  3. Hardware watchdog
Hardware watchdog
3 Posts 3 Posters 1.8k Views 2 Watching
  • KoreshK
    KoreshK
    Koresh
    wrote on last edited by Koresh
    Hello everyone :)
    I want to try to implement hardware watchdog in one of my boards (wall socket insertable nodes). I've received 10pcs of TPS3813K33 chips. I chose this IC as relatively inexpensive solution with large programmable window range. I need to generate heartbeat pulses on dedicated WDI pin. Pulses must be not so frequently but frequently enough to prevent watchdog reset (approximately 1 - 25sec). I use mysensors 2.0 library now but I don't know very well structure of library. May be library has some functionality I can use? So I don't want to invent my bike from scratch :) Now I want to chose one of three (?) variants:
    1. Write separete library
    2. Add functionality to mysensors library
    3. Use existing functionality.
    Thanks for any help!
    AWIA 1 Reply Last reply
    • scalzS
      scalzS
      @Koresh : you can find some stuff about wdt, hardware, and 328p at MyHwATMega328 files. mysensorscore files too. There is also an heartbeat function but not done in this way i think.
      I'm not sure, i let others answer, if for something like this (a bit specific to an external chip) it wouldn't be better outside mysensors, in a specific lib for the application for instance. or use timers etc...
      it depends what you want to do, i'm not sure.
      • KoreshK Koresh
        Hello everyone :)
        AWIA
        AWIA
        AWI
        @Koresh Intresting option: to generate a full reset if no sign of life for ... time limit. I would implement this without special library/ MySensors functionality. Just use gw.sleep( xx ms) ; and generate a pulse every xx ms in the main loop.
