  2. Announcements
  3. MySensors 2.0.0 Released
75 Posts 42 Posters 55.0k Views 37 Watching
  • G
    G
    gloob
    I did now also update my gateway but I see two messages in the debug panel that I don't understand:
    pm open,type:2 0
    0;255;3;0;9;TSP:SANCHK:OK
    Does anybody have an idea what that means?
    ? 1 Reply Last reply
    • TheoLT
      TheoLT
      TheoL
      I've read the documentation and I'm really impressed with the great work you've guys have done. Developping sensors with MySensors had never been this easy. You guys rock!
      • hugowsH
        hugowsH
        hugows
        I just built my first "sensor network" yesterday and I was lucky to arrive on the 2.0 version - fun times! Congrats hek and contributors.
        • KoreshK
          KoreshK
          Koresh
          Congratulations!
          I used 2.0dev last month and I'm happy to see this version get stable status. :thumbsup:
          • YveauxY Yveaux
            @DavidZH See here:
            "It should be fully backward compatible with your controller (serial api hasn't been changed since 1.5).
            We recommend updating both gateway and sensors to the the latest release."
            D
            D
            DavidZH
            @Yveaux
            I have now recompiled my node that was on 2.0DEV to 2.0Stable and it will not fly. So tomorrow I will recompile my gateway to see if that runs better.
            I really have to get used to the new debug output though. But it give a lot more info!
            • G gloob
              pm open,type:2 0
              A Former User
              pm open,type:2 0
              I have this problem too. What does that mean?
              tbowmoT 1 Reply Last reply
              • ? A Former User
                pm open,type:2 0
                tbowmoT
                tbowmoT
                tbowmo
                @kenci said:
                pm open,type:2 0
                The TSP:SANCHK:OK is a sanity check of the radio, this time it's OK. But if we fail in talking with the radio (spi failure etc) it will try to initialize the radio, and also write Fail (I believe)
                It's @tekka that is the brain behind this part (and has promised to make some documentation on it :))
                ? mppM 2 Replies Last reply
                • tbowmoT tbowmo
                  @kenci said:
                  pm open,type:2 0
                  A Former User
                  @tbowmo Thank you for the explanation. But what does that mean pm open,type:2 0
                  • marekdM
                    marekdM
                    marekd
                    Hi there.
                    Good work.
                    I was using dev ver. - should I recompile all nodes and GW to 2.0.0, to use it?
                    YveauxY AWIA 2 Replies Last reply
                    • marekdM marekd
                      Hi there.
                      Good work.
                      YveauxY
                      YveauxY
                      @marekd quote from the main site : "We recommend updating both gateway and sensors to the the latest release."
                      • marekdM marekd
                        Hi there.
                        Good work.
                        AWIA
                        AWIA
                        AWI
                        @marekd To add to @Yveaux , if you are using repeaters (or nodes with the repeater functionality switched on) these also should be updated to the latest release.
                        • Tore André RosanderT
                          Tore André Rosander
                          Is there any plans to update the Raspberry gateway? The one where the nrf radio is connected directly to RPI gpio.
                          As far as i know it is version 1.4 at the moment.
                          D 1 Reply Last reply
                          • Tore André RosanderT Tore André Rosander
                            D
                            D
                            drock1985
                            @Tore-André-Rosander
                            I think that was someone who contributed it a while back. I remember going though the thread, and at one time someone was looking for anyone to update the 1.5 base for the signing; IIRC.
                            Probably best to switch to another Gateway for now.
                            My Projects
                            2 Door Chime Sensor
                            Washing Machine Monitor
                            Tore André RosanderT 1 Reply Last reply
                            • D drock1985
                              Tore André Rosander
                              @drock1985
                              Is there any pro/cons when choosing the esp gateway or the serial gateway (connected to Raspberry pi)?
                                @drock1985
                                D
                                D
                                drock1985
                                Not really; depends on what your controller supports. Personally I have Home-Assistant running the latest MySensors 2.0 Wifi (ESP) gateway no problems.
                                My Projects
                                2 Door Chime Sensor
                                • scalzS
                                  scalzS
                                  wrote on last edited by scalz
                                  #56
                                  for pros, I think serial gw is more secure. I mean esp is wifi, serial gw is only connected to controller. Of course controller is connected to network, but esp is just one more door directly connected to mysensors. Cons, not as verstatile as esp ;)
                                  • F
                                    F
                                    Fabien
                                    And with RFM69, ESP and MySensors 2.0 doesn't work for me. With serial gateway, it's ok. With Ethernet Gateway W5100 and MYS 1.0, I lost lot of packets (NRF radio).
                                      Tore André Rosander
                                      Thanks for the response, i tested the esp gateway and it looks good. But i think im going for the serial gateway just to eliminate the need for WiFi in my setup. So if the WiFi is messing up during the night the mysensors network still works.
                                      • scalzS
                                        scalzS
                                        #59
                                        @Fabien ah weird.. for test, i have a working rfm69, esp mqtt and mysensors 2b gw.. but i don't know for the other esp gw.
                                        • T
                                          tante ju
                                          I like the new setup of the MySensors lib, but after getting some more gray hairs and replacing processors, boards and all the other stuff I noticed, there is something wrong with it.
                                          Following effect (tried it with Arduino versions 1.6.3 up to 1.6.9 on a Mac with El Capitan):
                                          I've setup a clean Arduino environment and installed the new MySensors lib. Wrote a program, where I wanted to test some interrupt routines with MySensor and it did not work. ok, seemed to be a bug and watchdog stepped in. Fixed software, rewrote software, created a small test program and always the same issue. I used Node Id 5 for this one.
                                          Then, after a whole day and changing processors and all other stuff I loaded a file, working with 2.0-beta and using Node Id 7. And what I got where the same messages on the gateway, just with Node Id 7. ???
                                          In fact I got a presentation of HUM (my tests with Node 5), but with Node 7, although the file never had anything to do with HUM.
                                          Verseifen with an Arduino Nano board, installed a very small MySensor example script on it and same effect.
                                          So, some pieces of the initial program were once compiled and resided in the system, regardless what source you are using afterwards.
                                          Deleted the new 2.0.0 lib, installed my 2.0.0-beta and everything is fine. Switched back to 2.0.0 stable and instantly the old binary was back there.
                                          Any ideas?
                                          DrJeffD Tore André RosanderT 2 Replies Last reply
