  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 170.5k Views 65 Watching
  • okosO
    okosO
    okos
    Thanks Nca78, I'm waiting for a revised code
    • Nca78N
      this is the updated code, the list of changes at the top of the script.
      In short :
      • fixed initialization of hardware buttons
      • improved debug information
      • made temperature sensor optional (via a #define) as I think it's location on the board is not safe
      I think the behavior of the node is fine now, it has debug for physical buttons and the script uses less program space (<12k, <8k if temp sensor is disabled: you can enable debug even with an old atmega168 pro mini :)) and less ram (514 bytes for global variables).
      I added the temp sensor on my first board to make some tests, it's in the ceiling now in a big (10x10cm) but air-tight electric box. Both relays are switched off at the moment and I'm waiting for the temperature to stabilize, then I will try to switch the loads on and off, leave on for a long time etc etc. 28W light tube on first relay, 2x28W on the other, it should not create problem.
       *  HISTORY :
      // MySensor Debug
      //#define MY_REPEATER_FEATURE
      #define RELAY_PIN_2  5
      #define BUTTON_PIN_2 7
      #define CHILD_ID 11 // Id of the sensor child for 1st relay
      #define CHILD_ID_2 12 // Id of the sensor child for 2nd relay
      // Relay status
      #define RELAY_ON 1
      #define RELAY_OFF 0
      #ifdef USE_TEMP_SENSOR
      #include <OneWire.h>
      #define ONE_WIRE_BUS 8
      #define TEMPERATURE_ROUNDING 10.f   // Change value to change rounding of temperature value: 10.f for 0.1°C change, 5.f for 0.2°C change, 2.f for 0.5°C change
      Bounce debouncer = Bounce();
      int oldValue;
      bool state;
      Bounce debouncer2 = Bounce();
      int oldValue2;
      bool state2;
        present(CHILD_ID, S_LIGHT);
        present(CHILD_ID_2, S_LIGHT);
        sensors.begin();
        // Setup the button
        pinMode(BUTTON_PIN, INPUT);
        // Activate internal pull-up
        // Setup the button
        pinMode(BUTTON_PIN_2, INPUT);
        debouncer.attach(BUTTON_PIN);
        debouncer.interval(5);
        debouncer2.interval(5);
        debouncer.update();
        debouncer2.update();
        oldValue = debouncer.read();
        pinMode(RELAY_PIN, OUTPUT);
        pinMode(RELAY_PIN_2, OUTPUT);
        state = loadState(CHILD_ID);
        static float prevTemp = 0;
        debouncer.update();
        // Get the update value
        int value = debouncer.read();
        if (value != oldValue) {
        oldValue = value;
        if (value2 != oldValue2) {
        oldValue2 = value2;
      #ifdef MY_DEBUG
          prevTemp = temperature;
        if (message.isAck()) {
      #ifdef MY_DEBUG
          // Change relay state
          state = message.getBool();
          // Store state in eeprom
          saveState(CHILD_ID, state);
          state2 = message.getBool();
      // Set status of a relay pin
      #ifdef MY_DEBUG
        Serial.print(F(", Sensor="));
        Serial.print(sensorID);
        Serial.println(value);
      Z 1 Reply Last reply
      • Nca78N
        Temperature stabilized, but module became irresponsive. Switched on then off, it lit up but didn't appear in Domoticz log. Then after some time the power light of the arduino went off. Slow blow fuse is dead :(
        When I power the arduino through the programmer everything is fine, so I suppose the HLK died
        okosO 1 Reply Last reply
        • Nca78N Nca78
          okosO
          okosO
          okos
          wrote on last edited by okos
          #71
          @Nca78
          You check out what's happened? My plate at the moment is working without a problem and the temperature in the box 35°C (bulb 40W)
          But on the new board my domoticz does detect ds18b20 and I think the problem may be inaccurate soldering DS18B20 because it is a very small gap between the legs.
          What do you think?
          Nca78N 1 Reply Last reply
          • okosO okos
            @Nca78
            What do you think?
            @okos I think position of the ds18b20 is a real safety problem on this board. It's no use to put a relatively "safe" module like the HLK if we put secondary trace so close from the mains trace. Even without the ds18b20 soldered the traces are too close. I might drill the ds18b20 hole that is the closest from the main trace bigger to create some clearance.
            But I think my problem was from faulty HLK. I put a new slow blow fuse and a new HLK, it was a pain to change it :) It's been running over 24h without problem now, didn't put a load yet.
            • Daniel OliveiraD
              Daniel OliveiraD
              Daniel Oliveira
              I would like to suggest to move the termal fuse and the varistor.
              I would move the temp fuse to where the SB fuse is, the latter to where the varistor is. And finally the varistor to where the "My Sensors Board" inscription is.
              This would remove the mains trace from the middle of the PCB away from the ds18b20 and the connector for the switches.
              It would also allow to move the NRF24 and the switched connector closer to the HLK and thus further from the mains connector.
              Best regards
              MySensors rules my home :)
              • Daniel OliveiraD
                Daniel OliveiraD
                Daniel Oliveira
                Can someone please point me out the software used to design the PCB?
                If I got some time I would like to try out the improvements that I've mentioned before.
                It makes more or less 10 years the last time that I've did some PCB design with Eagle, nostalgia.... :)
                tonnerre33T 2 Replies Last reply
                • Daniel OliveiraD Daniel Oliveira
                  tonnerre33T
                  tonnerre33T
                  tonnerre33
                    tonnerre33T
                    tonnerre33T
                    tonnerre33
                    @Daniel-Oliveira
                    I think it's DipTrace ;)
                    • Nca78N
                      Running fine now, nearly one week with a load connected (2*28W tubes) and switching on/off without a problem.
                      • Nca78N Nca78
                        okosO
                        okosO
                        okos
                        #78
                        Super :smile:
                        I solder already the third board, and I hope that the thermometer will be visible in domoticz.
                        • Mercury69M
                          Mercury69M
                          Mercury69
                          Dear All,
                          I'm interested in build some exemplar of this beautiful project, so for that reason I ordered all the items present in Bill Of Material.
                          I ordererd most of the item without problem, but I get in trouble in finding the "Slow Blow Fuse (250v 0.2A)", as in the link given, the 0.2A fuse is not available and in plus the seller doesn't send to Italy.
                          For that reason I started a search in a lot of different shop, from the most knowed to the less knowed, but I'm not able to find it for a reasonable price.
                          As example I found a Company that sell 10 of it for a total of 3.40$ but they ship it for 35$, so I think is a nonsense.
                          Other Company only sell minimum quantity of 1000 item, but I don't need that amount and in plus the price will become very high.
                          So for that reason I ask you if someone can suggest me an internet shop where I can find it for a reasonable price (item+shipping), or eventually if it's possible to substitute that "Slow Blow Fuse (250v 0.2A)" with different kind of fuse maybe more easy to find.
                          Or as a last chance, if someone eventually have 10 of it and is available to send me (off course I will pay for the item and for the shipping) in Italy.
                          Thank you in advance for your attention.
                          AmsterA 1 Reply Last reply
                          • Mercury69M Mercury69
                            Dear All,
                            AmsterA
                            AmsterA
                            Amster
                            wrote on last edited by Amster
                            #80
                            @Mercury69
                            See: Aliexpress Sorry these required a fuse holder :disappointed:
                            maybe this one ? Mouser.it
                            • Nca78N
                              Sorry the shop I bought mine from doesn't sell a single fuse anymore ...
                              I don't know if these fuses will fit on the board but they are the closest specced having some leads :
                              https://www.aliexpress.com/item/10-pcs-lot-T250mA-250V-TE5-Slow-Blow-Subminiature-Fuse-UL-VDE-RoHS-Approved-250mA/32712347448.html
                              I think it would be better for next revision of this board or future boards powered from main to use a fuse holder...
                              • Mercury69M
                                Mercury69M
                                Mercury69
                                Thank you to all for your rapid answer.
                                @Amster
                                I saw the fuse in Mouser website, I think the same one is the following:
                                http://www.mouser.it/ProductDetail/Littelfuse/0875200MXEP/?qs=%2Fha2pyFadugxaz6Ka1QIzhvtD8HnMnU0Sbd%2Fe9cxA257in2%2FbECi0w==
                                I also called they and they told me that only after I will put the order they check the real availability in the various site they have and if present they send me, but if not present I have to wait 10 Week as this is the Factory Lead Time.
                                And more of this the shipping will cost 20€, so a total of 39,80€ for 10 little fuse I think is too much.
                                @Nca78
                                I think I will go for the one you suggest. It's cheap, with free shipping and it seems not to big to don't fit in the board.
                                Now I will have to wait about 1 month before all parts arrive, then I will let you know if fuse will fit or not.
                                Thank you again for your attention and a big hello from Italy.
                                • mr_constM
                                  mr_constM
                                  mr_const
                                  I bought here in Ukraine circular-shaped slow-blow fuses and soldered them almost normally (here is their datasheet http://www.rcscomponents.kiev.ua/datasheets/5rt.JPG), so far everything is ok.
                                  And here is my board instance:
                                  mysensors board
                                  • jendrushJ
                                    jendrushJ
                                    jendrush
                                    Very nice project. I would like to have access to few more pins to add some functionality like motion sensor, and light sensor. Of course those would be outside of the wall :)
                                    • jendrushJ jendrush
                                      Hello, I would not advise to use this board with sensors accessible to fingers. The spacing between main voltage and low voltage traces is too narrow at some points on the board and a short circuit is possible. It is fine/safe to use only in a closed box or connected to wall switches as they are designed to be safe with main voltage.
                                      • jendrushJ
                                        jendrushJ
                                        jendrush
                                        I think that woundn't be so risky becouse o think about mounting it not behind light buttons, but in this box just below ceiling(where wires crossing their paths), this box is placed more than 2 meters above floor level.
                                          Still a bit, no ?
                                          Anyway if you have requirement for a board that would be both easy to solder and safe even outside of electrical box, can you send them to me by private message ? I'm working on such a board and I'm opened to any improvement ideas of use cases that would not be filled by currently available boards.
