_PORT
                                In node scetch:
                                tekkaT
                                tekkaT
                                tekka
                                #55
                                @Алексей-Гусаров I'll look into that. Seems like bootloader is not handing over to the sketch (corroborates previous reports). Can you post the OTA log (from e.g. MYSController)?
                                • tekkaT tekka
                                  Thar0lT
                                  Thar0lT
                                  Thar0l
                                  @tekka I'm using mycotroller.org instead of myscontroller. It writes that "firmware update initiated" and nothing happens.
                                  tekkaT J 2 Replies Last reply
                                  • Thar0lT Thar0l
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Алексей-Гусаров Then I highly suggest to run MYSController to log OTA traffic for troubleshooting...
                                    • tekkaT tekka
                                      Thar0lT
                                      Thar0lT
                                      Thar0l
                                      @tekka OK, I'll try to do it tomorrow.
                                      • Thar0lT Thar0l
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Алексей-Гусаров :+1:
                                        J 1 Reply Last reply
                                        • Thar0lT Thar0l
                                          J
                                          J
                                          jkandasa
                                          @Алексей-Гусаров in mycontroller.org you can get log under Status >> Resources logs. Change items per page to 500 to display more number of logs.
