  3. Dimmer and automaticly turn "on" and "off" the light
7 Posts 3 Posters 2.8k Views 3 Watching
  • J
    J
    jacek
    wrote on last edited by jacek
    I have dimmer code wchitch allow turn "on" or "off" the light from switch or domoticz when light level is ">" or "<" 350.
    I wont that light when is "on" and light level change from < 350 to > 350 light automaticly "off" and sen information to domoticz but I cant do that :(
    I have something like this but this only send information to domoticz and no change lighgt status.
    Sorry this change light status but only from "on" to "off", when light level change to < 350 light turn "on" and I dont know why for a moment turn "off"
    void autolight()
      if (analogRead(photoPin) > 350 &&  analogRead(LED_PIN) > 0)
      {//Turn "off" the light
        analogWrite(LED_PIN,0);
        gw.send(dimmerMsg.set(0), true);
                             return;
      else if (analogRead(photoPin) < 350 &&  analogRead(LED_PIN) == 0)
      {// Turn "on" the light
        analogWrite(LED_PIN,100);
        gw.send(dimmerMsg.set(100), true);
                             return;
      if (analogRead(photoPin) < 350) {
                       // Incoming on/off command sent from controller ("1" or "0")
                             int lightState = message.getString()[0] == '1';
                             int newLevel = 0;
                                if (lightState==LIGHT_ON) {
                                   // Pick up last saved dimmer level from the eeprom
                                   newLevel = loadLevelState(EEPROM_DIM_LEVEL_SAVE);
                       // Send dimmer level back to controller with ack enabled
                             gw.send(dimmerMsg.set(newLevel), true);
                       // We do not change any levels here until ack comes back from gateway
                             return;
      } else {
                             return;
    } else if (message.type == V_DIMMER) {
                       // Incoming dim-level command sent from controller (or ack message)
                             fadeTo = atoi(message.getString(convBuffer));
                       // Save received dim value to eeprom (unless turned off). Will be
                       // retreived when a on command comes in
                             if (fadeTo != 0)
                                    saveLevelState(EEPROM_DIM_LEVEL_SAVE, fadeTo);
      } else {
                             return;
    SparkmanS 1 Reply Last reply
    • J jacek
      void autolight()
                               return;
                               return;
                               int newLevel = 0;
                               return;
        } else {
                               return;
                               if (fadeTo != 0)
        } else {
                               return;
      SparkmanS
      SparkmanS
      Sparkman
      @jacek In your icomingMessage routine, it looks you have no code to turn the light off, although I might be misinterpreting it.
      Cheers
      Al
      • J
        J
        jacek
        Sorry it' s complite incomingMessages code:
                                 int newLevel = 0;
                                 return;
          } else {
                                 return;
                                 if (fadeTo != 0)
          } else {
                                 return;
          saveLevelState(EEPROM_DIM_LEVEL_LAST, fadeTo);
          Serial.print("New light level received: ");
          Serial.println(fadeTo);
          if (!changedByKnob)
            knob.write(fadeTo);
          // Cancel send if user turns knob while message comes in
          changedByKnob = false;
          sendDimValue = false;
          // Stard fading to new light level
          startFade();
        • J jacek
                                   int newLevel = 0;
                                   return;
            } else {
                                   return;
                                   if (fadeTo != 0)
            } else {
                                   return;
            if (!changedByKnob)
              knob.write(fadeTo);
            startFade();
          SparkmanS
          SparkmanS
          Sparkman
          wrote on last edited by Sparkman
          @jacek It looks like you have an endless loop to me,
          To initiate turning off the light due to a high ambient level, you call gw.send(dimmerMsg.set(0), true); which will instruct domoticz to send a command back which should be acted upon in your incomingMessage routine. In that routine, if the ambient light level is high, you send the same command back to domoticz: gw.send(dimmerMsg.set(0), true);. It's not clear to me what the rest of the functions after that do but they won't be executed due to your return command. What does the serial output show when high ambient light triggers this?
          • J
            J
            jacek
            You have right ist loop but I do not know where :)
            This is complit code:
            #include <Encoder.h>
            #include <Bounce2.h>
            #include <OneWire.h>
            #define ONE_WIRE_BUS 19 // Pin where dallase sensor is connected
            #define MAX_ATTACHED_DS18B20 1
            #define LED_PIN 3           // Arduino pin attached to MOSFET Gate pin
            #define KNOB_ENC_PIN_1 4    // Rotary encoder input pin 1
            #define KNOB_ENC_PIN_2 5    // Rotary encoder input pin 2
            #define KNOB_BUTTON_PIN 6   // Rotary encoder button pin
            #define photoPin A6         // Fotorezystor
            #define FADE_DELAY 10       // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
            #define SEND_THROTTLE_DELAY 400 // Number of milliseconds before sending after user stops turning knob
            #define SN "DimmableLED /w button"
            #define SV "1.2"
            #define CHILD_ID_LIGHT 12
            #define ID 11
            #define EEPROM_DIM_LEVEL_LAST 1
            #define EEPROM_DIM_LEVEL_SAVE 2
            #define LIGHT_OFF 0
            #define LIGHT_ON 1
            int dimValue;
            int fadeTo;
            int fadeDelta;
            int persons;
            byte oldButtonVal;
            bool changedByKnob=false;
            bool sendDimValue=false;
            unsigned long lastFadeStep;
            unsigned long sendDimTimeout;
            char convBuffer[10];
            int numSensors=0;
            boolean metric = true;
            unsigned long on = 0;
            unsigned long onT = 0;
            MyMessage msg(0,V_TEMP);
            MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
            MyMessage msgl(0, V_LIGHT_LEVEL);
            ////WENT
            //Relay Relays[noRelays];
            //Bounce debouncer1[noRelays];
            //MyMessage msg1[noRelays];
            ////END
            Encoder knob(KNOB_ENC_PIN_1, KNOB_ENC_PIN_2);
            Bounce debouncer = Bounce();
            int lastLightLevel;
               // The third argument enables repeater mode.
            //  gw.begin(NULL, AUTO, true);
              //Send the sensor node sketch version information to the gateway
             // gw.sendSketchInfo("Repeater Node", "1.0");
              // Set knob button pin as input (with debounce)
              pinMode(KNOB_BUTTON_PIN, INPUT);
              pinMode(photoPin, INPUT);
              digitalWrite(KNOB_BUTTON_PIN, HIGH);
              debouncer.attach(KNOB_BUTTON_PIN);
              debouncer.interval(5);
              oldButtonVal = debouncer.read();
              // Set analog led pin to off
              analogWrite( LED_PIN, 0);
              // Init mysensors library
              gw.begin(incomingMessage, ID, true);
              gw.present(CHILD_ID_LIGHT, S_DIMMER);
              gw.sendSketchInfo(SN, SV);
              // Retreive our last dim levels from the eprom
              fadeTo = dimValue = 0;
              byte oldLevel = 0;
              Serial.print("Sending in last known light level to controller: ");
              Serial.println(oldLevel);
              gw.send(dimmerMsg.set(oldLevel), true);
              Serial.println("Ready to receive messages...");
              sensors.begin();
                 gw.present(i, S_TEMP);
              gw.present(15, S_LIGHT_LEVEL);
              // Process incoming messages (like config and light state from controller)
              gw.process();
              // Sprawdzenie temperatury
              CheckTemp();
              onT = onT + 1;
              on = on + 1;
              if (on > 401 + 2*ID) {
              // Poziom swiata
              lightLevel();
              on = 0;
              if (analogRead(photoPin) > 350) { persons = 0;} else {persons = 1;}
              // Check if someone has pressed the knob button
              checkButtonClick();
              // Fade light to new dim value
              fadeStep();
               //Autolight
              autolight();
            void autolight()
                                     return;
               // analogWrite(LED_PIN,100);
                                     return;
            void lightLevel()
            int lightLevel = (analogRead(photoPin));
              Serial.println(lightLevel);
                  gw.send(msgl.set(lightLevel));
                  lastLightLevel = lightLevel;
            void CheckTemp()
                #if COMPARE_TEMP == 1
                #else
                      if (onT > 400 + 2*ID) {
                     onT = 0; }
                int newLevel = 0;
                return;
                 } else {
                  return;
                if (fadeTo != 0)
              } else {
                  return;
              if (!changedByKnob)
                knob.write(fadeTo);
              startFade();
            void checkButtonClick()
            if ( persons == 1 ) {
              debouncer.update();
              byte buttonVal = debouncer.read();
              byte newLevel = 0;
              if (buttonVal != oldButtonVal && buttonVal == LOW) {
                if (dimValue==0) {
                  // Turn on light. Set the level to last saved dim value
                 // int saved = loadLevelState(EEPROM_DIM_LEVEL_SAVE);
                 int saved = 100;
                  newLevel = saved > 0 ? saved : 100;
                gw.send(dimmerMsg.set(newLevel),true);
              oldButtonVal = buttonVal;
            void startFade() {
              fadeDelta = ( fadeTo - dimValue ) < 0 ? -1 : 1;
              lastFadeStep = millis();
            // This method provides a graceful none-blocking fade up/down effect
            void fadeStep() {
              unsigned long currentTime  = millis();
              if ( dimValue != fadeTo && currentTime > lastFadeStep + FADE_DELAY) {
                dimValue += fadeDelta;
                analogWrite( LED_PIN, (int)(dimValue / 100. * 255) );
                lastFadeStep = currentTime;
                Serial.print("Fading level: ");
                Serial.println(dimValue);
                if (fadeTo == dimValue && changedByKnob) {
                  sendDimValue = true;
                  sendDimTimeout = currentTime;
              // Wait a few millisecs before sending in new value (if user still turns the knob)
              if (sendDimValue && currentTime > sendDimTimeout + SEND_THROTTLE_DELAY)  {
                 // We're done fading.. send in new dim-value to controller.
                 // Send in new dim value with ack (will be picked up in incomingMessage)
                gw.send(dimmerMsg.set(dimValue), true); // Send new dimmer value and request ack back
            // Make sure only to store/fetch values in the range 0-100 from eeprom
            int loadLevelState(byte pos) {
              return min(max(gw.loadState(pos),0),100);
            void saveLevelState(byte pos, byte data) {
              gw.saveState(pos,min(max(data,0),100));
            SparkmanS TheoLT 2 Replies Last reply
            • J jacek
              #define SV "1.2"
              #define ID 11
              #define LIGHT_OFF 0
              #define LIGHT_ON 1
              int dimValue;
              int fadeTo;
              int fadeDelta;
              int persons;
              byte oldButtonVal;
              int numSensors=0;
              ////WENT
              ////END
              int lastLightLevel;
                byte oldLevel = 0;
                sensors.begin();
                gw.process();
                CheckTemp();
                onT = onT + 1;
                on = on + 1;
                // Poziom swiata
                lightLevel();
                on = 0;
                checkButtonClick();
                fadeStep();
                 //Autolight
                autolight();
              void autolight()
                                       return;
                                       return;
              void lightLevel()
              void CheckTemp()
                  #else
                       onT = 0; }
                  int newLevel = 0;
                  return;
                   } else {
                    return;
                  if (fadeTo != 0)
                } else {
                    return;
                if (!changedByKnob)
                  knob.write(fadeTo);
                startFade();
                debouncer.update();
                byte newLevel = 0;
                  if (dimValue==0) {
                   int saved = 100;
              void startFade() {
              void fadeStep() {
              SparkmanS
              SparkmanS
              Sparkman
              @jacek As I mentioned, you call gw.send(dimmerMsg.set(0), true); again in the incomingMessage routine. By doing that, you are asking Domoticz to send another off command. Instead you should have a command there to actually set the dim level on the pins to the value that you want. I'm not too familiar with this code, but looking at it, you should just save the new state there and then continue with the routine, rather than calling return;
              Cheers
              Al
              • J jacek
                #define SV "1.2"
                #define ID 11
                #define LIGHT_OFF 0
                #define LIGHT_ON 1
                int dimValue;
                int fadeTo;
                int fadeDelta;
                int persons;
                byte oldButtonVal;
                int numSensors=0;
                ////WENT
                ////END
                int lastLightLevel;
                  byte oldLevel = 0;
                  sensors.begin();
                  gw.process();
                  CheckTemp();
                  onT = onT + 1;
                  on = on + 1;
                  // Poziom swiata
                  lightLevel();
                  on = 0;
                  checkButtonClick();
                  fadeStep();
                   //Autolight
                  autolight();
                void autolight()
                                         return;
                                         return;
                void lightLevel()
                void CheckTemp()
                    #else
                         onT = 0; }
                    int newLevel = 0;
                    return;
                     } else {
                      return;
                    if (fadeTo != 0)
                  } else {
                      return;
                  if (!changedByKnob)
                    knob.write(fadeTo);
                  startFade();
                  debouncer.update();
                  byte newLevel = 0;
                    if (dimValue==0) {
                     int saved = 100;
                void startFade() {
                void fadeStep() {
                TheoLT
                TheoLT
                TheoL
                @jacek By the looks of your code you're doing the following.
                1. Domoticz sends a command to your Node.
                2. You ignore the value and assign 0 as the value.
                3. You send the new value - which is allways 0 - to domoticz.
                So basically you turn off the lamp no matter what the command is what Domoticz is sending to the node.
                At least that's what I think. But I'm a bit tired have been studying for too many hours today ;-)
