  3. [1.5.4] setDestination remove signing (MySigningAtsha204Soft)
2 Posts 1 Posters 959 Views 1 Watching
    Mr.Osaka
    wrote on last edited by Mr.Osaka
    Hi, i use MySensors 1.5.4. I test the software version signing.
    If i send a message to another node the signing is lost.
    the code
     * version 2 as published by the Free Software Foundation.8
    // set node id
    #define NODE_ID 143
    // select MySigningAtsha204Soft
    #define Atsha204Soft
    // select MySigningAtsha204 with hardware
    //#define Atsha204hw
    #ifdef Atsha204Soft
      #include <MySigningAtsha204Soft.h>
    #elif defined Atsha204hw
      #include <MySigningAtsha204.h>
    #include <MyHwATMega328.h>
    MyHwATMega328 hw; // Select AtMega328 hardware profile
    MyTransportNRF24 radio;  // NRFRF24L01 radio driver
    #ifdef Atsha204Soft
      MySigningAtsha204Soft signer(true);
      MySensor gw(radio, hw, signer);
      MySigningAtsha204 signer; // Select HW ATSHA signing backend
    #else
      MySensor gw(radio, hw);
    #include <Wire.h>
    #define CHILD_ID_HVAC 0
    #define CHILD_ID_TEMP 1
    // Initialize thermostat message
    MyMessage msgHeater(CHILD_ID_HVAC, V_STATUS);
    boolean metric = true;
    int Sleep_time = 3000;
    float temperature;
    byte heating;
      gw.begin(NULL, NODE_ID);
      // termostato
      gw.present(CHILD_ID_HVAC, S_HVAC);
      msgHeater.setDestination(200);
      heating = 1;
      temperature = 24;
      gw.process();
      gw.send(msgTemp.set(temperature,1));
      gw.send(msgHeater.set(heating,1));
      gw.sleep(Sleep_time);
    MyConfig.h
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    // Enable debug flag for debug prints. This will add a lot to the size of the final sketch but good
    // to see what is actually is happening when developing
    #define DEBUG
    // Disable this line, If you are using TX(1), RX(0) as normal I/O pin
    #define ENABLED_SERIAL
    // Serial output baud rate (for debug prints and serial gateway)
    #define BAUD_RATE 115200
    *  Over the air firmware updates
    // The following define enables the safe over-the-air firmware update feature
    // which requires external flash and the DualOptiBoot bootloader.
    // Note: You can still have OTA FW updates without external flash but it
    // requires the MYSBootloader and disabled MY_OTA_FIRMWARE_FEATURE
    //#define MY_OTA_FIRMWARE_FEATURE
    // Slave select pin for external flash
    #define MY_OTA_FLASH_SS 8
    // Flash jdecid
    #define MY_OTA_FLASH_JDECID 0x1F65
    *  Information LEDs blinking
    // This feature enables LEDs blinking on message receive, transmit
    // or if some error occured. This was commonly used only in gateways,
    // but now can be used in any sensor node. Also the LEDs can now be
    // disabled in the gateway.
    //#define WITH_LEDS_BLINKING
    // The following setting allows you to inverse the blinking feature WITH_LEDS_BLINKING
    // When WITH_LEDS_BLINKING_INVERSE is enabled LEDSs are normally turned on and switches
    // off when blinking
    #define WITH_LEDS_BLINKING_INVERSE
    // default LEDs blinking period in milliseconds
    #define DEFAULT_LED_BLINK_PERIOD 300
    // The RX LED default pin
    #define DEFAULT_RX_LED_PIN 6
    // The TX LED default pin
    #define DEFAULT_TX_LED_PIN 5
    // The Error LED default pin
    #define DEFAULT_ERR_LED_PIN 4
    *  Message Signing Settings
    // Disable to completly disable signing functionality in library
    #define MY_SIGNING_FEATURE
    // Define a suitable timeout for a signature verification session
    // Consider the turnaround from a nonce being generated to a signed message being received
    // which might vary, especially in networks with many hops. 5s ought to be enough for anyone.
    #define MY_VERIFICATION_TIMEOUT_MS 5000
    // Enable to turn on whitelisting
    // When enabled, a signing node will salt the signature with it's unique signature and nodeId.
    // The verifying node will look up the sender in a local table of trusted nodes and
    // do the corresponding salting in order to verify the signature.
    // For this reason, if whitelisting is enabled on one of the nodes in a sign-verify pair, both
    // nodes have to implement whitelisting for this to work.
    // Note that a node can still transmit a non-salted message (i.e. have whitelisting disabled)
    // to a node that has whitelisting enabled (assuming the receiver does not have a matching entry
    // for the sender in it's whitelist)
    //#define MY_SECURE_NODE_WHITELISTING
    // MySigningAtsha204 default setting
    #define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
    // MySigningAtsha204Soft default settings
    #define MY_RANDOMSEED_PIN 7 // A7 - Pin used for random generation (do not connect anything to this)
    // Key to use for HMAC calculation in MySigningAtsha204Soft (32 bytes)
    #define MY_HMAC_KEY 0x00,0x01,0x02,0x03,0x04,0x05,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    *  NRF24L01 Driver Defaults
    #define RF24_CE_PIN		   9
    #define RF24_CS_PIN		   10
    #define RF24_PA_LEVEL 	   RF24_PA_MAX
    #define RF24_PA_LEVEL_GW   RF24_PA_MAX
    // RF channel for the sensor net, 0-127
    #define RF24_CHANNEL	   76
    //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
    #define RF24_DATARATE 	   RF24_250KBPS
    // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
    #define RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
    // Enable SOFTSPI for NRF24L01 when using the W5100 Ethernet module
    //#define SOFTSPI
    #ifdef SOFTSPI
    	// Define the soft SPI pins used for NRF radio
    	const uint8_t SOFT_SPI_MISO_PIN = 16;
        const uint8_t SOFT_SPI_MOSI_PIN = 15;
        const uint8_t SOFT_SPI_SCK_PIN = 14;
    *  RFM69 Driver Defaults
    // Default network id. Use the same for all nodes that will talk to each other
    #define RFM69_NETWORKID     100
    // Default frequency to use. This must match the hardware version of the RFM69 radio (uncomment one):
    // #define RFM69_FREQUENCY   RF69_433MHZ
    #define RFM69_FREQUENCY   RF69_868MHZ
    //#define FREQUENCY     RF69_915MHZ
    // Enable this for encryption of packets
    //#define RFM69_ENABLE_ENCRYPTION
    #define RFM69_ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
    log with msgHeater.setDestination(200);
    send: 143-143-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:1
    read: 0-0-143 s=255,c=3,t=15,pt=2,l=2,sg=0:1
    send: 143-143-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=ok:
    read: 0-0-143 s=255,c=3,t=17,pt=6,l=25,sg=0:01B3F448E00B03DE197731D7302FC7167D50E9F50B77C63700
    send: 143-143-0-0 s=255,c=0,t=17,pt=0,l=5,sg=1,st=ok:1.5.4
    read: 0-0-143 s=255,c=3,t=17,pt=6,l=25,sg=0:01760D40777B6F77FB01DB9885D5E308FEA51F1A08C6FB2062
    send: 143-143-0-0 s=255,c=3,t=6,pt=1,l=1,sg=1,st=ok:0
    sensor started, id=143, parent=0, distance=1
    send: 143-143-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 143-143-0-0 s=0,c=0,t=29,pt=0,l=0,sg=0,st=ok:
    send: 143-143-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=ok:
    read: 0-0-143 s=255,c=3,t=17,pt=6,l=25,sg=0:0113FB50BA8E123562556FFB438496DD27EE929E73D8B05435
    send: 143-143-0-0 s=1,c=1,t=0,pt=7,l=5,sg=1,st=ok:24.0
    send: 143-143-0-200 s=0,c=1,t=2,pt=7,l=5,sg=0,st=ok:1.0
    read: 0-0-143 s=255,c=3,t=17,pt=6,l=25,sg=0:01064049BBFFF98FDAD1841895BC33ECDDA202E66BDB9D045F
    log without msgHeater.setDestination(200);
    send: 143-143-0-0 s=0,c=3,t=16,pt=0,l=0,sg=0,st=ok:
    send: 143-143-0-0 s=0,c=1,t=2,pt=7,l=5,sg=1,st=ok:1.0
    Arduino ide 1.6.1
    the node is arduino nano and gateway is a mini pro over a Raspberry Pi via serial
    I don't now if is a bug or a programming error.
    Thank you for help
    Stefano
    p.s.: sorry for the broken english
      Mr.Osaka
      the answer for this problem is here
      technically possible, but hard to implement.
      Stefano
