  3. Library 1.6 devel - How query the parent node?
6 Posts 2 Posters 1.8k Views 2 Watching
  • X
    X
    xefil
    I'm using succesfully the new development library.
    If I set the parent to AUTO and enable the debug mode, I can see which parent was choosen.
    I would like to save this output to a variable.
    Can I query (maybe during presentation) the parent I get during the discovery? How?
    Thanks'
    Simon
      You should be able to query query parent id through:
      _nc.parentNodeId
      Hmm. we should probably add a new method getParentId() or something to make it a bit more publicly accessible .
      • X
        X
        xefil
        Ok, thank you!
        Should be enough something like that?
        int parntNode = _nc.parentNodeId;
        L'll give it a try.
        Thank's!
        Simon
        PS: I've seen I could query as well 'distance' :)
        • X
          X
          xefil
          Hello @hek
          I was able to query the parentnode. I would like to send this information to the Gateway and then save/display it into my controller.
          How i s the best way to send these informations? They are not really related to a sensor, are more custom.
          I could define it something like that:
          // parent
          MyMessage msgNodeVar1(CHILD_ID_NODE, V_VAR1)
          // distance
          MyMessage msgNodeVar1(CHILD_ID_NODE, V_VAR2)
          but under which sub-type present it?
          present(CHILD_ID_NODE, S_<WHICHONE???>);
          Then into loop() with a time I could then send these informations:
          parentNode = _nc.parentNodeId;
          send(msgNodeVar1.set(parentNode, 1));
          distance = _nc.distance;
          send(msgNodeVar2.set(distance, 1));
          So, to be clean, which subtype should I use for the presentation?
          Thanks!
          Simon
            The parent node-id is sent automatically during node presentation (and can be retrieved from a running node by sending an I_PRESENTATION to the node).
            https://github.com/mysensors/MySensors/blob/dc99e8a8d4b024d69af3b67d3b9f1190700a5200/core/MySensorsCore.cpp#L216
            But to answer your question, The VAR_X can be used with any device type.
            X 1 Reply Last reply
              X
              X
              xefil
              @hek
              I can retrive the parent node by requesting it, that's ok. I have no idea how to do that (if you can point me to an example...)
              BTW, if I would like to inform the Controller (OpenHAB) on which parent is used by a node (I'm using MQTTClient as GW) I need to present and register this information as written by me before or there is another way as well?
              Thanks!
              simon
