  3. 💬 MyMultisensors
💬 MyMultisensors
328pmotionatsha204amulti sensorhumiditytemperaturepirambiant lightlow powercoincell
176 Posts 33 Posters 92.2k Views 35 Watching
  • bjornhallbergB
    bjornhallbergB
    bjornhallberg
    Still very much interested in buying the board with RFM69 footprint! Just saying!
    • alexsh1A
      alexsh1A
      alexsh1
      @scalz do you mind me asking where you bought PIR lens, eeprom, and most important that fancy small antenna??? Thanks
      scalzS 1 Reply Last reply
      • alexsh1A alexsh1
        scalzS
        scalzS
        wrote on last edited by scalz
        #103
        sorry to be so quiet actually :)
        I buy most of my ic at electronic suppliers like Mouser, Digikey, Arrow etc.
        • the flash is AT25DF512C-MAHN-T . But for coincells, ota+rfm69 is a bit too much power hungry, imho..
        • the small pcb antenna is ANT-868-USP but it was for fun, as a simple wire antenna works as well and is cheaper.
        • PIR and PIR lens are from aliexpress or ebay. PIR is LHI968. And fresnel type is 8120.
          An example of link for the lens:
          http://www.ebay.com/itm/10-PIECE-White-Fresnel-8120-PIR-infrared-mini-sensor-lights-small-Lenses-/142190239995?hash=item211b32e0fb:g:WsAAAOSwEHpZJnuW
        alexsh1A 1 Reply Last reply
        • scalzS scalz
          alexsh1A
          alexsh1A
          alexsh1
          @scalz Thank you. I do shopping at those sites as well if I do a large order, but delivery charge is just killing if I need to order 1-3 items.
          I am going to try 2450 with your board. It has 600mAh so I am hoping that using eeprom is fine with this coincell. Regarding 2032, I agree with you. I have a node, which consumes 5-6uA (with watchdog) and I had to disable the LED to use it with coincell. It just drains too much energy from a low capacity battery.
          Yes, simple wire would work fine, but ANT-868-USP is just looking very tidy.
          • alexsh1A
            alexsh1A
            alexsh1
            Just waiting for some components to finalise it
            • alexsh1A alexsh1
              scalzS
              scalzS
              @alexsh1
              nice assembly :+1: oshpark i guess ??
              I agree too, for PIR use, CR2450 is a minimum.
              Well, with my tinkering and some stock in case, i usually get very quickly the free shipping..
              but you can find these flash at Arrow for instance, they just need 20€ min order.
              I guess you already have those, but for example,, coincell holders etc are not really cheaper at aliexpress etc..
              Time to do some stock for stuff you need perhaps :)
              • scalzS scalz
                @alexsh1
                alexsh1A
                alexsh1A
                alexsh1
                #107
                @scalz yes, it is oshpark- I usually use them as the quality is exceptional. And typically I only need 3-4 pcbs anyway.
                Unfortunately, I do not have oven and do not use smd stencil, which means the process is very long and manual. A lot of hot air fan work under the magnifying glass, but given this is not a board with too many components, it works.
                You should get some commission from Arrow. I have just placed my order for eeprom and some parts ;))
                • Sergio RiusS
                  Sergio RiusS
                  Sergio Rius
                  wrote on last edited by Sergio Rius
                  #108
                  Good job! Looking forward for a assembled version for buying. (NRF, of course :grinning: )
                  • CarywinC
                    CarywinC
                    Carywin
                    @scalz I ordered some boards and components which are on the way, but I can't find the source code anywhere?
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      @scalz - I forgot to burn a bootloader onto a blank atmega328p tqfl. Can I burn it using your pogo pads? The only problem is that it my Adruino ISP is running at 5V. I do not have radio soldered. I am not going to damage anything connecting 5V to VCC3?
                      • scalzS
                        scalzS
                        #111
                        @alexsh1 pogopads are there for this. But SI7021, and others sensors are not 5v tolerant :grimacing: You'll need to use a regulator, and perhaps get a cheap 3v/5v programmer
                        @Carywin source code depends what you need. you can also use some examples from MySensors website. when i'll get more time (actually busy), i'll upload mine (need to check if it needs some polishing) or some examples.
                        • scalzS scalz
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @scalz I did manage with 5V. Just de-soldered SI7021 and uploaded DualOptiboot. Other components are 5V tolerant. Having said that, I recall I did upload a different bootloader at 5V to Sensebender Micro (without nrf24l01+) without damaging SI7021.
                          R22 has to be changed for 330 Ohm as 1.5k was way too dark and not visible. I like bright LEDs you know :-))
                          • scalzS
                            scalzS
                            @alexsh1 i can see the led with 1k5 :laughing: i'm using it only for debug on my side. But you're right, if you want more brightness. just be careful to not drain too much if you're using a coincell ;)
                            • scalzS scalz
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #114
                              @scalz I am with you on the battery. I completely switched it off on another node running on 2032. The node is reporting very hour and has got about 4uA consumption while sleeping. :-) Probably will stay alive for a few years. However, when debugging, I like bright LEDs.
                              By the way, I tested the node - OPT3001 and SI7021 are working fine. Cannot test LHI968 as I still do not have some resistors. I am very satisfied. The only issue is that assembling the board is very tedious - but it is compensated by its size
                              • scalzS
                                scalzS
                                #115
                                @alexsh1 i'm very glad to hear that :+1: I'll try to upload an example for PIR pinchange with my helper lib for blindtime etc asap
                                • scalzS scalz
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @scalz I know you are currently developing a similar board on SAMD. Do you have any problems with atmega328p memory? Unfortunately, with signing and a few sensors, I'm running out of memory. On your node, I can have PIR, light, temp/hum and reed. I may struggle to combine all of them under 32kb with signing. Given that I have dualoptiboot (1.5k less) for OTA, it does not help either.
                                  I can see your PIR setup is complex. What is it you are trying to achieve?
                                  • scalzS
                                    scalzS
                                    #117
                                    @alexsh1 my next board won't be for SAMD.
                                    I need to check my code and what's the compil results, i don't remember exactly. but that was tight, 90% perhaps, i usually don't want to go above..
                                    What do you mean by PIR setup is complex?
                                    • scalzS scalz
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @scalz I can see you created MyPirHelper.h - not sure what your trying to achieve. Could you explain maybe a bit more?
                                      • scalzS
                                        scalzS
                                        #119
                                        @alexsh1 this is a lib for helping to use PIR, could be integrated in nodemanager though, but i generally prefer to keep hands on my code, also because C code is usually more memory optimized.
                                        So this is for handling PIR like some controllers ic do, and pinchange, with weak functions for users functions etc.
                                        How looks my flow:
                                         * PIR Sensor State Machine
                                         * Flow : sensitivity of pir sensor for noisy environment, limits tx, power saving..
                                         * 1) NODE_SETUP  : settle for PIR_SETTLE_TIME. Then 2)
                                         * 2) PIR_START   : Wait/sleep for the first pulse. Then 3)
                                         * 3) PIR_SCAN    : If One trigger, wait/sleep for PIR_DEFAULT_PULSES during the PIR_DEFAULT_WINDOWTIME.
                                         *                  If so, the motion is validated. Then 4)
                                         *                  Else 2)
                                         * 4) PIR_CANCEL  : PIR is disabled for PIR_DEFAULT_CANCELTIME. After, this period it reports new changed state
                                         *                  If LOW, then 5)
                                         *                  Else 4)
                                         * 5) PIR_IS_BLIND: Keep PIR sensor insensitive for PIR_DEFAULT_BLINDTIME before 2)
                                        • scalzS scalz
                                          How looks my flow:
                                           *                  Else 2)
                                           *                  If LOW, then 5)
                                           *                  Else 4)
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #120
                                          @scalz this is exactly what I do not understand. For me PIR is very simple - 1 or 0, HIGH or LOW. Why treating it differently? Maybe this is very Noobs, but this is how I treat my PIRs. I may introduce 10-30 secs delay for it to settle or 30sec sleep after it has been triggered (I do not want to have extra PIR messages to my GW and controller)
