  3. Some Questions with gardening node (sensor/accurator)
1 Posts 1 Posters 965 Views 1 Watching
  • dakkyD
    dakkyD
    dakky
    Hello
    Ich want to implement a gardening node and found this project:
    http://iot-playground.com/blog/2-uncategorised/61-nrf24l01-arduino-balcony-irrigation-controller
    I think i am able to adopt this for my setup without the solar power part.
    There are still some question on the hardware-side:
    • the pumps
      When using this setup: i need one pump per plant. Is there a more efficient setup with one pump and valves? I searched for valves, but they seem to be far more expensive that these cheap pumps?
    • unknown parts on the pcb
      http://iot-playground.com/images/articles/029/20150620_135404x.jpg
      Can someone explain to me, what the items below the arduino are used for?
    • Power
      when using a 12v power supply a can use it to power the pumps (directly), the 5v arduino (via the RAW input pin) and the radio (via the 5V pin of the arduino + a 3v regulator)? Is that correct? did i miss anything? Any idea, how many pumps should run at the same time? or should it be limited to one per time on the controller side?
    Anything i should think about?
    thank
    Dakky
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
