  3. 💬 Wall Socket Insertable Node
rfm69atsha204amysensorsrelaypower supply
77 Posts 21 Posters 33.0k Views 27 Watching
  • Sander TeunissenS Sander Teunissen
    I was looking for a gateway for the rfm69 chip. I just learned it is available in different frequencies. On which one of this component operating?
    tonnerre33T Offline
    tonnerre33T Offline
    tonnerre33
    @Sander-Teunissen depend which rfm69 you will order. For example i have choosen 868Mhz, that's why i'll choose this frequency for all my nodes and my gateway ;)
    Sander TeunissenS 1 Reply Last reply
      K Offline
      K Offline
      Koresh
      @Sander-Teunissen
      315/433/868/915 MHz. I plan to mount 433Mhz for the first batch but it is easy to solder another if it necessary.
      • Sander TeunissenS Offline
        Sander Teunissen
        @Koresh thanks. I guess
        https://www.openhardware.io/view/102/Wall-Switch-Insertable-Node
        Will be 433 too then ?
        K 1 Reply Last reply
          K Offline
          K Offline
          Koresh
          @Sander-Teunissen Yes. Very soon I hope. This board (switch) contains only 0603 components now (without 0402 components), so it will be avaliable as kit for soldering funs too :wink:
          12/06/2016	2:47 P.M. Your package is at the clearing agency awaiting final release.
          It is components package... So I hope I will mount boards soon.
          • K Koresh
            Sander Teunissen
            @Koresh great! Looking forward to it!
            • tonnerre33T tonnerre33
              Sander Teunissen
              I guess that's true when you do the board yourself.... But I am not tech savvy enough (or too lazy ;-) ) to do the board myself. I hope to buy them from Koresh directly...
              • S Offline
                shabba
                Any update on this? This would scratch my latest itch! :-)
                • S shabba
                  K Offline
                  K Offline
                  Koresh
                  Both versions of this board are under intensive testing now. I've tuned it a little these days for working in very cold enveronment (it is very cold now in my country, up to -25-30C).
                  MiKaM 1 Reply Last reply
                  • S Offline
                    shabba
                    Great - Keep us informed!
                    • K Koresh
                      MiKaM Offline
                      MiKaM Offline
                      MiKa
                      @Koresh
                      Which type of transformer You are using (tr1)? type or order link?
                      THX,
                      MiKa
                      • PierreStP Offline
                        PierreStP Offline
                        PierreSt
                        Hi Koresh,
                        Thanks for the last update and congratulations on finishing the design. You mentionned some time earlier that you wanted to sell these (and also CE approval?). Could you tell us the status of this?
                        Thanks,
                        Pierre
                        • PierreStP PierreSt
                          Hi Koresh,
                          Thanks,
                          Pierre
                          K Offline
                          K Offline
                          Koresh
                          @PierreSt Many thanks for you attention to this project. I will add all assembled boards to Ebay next week. My devices successfully passed all safety tests. But unfortunatelly I have no enough resources to complete CE certification yet.
                          • S Offline
                            shabba
                            Hi @Koresh - Brilliant! I can't wait to order a whole pile of your boards! :)
                            Please shout when there are available!
                            • fisherF Offline
                              fisherF Offline
                              fisher
                              Found it on ebay - is it yours Koresh?
                              http://www.ebay.com/usr/easysensors
                              For now there is only Wall Socket insertable node on stock, more boards will come soon I hope
                              Y 1 Reply Last reply
                              • fisherF fisher
                                Y Offline
                                Y Offline
                                yury
                                Hi @fisher yes this is Koresh board. Hope to upload others soon... We did production and testing with him together.
                                • D Offline
                                  DavidZH
                                  @Koresh I'd like to repeat the question @MiKa asked on Januari 10th; can you share details on the transformer you used? Or a hint on where you got the inspiration for the power supply for the board?
                                  • D DavidZH
                                    K Offline
                                    K Offline
                                    Koresh
                                    @DavidZH Sorry for such long delay with this question. I will try to explain it carefully now.
                                    I think it is not possible to buy ready transformer on ali or anywhere else. You can only derive it yourself according to your schematic and produce it at any factory according to your requirements.
                                    This board has flyback power supply so you can use any flyback transformer design guide, or use as similar as possible reference design. I used EBC10010 reference design to produce the required transformer.
                                    The main difficulty is the difference between theoretical transformers and produced transformers, so we should tune our schematic to produced transformer a little. Now I have a small batch of transformers almost all of which are soldered on the boards. When I place an order for the next batch of transformers (may be a larger one), I can who send it to anyone who is interested (of course with a tuned schematic if the next batch is different).
                                    D Z 2 Replies Last reply
                                    • K Koresh
                                      DavidZH
                                      @Koresh Thanks for the explanation.
                                      I've been searching for a power solution for my nodes. And that's quite the task.... For now I'm working with the HLK, but that's a tight squeeze. And when I want to make a dimmer, I could use a zero cross circuit. I've been looking into Vigortronix, who have a supply similar to the HLK, but with an extra pulse output for the zero-X. Too bad they are WIDE. They won't leave any proper room for a relay or connection terminal.
                                      I'll take a look at your link and see if I can make that work in my case, and may come back to you for some magnetics.
                                      • K Offline
                                        K Offline
                                        Koresh
                                        Unfortunately I can't open my ebay shop right now. While I'm trying to open it, you can buy this board here: https://www.ebid.net/eu/for-sale/arduino-ide-compatible-low-profile-220v-10a-relay-rfm69hw-433-mhz-radio-156694939.htm
                                        • jeremushkaJ Offline
                                          jeremushkaJ Offline
                                          jeremushka
                                          in case you want to use the wall plug manually when a device is connected (without mysensors), it will not work at all in case the relay has been switched ? How do you manage external usage ?
                                          12.2k
