  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 165.4k Views 65 Watching
  • Nca78N Nca78
    @okos if you have the device in Domoticz it means it could run, and send data to the gateway controller.
    Did you change anything in hardware of software between the moment you added the node/sensor to Domoticz and the moment you tried to activate it ?
    Are you sure your settings for the ACK are ok ? Maybe you are not sending one in the node but waiting from one in Domoticz ? Check the "Ack" column in Domoticz and if it's true try to change it to false.
    okosO
    okosO
    okos
    Thanks for the answer :smiley: Nca78, but I do not know where to look for settings Ack.
    Please help
    Nca78N 1 Reply Last reply
    • okosO okos
      Please help
      Nca78N
      Nca78N
      @okos go to Setup menu / Hardware, then click on the "Setup" button for your MySensors gateway.
      In the top list select the node, and in the bottom you will see the sensors attached to this node, and a Ack column for each sensor. To edit the ack column just select item and you have the checkbox below the grid with update button.
      okosO 1 Reply Last reply
      • Nca78N Nca78
        okosO
        okosO
        okos
        wrote on last edited by okos
        #63
        This post is deleted!
        • Nca78N
          Nca78N
          First board soldered and tested, it runs very well, thank you for the great work @aproxx !
          Thank you @Konstantin-Kolesnichenko also for adapting the script to version 2.0.
          I just didn't dare to install the ds18b20, the tiny distance to the temp fuse pad gives me some nightmares :cold_sweat: so I prefer having no temperature sensor and put a piece of insulating tape on both sides.
          This one will go in the ceiling, but for next board I will keep the vcc pin of the NRF24 and change a bit the code to use touch sensors behind a livolo glass plate. I need some top level WAF before I can go on with the MySensorization of all the appartment :D
          0_1471537898596_SSR_Relay_Board.jpg (like the others I will not show the back side and it's ugly pieces of insulating tape :D)
          @okos did you fix your problem ? I see your deleted message.
          • Nca78N Nca78
            okosO
            okosO
            okos
            #65
            Now everything is ok.
            Nrf changed, and changed the position of the gate (it is now above - on the fridge :))
            But I have another problem
            I used the code from Konstantin Kolesnichenko (thanks), and even after the power is changing relay.
            Example:
            on relay 1
            off Relay 2
            turn off the power, and after power returning I
            on relay 2
            off Relay 1
            Why exchange ?
            • okosO okos
              Example:
              on relay 1
              off Relay 2
              on relay 2
              off Relay 1
              Why exchange ?
              Nca78N
              Nca78N
              @okos I will try to do more tests tomorrow to see if I have the same problem. I see no obvious mistake in the script that would generate this though. The only thing I see would be if you have linked your module with physical switches and they are in different position. As the script assumes that at startup the buttons are in "off" position (circuit opened).
              I think we should have this code at the end of the setup() method to initialize the oldValue and oldValue2 variables.
                // Set the initial values of oldValue/oldValue2 variables from status of physical switches
                debouncer.update();
                debouncer2.update();
                oldValue = debouncer.read();
                oldValue2 = debouncer2.read();
              • Nca78N
                Nca78N
                @okos I confirm to you that without the change in my previous message, I had a similar problem (relay 1 always on and relay 2 always off at startup). After applying the change I don't have any problem on restart, it was just an initialization problem.
                I'm making some small improvements to the sketch, I will test tomorrow and post it.
                • okosO
                  okosO
                  okos
                  Thanks Nca78, I'm waiting for a revised code
                  • Nca78N
                    Nca78N
                    this is the updated code, the list of changes at the top of the script.
                    In short :
                    • fixed initialization of hardware buttons
                    • improved debug information
                    • made temperature sensor optional (via a #define) as I think it's location on the board is not safe
                    I think the behavior of the node is fine now, it has debug for physical buttons and the script uses less program space (<12k, <8k if temp sensor is disabled: you can enable debug even with an old atmega168 pro mini :)) and less ram (514 bytes for global variables).
                    I added the temp sensor on my first board to make some tests, it's in the ceiling now in a big (10x10cm) but air-tight electric box. Both relays are switched off at the moment and I'm waiting for the temperature to stabilize, then I will try to switch the loads on and off, leave on for a long time etc etc. 28W light tube on first relay, 2x28W on the other, it should not create problem.
                     * Script for double SSR relay board by Aproxx
                     * https://www.openhardware.io/view/77/AC-DC-double-solid-state-relay-module
                     * https://forum.mysensors.org/topic/3671/ac-dc-double-solid-state-relay-module
                     * Control 2 circuits either from controller or from physical buttons connected on pins 4 & 7
                     * Optional DS18b20 is connected on pin 8
                     *  HISTORY :
                     * xx/xx/2016 original version by Aproxx
                     * 08/02/2016 upgraded to MySensors 2.0 by mr_const
                     * 08/30/2016 changes by Nca78 :
                     *        - fixed initialization of physical buttons/debouncer status
                     *        - centralized pin status change for relays in setRelayState method
                     *        - centralized debug information for state changes in one method + added debug info when changed by physical switches
                     *        - added #ifdef MY_DEBUG before each Serial.print (saves prog memory when not in debug mode) and F() macros for debug strings (saves RAM when in debug mode)
                     *        - added #define USE_TEMP_SENSOR to make temperature sensor optional (not used if line is commented)
                     *        - put back #define for repeater feature
                     *        - add #define TEMPERATURE_ROUNDING for custom temperature rounding
                    // MySensor Debug
                    //#define MY_DEBUG
                    // Enables repeater functionality (relays messages from other nodes)
                    //#define MY_REPEATER_FEATURE
                    // Comment line below if you don't want to use the temperature sensor
                    #include <Bounce2.h>
                    #define RELAY_PIN    3  // Arduino Digital I/O pin number for relay
                    #define RELAY_PIN_2  5
                    #define BUTTON_PIN   4  // Arduino Digital I/O pin number for button
                    #define BUTTON_PIN_2 7
                    #define CHILD_ID 11 // Id of the sensor child for 1st relay
                    #define CHILD_ID_2 12 // Id of the sensor child for 2nd relay
                    // Relay status
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    // Source of state change (used when printing debug information)
                    #define CHANGE_STATE_SOURCE_RADIO 0
                    #define CHANGE_STATE_SOURCE_SWITCH 1
                    // Temperature sensor definitions
                    #ifdef USE_TEMP_SENSOR
                    #include <OneWire.h>
                    #define ONE_WIRE_BUS 8
                    #define CHILD_DSB_ID 13 // Id of the sensor child for temperature sensor
                    #define TEMPERATURE_ROUNDING 10.f   // Change value to change rounding of temperature value: 10.f for 0.1°C change, 5.f for 0.2°C change, 2.f for 0.5°C change
                    Bounce debouncer = Bounce();
                    int oldValue;
                    bool state;
                    Bounce debouncer2 = Bounce();
                    int oldValue2;
                    bool state2;
                    MyMessage msg(CHILD_ID, V_LIGHT);
                    MyMessage msg2(CHILD_ID_2, V_LIGHT);
                    MyMessage msgTemp(CHILD_DSB_ID, V_TEMP);
                    OneWire oneWire(ONE_WIRE_BUS);
                    void presentation() {
                      sendSketchInfo("Double Relay & Button", "0.2");
                      present(CHILD_ID, S_LIGHT);
                      present(CHILD_ID_2, S_LIGHT);
                      present(CHILD_DSB_ID, S_TEMP);
                      sensors.begin();
                      // Setup the button
                      pinMode(BUTTON_PIN, INPUT);
                      // Activate internal pull-up
                      digitalWrite(BUTTON_PIN, HIGH);
                      // Setup the button
                      pinMode(BUTTON_PIN_2, INPUT);
                      digitalWrite(BUTTON_PIN_2, HIGH);
                      debouncer.attach(BUTTON_PIN);
                      debouncer.interval(5);
                      debouncer2.attach(BUTTON_PIN_2);
                      debouncer2.interval(5);
                      //  if this is not done the loop() will detect status change and switch the relays on or off
                      debouncer.update();
                      setRelayState(RELAY_PIN, RELAY_OFF);
                      pinMode(RELAY_PIN, OUTPUT);
                      digitalWrite(RELAY_PIN_2, RELAY_OFF);
                      pinMode(RELAY_PIN_2, OUTPUT);
                      state = loadState(CHILD_ID);
                      setRelayState(RELAY_PIN, state);
                      state2 = loadState(CHILD_ID_2);
                      setRelayState(RELAY_PIN_2, state2);
                       Example on how to asynchronously check for new messages from gw
                      static float prevTemp = 0;
                      debouncer.update();
                      // Get the update value
                      int value = debouncer.read();
                      int value2 = debouncer2.read();
                      if (value != oldValue) {
                        send(msg.set(state ? false : true), true); // Send new state and request ack back
                        // Write some debug info
                        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID, value);
                      oldValue = value;
                      if (value2 != oldValue2) {
                        send(msg2.set(state2 ? false : true), true); // Send new state and request ack back
                        printStateChangedDebug(CHANGE_STATE_SOURCE_SWITCH, CHILD_ID_2, value2);
                      oldValue2 = value2;
                      float temperature = static_cast<float>(static_cast<int>(sensors.getTempCByIndex(0) * TEMPERATURE_ROUNDING)) / TEMPERATURE_ROUNDING;
                      if (temperature != -127.00f && temperature != 85.00f && prevTemp != temperature) {
                    #ifdef MY_DEBUG
                        Serial.print("Sent temperature: ");
                        Serial.println(temperature);
                        prevTemp = temperature;
                      if (message.isAck()) {
                    #ifdef MY_DEBUG
                        Serial.println(F("This is an ack from gateway"));
                      else if (message.type == V_LIGHT && message.sensor == CHILD_ID) {
                        // Change relay state
                        state = message.getBool();
                        // Store state in eeprom
                        saveState(CHILD_ID, state);
                        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID, state);
                      else if (message.type == V_LIGHT && message.sensor == CHILD_ID_2) {
                        state2 = message.getBool();
                        saveState(CHILD_ID_2, state2);
                        printStateChangedDebug(CHANGE_STATE_SOURCE_RADIO, CHILD_ID_2, state2);
                    // Set status of a relay pin
                    void setRelayState(byte relayPin, bool value) {
                      digitalWrite(relayPin, value ? RELAY_ON : RELAY_OFF);
                    // Print debug info, centralized in one place to minimize memory usage and have only one #ifdef MY_DEBUG for all state change messages
                    void printStateChangedDebug(int source, int sensorID, bool value) {
                    #ifdef MY_DEBUG
                      Serial.print(F("Sensor value changed, source="));
                      Serial.print(source == CHANGE_STATE_SOURCE_RADIO ? F("Radio") : F("Physical switch"));
                      Serial.print(F(", Sensor="));
                      Serial.print(sensorID);
                      Serial.print(F(", New status: "));
                      Serial.println(value);
                    Z 1 Reply Last reply
                    • Nca78N
                      Nca78N
                      Temperature stabilized, but module became irresponsive. Switched on then off, it lit up but didn't appear in Domoticz log. Then after some time the power light of the arduino went off. Slow blow fuse is dead :(
                      When I power the arduino through the programmer everything is fine, so I suppose the HLK died
                      • Nca78N Nca78
                        okosO
                        okosO
                        okos
                        #71
                        @Nca78
                        You check out what's happened? My plate at the moment is working without a problem and the temperature in the box 35°C (bulb 40W)
                        But on the new board my domoticz does detect ds18b20 and I think the problem may be inaccurate soldering DS18B20 because it is a very small gap between the legs.
                        What do you think?
                        • okosO okos
                          @Nca78
                          What do you think?
                          Nca78N
                          Nca78N
                          @okos I think position of the ds18b20 is a real safety problem on this board. It's no use to put a relatively "safe" module like the HLK if we put secondary trace so close from the mains trace. Even without the ds18b20 soldered the traces are too close. I might drill the ds18b20 hole that is the closest from the main trace bigger to create some clearance.
                          But I think my problem was from faulty HLK. I put a new slow blow fuse and a new HLK, it was a pain to change it :) It's been running over 24h without problem now, didn't put a load yet.
                          • Daniel OliveiraD
                            Daniel OliveiraD
                            Daniel Oliveira
                            I would like to suggest to move the termal fuse and the varistor.
                            I would move the temp fuse to where the SB fuse is, the latter to where the varistor is. And finally the varistor to where the "My Sensors Board" inscription is.
                            This would remove the mains trace from the middle of the PCB away from the ds18b20 and the connector for the switches.
                            It would also allow to move the NRF24 and the switched connector closer to the HLK and thus further from the mains connector.
                            Best regards
                            MySensors rules my home :)
                            • Daniel OliveiraD
                              Daniel OliveiraD
                              Daniel Oliveira
                              Can someone please point me out the software used to design the PCB?
                              If I got some time I would like to try out the improvements that I've mentioned before.
                              It makes more or less 10 years the last time that I've did some PCB design with Eagle, nostalgia.... :)
                              tonnerre33T 2 Replies Last reply
                              • Daniel OliveiraD Daniel Oliveira
                                tonnerre33T
                                tonnerre33T
                                tonnerre33
                                  tonnerre33T
                                  tonnerre33T
                                  tonnerre33
                                  @Daniel-Oliveira
                                  I think it's DipTrace ;)
                                  • Nca78N
                                    Nca78N
                                    Running fine now, nearly one week with a load connected (2*28W tubes) and switching on/off without a problem.
                                    • Nca78N Nca78
                                      okosO
                                      okosO
                                      okos
                                      #78
                                      Super :smile:
                                      I solder already the third board, and I hope that the thermometer will be visible in domoticz.
                                      • Mercury69M
                                        Mercury69M
                                        Mercury69
                                        Dear All,
                                        I'm interested in build some exemplar of this beautiful project, so for that reason I ordered all the items present in Bill Of Material.
                                        I ordererd most of the item without problem, but I get in trouble in finding the "Slow Blow Fuse (250v 0.2A)", as in the link given, the 0.2A fuse is not available and in plus the seller doesn't send to Italy.
                                        For that reason I started a search in a lot of different shop, from the most knowed to the less knowed, but I'm not able to find it for a reasonable price.
                                        As example I found a Company that sell 10 of it for a total of 3.40$ but they ship it for 35$, so I think is a nonsense.
                                        Other Company only sell minimum quantity of 1000 item, but I don't need that amount and in plus the price will become very high.
                                        So for that reason I ask you if someone can suggest me an internet shop where I can find it for a reasonable price (item+shipping), or eventually if it's possible to substitute that "Slow Blow Fuse (250v 0.2A)" with different kind of fuse maybe more easy to find.
                                        Or as a last chance, if someone eventually have 10 of it and is available to send me (off course I will pay for the item and for the shipping) in Italy.
                                        Thank you in advance for your attention.
                                        AmsterA 1 Reply Last reply
                                        • Mercury69M Mercury69
                                          Dear All,
                                          AmsterA
                                          AmsterA
                                          Amster
                                          wrote on last edited by Amster
                                          #80
                                          @Mercury69
                                          See: Aliexpress Sorry these required a fuse holder :disappointed:
                                          maybe this one ? Mouser.it
