  3. Registered Temperature Sensors on Mysensors, need Help
3 Posts 2 Posters 919 Views 2 Watching
  • obel38O
    obel38O
    obel38
    Hi all,
    i need help because i have just finished a node to monitor a heating system.
    Temperature sensors need to be registered to be sure of each sensor shown at the right place.
    So here is my Node program, and all sensors shown in Domoticz, but temperatures stay to 0.
    There is a mistake, but i could not find where, and why !
    Please, if someone is able to "know".
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    #include <OneWire.h>
    #include <Bounce2.h>
    #define NODE_ID 01 // or set to AUTO if you want gw to assign a NODE_ID for you.
    #define SKETCH_NAME "Chaudiere"
    #define SKETCH_VERSION "1.01"
    #define CHILD_ID100 100
    #define BUTTON_PIN1  3  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID101 101
    #define BUTTON_PIN2  4  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID102 102
    #define BUTTON_PIN3  5  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID103 103
    #define BUTTON_PIN4  6  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID104 104
    #define BUTTON_PIN5  7  // Arduino Digital I/O pin for button/reed switch
    #define CHILD_ID105 105
    #define BUTTON_PIN6  8  // Arduino Digital I/O pin for button/reed switch
    #define PRESSURE_SENSOR_ANALOG_PIN 7
    #define VANNE_SENSOR_ANALOG_PIN 6
    #define CURRENT_PAC_ANALOG_PIN 5
    #define CHILD_C10    10
    #define CHILD_C11    11 // Identification Pressostat Ballon
    #define CHILD_C12    12
    #define CHILD_C13    13
    #define CHILD_C14    14
    #define CHILD_C15    15
    #define CHILD_C16    16 // Identification vanne 3 voies
    #define CHILD_C17    17
    #define CHILD_C18    18
    #define CHILD_C19    19
    #define CHILD_C20    20 // Current P.A.C.
    Bounce debouncer = Bounce();
    int oldValue1=-1;
    int oldValue2=-1;
    int oldValue3=-1;
    int oldValue4=-1;
    int oldValue5=-1;
    int oldValue6=-1;
    #define ONE_WIRE_BUS 2 // Pin where dallas sensor is connected
    #define MAX_ATTACHED_DS18B20 10
    DallasTemperature Dallas(&oneWire); // Pass the oneWire reference to Dallas Temperature.
    #define TEMPERATURE_PRECISION 12  //The resolution of the sensor
    float lastTemperature[8];
    DeviceAddress dallasAddresses[] = {
     {0x28, 0xEB, 0xBB, 0x58, 0x4, 0x0, 0x0, 0xAA},   // C10
      {0x28, 0x71, 0x7F, 0x78, 0x4, 0x0, 0x0, 0x99}, // C12
      {0x28, 0xA, 0xC7, 0x77, 0x4, 0x0, 0x0, 0x12},   // C13
      {0x28, 0x23, 0xE, 0x78, 0x4, 0x0, 0x0, 0x79}, // C14
      {0x28, 0x58, 0x16, 0x78, 0x4, 0x0, 0x0, 0x5B},   // C15
      {0x28, 0x6B, 0x1, 0x78, 0x4, 0x0, 0x0, 0xC2}, // C17
      {0x28, 0x91, 0xC9, 0x77, 0x4, 0x0, 0x0, 0xF9},   // C18
      {0x28, 0x2F, 0xE9, 0x77, 0x4, 0x0, 0x0, 0x15}, // C19
    int numSensors=0;
    boolean metric = true;
    MyMessage msgCirc100(CHILD_ID100,V_TRIPPED), msgCirc101(CHILD_ID101,V_TRIPPED),msgCirc102(CHILD_ID102,V_TRIPPED), msgCirc103(CHILD_ID103,V_TRIPPED), msgCirc104(CHILD_ID104,V_TRIPPED), msgCirc105(CHILD_ID105,V_TRIPPED);
    MyMessage msgTempC10(CHILD_C10,V_TEMP), msgTempC12(CHILD_C12,V_TEMP),msgTempC13(CHILD_C13,V_TEMP), msgTempC14(CHILD_C14,V_TEMP),msgTempC15(CHILD_C15,V_TEMP), msgTempC17(CHILD_C17,V_TEMP),msgTempC18(CHILD_C18,V_TEMP), msgTempC19(CHILD_C19,V_TEMP);
    MyMessage msgPressure(CHILD_C11, V_PRESSURE);
    MyMessage msgVanne(CHILD_C16, V_PERCENTAGE);
    MyMessage msgCurrent(CHILD_C20, V_CURRENT);
    int lastPressureValue;
    int lastPositionValue;
    //MyMessage msg(0,V_TEMP);
      pinMode(BUTTON_PIN1,INPUT);
      pinMode(BUTTON_PIN2,INPUT);
      pinMode(BUTTON_PIN3,INPUT);
      pinMode(BUTTON_PIN4,INPUT);
      pinMode(BUTTON_PIN5,INPUT);
      pinMode(BUTTON_PIN6,INPUT);
      // Activate internal pull-Down
      digitalWrite(BUTTON_PIN1,LOW);
      digitalWrite(BUTTON_PIN2,LOW);
      digitalWrite(BUTTON_PIN3,LOW);
      digitalWrite(BUTTON_PIN4,LOW);
      digitalWrite(BUTTON_PIN5,LOW);
      digitalWrite(BUTTON_PIN6,LOW);
      debouncer.attach(BUTTON_PIN1);
      debouncer.interval(50);
      debouncer.attach(BUTTON_PIN2);
      debouncer.attach(BUTTON_PIN3);
      debouncer.attach(BUTTON_PIN4);
      debouncer.attach(BUTTON_PIN5);
      debouncer.attach(BUTTON_PIN6);
      Dallas.begin();
      Dallas.setWaitForConversion(false);
      for (uint8_t i = 0; i < 8; i++) {
        Dallas.setResolution(dallasAddresses[i], TEMPERATURE_PRECISION);
    void presentation() {
      present(CHILD_ID100, S_DOOR);
      present(CHILD_ID101, S_DOOR);
      present(CHILD_ID102, S_DOOR);
      present(CHILD_ID103, S_DOOR);
      present(CHILD_ID104, S_DOOR);
      present(CHILD_ID105, S_DOOR);
      //numSensors = sensors.getDeviceCount();
      //Serial.print ("Capteurs Trouves :");
      //Serial.println (numSensors);
      present (CHILD_C10, S_TEMP);
      present (CHILD_C11, S_CUSTOM);
      present (CHILD_C12, S_TEMP);
      present (CHILD_C13, S_TEMP);
      present (CHILD_C14, S_TEMP);
      present (CHILD_C15, S_TEMP);
      present (CHILD_C16, S_CUSTOM);
      present (CHILD_C17, S_TEMP);
      present (CHILD_C18, S_TEMP);
      present (CHILD_C19, S_TEMP);
      present (CHILD_C20, S_CUSTOM);
    //  for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
    //     present(i, S_TEMP);
    //     Serial.print("Sensor" );
    //     Serial.print(i);
    //     Serial.print (ADRESSE 18B20);
      Dallas.requestTemperatures();
      // int16_t conversionTime = Dallas.millisToWaitForConversion(Dallas.getResolution());
      // sleep(conversionTime);
      // Capteur C10
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?Dallas.getTempC(dallasAddresses[0]):Dallas.getTempF(dallasAddresses[0])) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        if (lastTemperature[0] != temperature && temperature != -127.00 && temperature != 85.00) {
        #else
          send(msgTempC10.set(temperature,1));
          Serial.print("Capteur C10 Present: ");
          Serial.println (temperature);
          lastTemperature[0]=temperature;
        // Capteur C12
        temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?Dallas.getTempC(dallasAddresses[1]):Dallas.getTempF(dallasAddresses[1])) * 10.)) / 10.;
        if (lastTemperature[1] != temperature && temperature != -127.00 && temperature != 85.00) {
        #else
          send(msgTempC12.set(temperature,1));
          Serial.print("Capteur C12 Present: ");
          lastTemperature[1]=temperature;
        // Capteur C13
        temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?Dallas.getTempC(dallasAddresses[2]):Dallas.getTempF(dallasAddresses[2])) * 10.)) / 10.;
        if (lastTemperature[2] != temperature && temperature != -127.00 && temperature != 85.00) {
        #else
          send(msgTempC13.set(temperature,1));
          Serial.print("Capteur C13 Present: ");
          lastTemperature[2]=temperature;
        // Capteur C14
        temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?Dallas.getTempC(dallasAddresses[3]):Dallas.getTempF(dallasAddresses[3])) * 10.)) / 10.;
        if (lastTemperature[3] != temperature && temperature != -127.00 && temperature != 85.00) {
        #else
          send(msgTempC14.set(temperature,1));
          Serial.print("Capteur C14 Present: ");
          lastTemperature[3]=temperature;
        // Capteur C15
        temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?Dallas.getTempC(dallasAddresses[4]):Dallas.getTempF(dallasAddresses[4])) * 10.)) / 10.;
        if (lastTemperature[4] != temperature && temperature != -127.00 && temperature != 85.00) {
        #else
          send(msgTempC15.set(temperature,1));
          Serial.print("Capteur C15 Present: ");
          lastTemperature[4]=temperature;
        // Capteur C17
        temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?Dallas.getTempC(dallasAddresses[5]):Dallas.getTempF(dallasAddresses[5])) * 10.)) / 10.;
        if (lastTemperature[5] != temperature && temperature != -127.00 && temperature != 85.00) {
        #else
          send(msgTempC17.set(temperature,1));
          Serial.print("Capteur C17 Present: ");
          lastTemperature[5]=temperature;
        // Capteur C18
        temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?Dallas.getTempC(dallasAddresses[6]):Dallas.getTempF(dallasAddresses[6])) * 10.)) / 10.;
        if (lastTemperature[6] != temperature && temperature != -127.00 && temperature != 85.00) {
        #else
          send(msgTempC18.set(temperature,1));
          Serial.print("Capteur C18 Present: ");
          lastTemperature[6]=temperature;
     // Capteur C19
        temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?Dallas.getTempC(dallasAddresses[7]):Dallas.getTempF(dallasAddresses[7])) * 10.)) / 10.;
        if (lastTemperature[7] != temperature && temperature != -127.00 && temperature != 85.00) {
        #else
          send(msgTempC19.set(temperature,1));
          Serial.print("Capteur C19 Present: ");
          lastTemperature[7]=temperature;
     debouncer.update();
     // Get the update value
     int value1 = debouncer.read();
     int value2 = debouncer.read();
     int value3 = debouncer.read();
     int value4 = debouncer.read();
     int value5 = debouncer.read();
     int value6 = debouncer.read();
     int value7 = debouncer.read();
     value1 = digitalRead(BUTTON_PIN1);
     value2 = digitalRead(BUTTON_PIN2);
     value3 = digitalRead(BUTTON_PIN3);
     value4 = digitalRead(BUTTON_PIN4);
     value5 = digitalRead(BUTTON_PIN5);
     value6 = digitalRead(BUTTON_PIN6);
     if (value1 != oldValue1) {
         // Send in the new value
         send(msgCirc100.set(value1==HIGH ? 1 : 0));
         oldValue1 = value1;
      if (value2 != oldValue2) {
         send(msgCirc101.set(value2==HIGH ? 1 : 0));
         oldValue2 = value2;
      if (value3 != oldValue3) {
         send(msgCirc102.set(value3==HIGH ? 1 : 0));
         oldValue3 = value3;
        if (value4 != oldValue4) {
         send(msgCirc103.set(value4==HIGH ? 1 : 0));
         oldValue4 = value4;
      if (value5 != oldValue5) {
         send(msgCirc104.set(value5==HIGH ? 1 : 0));
         oldValue5 = value5;
      if (value6 != oldValue6) {
         send(msgCirc105.set(value6==HIGH ? 1 : 0));
         oldValue6 = value6;
      int PressureValue = (1023-analogRead(PRESSURE_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(PressureValue);
      if (PressureValue != lastPressureValue) {
          send(msgPressure.set(PressureValue));
          lastPressureValue = PressureValue;
      int PositionValue = (1023-analogRead(VANNE_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(PositionValue);
      if (PositionValue != lastPositionValue) {
          send(msgVanne.set(PositionValue));
          lastPositionValue = PositionValue;
      int CurrentValue = (1023-analogRead(CURRENT_PAC_ANALOG_PIN))/10.23;
      Serial.println(CurrentValue);
          send(msgCurrent.set(CurrentValue));
          lastPositionValue = CurrentValue;
      sleep(SLEEP_TIME);
    • obel38O
      obel38O
      obel38
      Another information,
      i am sure of the wiring and sensors connections, i tried with a normal sketch for Arduino, and every sensor is working fine
      Thanks for help
        You could probably simplify this sketch a bit...
        Look in the debug log and check it sends any temp data...
        If not, add debug in some locations until you find the problem. For instance what temp value you actually get when reading it from the dallas sensor.
