  3. DHT11 and a RELAY combinaison problem
4 Posts 2 Posters 2.0k Views 2 Watching
  • mikeadresseM Offline
    mikeadresse
    I need a good kick , i try to make working a DHT 11 with a Relay.
    I have veraedge with ethernet gateway working for ''simple'' sensor,
    No problem with 1X sensor...
    but when i try to put 2 togethers no succes...
    Could somebody ''educate'' me please!
    this my code:
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define HUMIDITY_SENSOR_DIGITAL_PIN 2
    #define RELAY_1 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    gw.begin();
    gw.sendSketchInfo("Humidity", "1.0");
    // gw.sendSketchInfo("Relay", "1.0");
    // Fetch relay status
    gw.present(sensor, S_LIGHT);
    pinMode(pin, OUTPUT);
    // Set relay
    digitalWrite(pin,HIGH);
    if (isnan(temperature)) {
    lastTemp = temperature;
    if (!metric) {
    Serial.print("T: ");
    Serial.println(temperature);
    if (isnan(humidity)) {
    lastHum = humidity;
    Serial.print("H: ");
    Serial.println(humidity);
    // gw.sleep(SLEEP_TIME); //sleep a bit
    if (message.type==V_LIGHT) {
    // Change relay state
    // Store state in eeprom
    // Write some debug info
    Serial.print(message.sensor);
    HERE THE DEBUG CODE:
    send: 13-13-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 13-13-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
    send: 13-13-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-13 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    sensor started, id=13, parent=0, distance=1
    send: 13-13-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:Humidity
    send: 13-13-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    send: 13-13-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
    send: 13-13-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 13-13-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.4
    repeater started, id=13, parent=0, distance=1
    send: 13-13-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    send: 13-13-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:23.0
    T: 23.00
    send: 13-13-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:35.0
    H: 35.00
    I have tried with: // gw.sendSketchInfo("Relay", "1.0"); (activated and not)
    Like i said everything is ok with one sensor... Thanks Mike
      mikeadresse
      Hi, again,
      -Before posting i went threw all the forum and also the debug FAQ
      -Spent many hourssss before asking....
      -Got serialgateway+ethernetgateway+onewire+dht11+relay+motion sensor :Working!
      -i have relay + sensor problem, small lack of knowledge here ...
      -Problem is my Veraedge with 1.5 release dont find the Relay...
      -I have tried to ''restore'' my library, but like i wrote 1X sensor is working but not both...
      -Radio have an electrolytic capacitor and working good.
      -supply for the radio is ok too... not coming from the nano...
      -and sketch upload as unique sensor is working for both relay and dht11 when alone...
      I have a problem in the ''setup'' for sure,
      i need a kick in my...
      Tried a lot of different things with the same issue: Veraedge dont find one part of the sensor : Could be temperature or relay...But always find Humidity...
      Please a clue ...
      Mike
      • N Offline
        N Offline
        Nuubi
        I think this is the way to go and learn:
        http://forum.mysensors.org/topic/2597/combining-mysensors-examples
          mikeadresse
          Thanks Nuubi ! For pointing this link! :smiley: :+1:
          '''Cent fois sur le métier remettez votre ouvrage!''' :sweat:
          Because you pointed it to me, i had to go back in this thread, again...
          Trying to find what was different from the 100 sketchs i tried...
          EUREKA :exclamation: ''development branch of MySensors Arduino package''
          ''https://github.com/mysensors/Arduino/archive/development.zip''
          I was not using the proper library...
          Now my Veraedge find everything ! :relaxed:
          Thanks again ! And also Thanks to Hek for ''Combining MySensors examples'' :clap:
          Mike
          12.1k
