MySensors 2.0.0 Released
@nielsokker documentation about the log messages is WIP and will follow soon.
In brief:
TSM refers to the transport state machine, (!) to an error.
Your error !TSM:CHKID:FAIL indicates that the node didn't receive a (valid) ID, hence !TSM:FAILURE (transport not operational) followed by TSM:PDT which means that the radio was powered-down for a while followed by a re-initialisation.Thank you for your answer! Does this mean that the hardware is failing? I used the repeater example.
What am I doing wrong when I get this when I try to compile?
I have a new installation of Arduino IDE 1.6.5 (have tried 1.6.7 also, and still the same)and I have put the new files in my arduino sketchbook also deleted all old ones)Arduino:1.6.5 (Windows 8.1), Kort:"Arduino Nano, ATmega328"
DustSensor.ino:49:25: fatal error: MySensors.h: No such file or directory
compilation terminated.
Fel vid kompilering.This report would have more information with
enabled in File > Preferences. -
enabled in File > Preferences.I had the same error. You have to(instead of what the 1.5 manual says) keep all the files in the mysensors_master folder. This folder needs to be in the libraries folder that already exists.
Guess it's a good thing I am just getting started. I am guessing 2.0 should be the default go to now?
:mega: We are happy to announce a major release of the MySensors library to 2.0.0!
For details, see here.
Doxygen links on the master github frontpage are not working. These are the correct links:
master developmentThanks a lot for that great piece of work!!!
Yes, this in the new normal... we moved all the examples using external library dependencies into https://github.com/mysensors/MySensorsArduinoExamples until we can figure out which ones work with auto-dependency-download using the IDE Library Manager.
We would really appreciate some help doing the verification.
Actually sensebender sketch is moved to the same repository as the hardware files for the SensebenderMicro.
Problem is that we do not want to have external dependencies on the examples in the MySensors library, as they are not distributed together anymore. That's why examples with external dependencies have been moved to a new repository. Except the sensebender sketch, which we/I decided to relocate to the SensebenderMicro repository, as it's a bit special, and belongs to that hardware..
I have been using the beta for some time now, to use the stable version do i just download the zip from github and replace the mysensors folder in arduino -> libraries ?
I have just done as said above and works a treat! I was still running on Arduino 1.6.1 but this was enough reason to update!
One question: my serial gateway is still running on 1.5, do I have to update that to 2.0?
I have one node running on 2.0b and that talks just fine. New nodes will follow soon (PCBs are being printed now...) so they will be on 2.0 as well. -
not a big deal, but is there something i should do to get the mysensors to show up in my manage library?
running 1.6.7 and not seeing it. oh well. not a biggy
updated to 1.6.9 and it's there. oh well. probably needed to update anyway :)
