  3. 💬 MDMSGate
💬 MDMSGate
atsha204amysensors gatewayesp8266ethernetmysensorsgatewaynrf24l01usbatmega328rfm69
82 Posts 22 Posters 43.0k Views 25 Watching
  • P
    P
    pointbre
    Hi Kalina,
    I've been searching RF gateway with enclosure for Raspberry Pi and your one seems to fit my needs but I'd like to know what kind of library is used for RFM69.
    Thanks in advance.
    mfalkviddM kalinaK 2 Replies Last reply
    • P pointbre
      Hi Kalina,
      Thanks in advance.
      #42
      Hi @pointbre, welcome to the MySensors community!
      The library used, well, is MySensors :) https://www.mysensors.org/about/iot is a good place to start
      P 1 Reply Last reply
        P
        P
        pointbre
        Hi @mfalkvidd , thanks for your reply. Does that mean that I can plug this MDMSGate into USB port of Raspberry Pi? I would like to use MDMSGate as a RF gateway(based on RFLink firmware, see http://www.nemcon.nl/blog2/), which can commuciate with Node-Red on Raspberry PI via USB serial connection(see https://nodered.org/docs/hardware/arduino).
        • P pointbre
          @pointbre no. It does not use the rflink protocol. It uses the MySensors protocol.
          • P pointbre
            Hi Kalina,
            Thanks in advance.
            kalinaK
            kalinaK
            kalina
            wrote on last edited by kalina
            #45
            Hi @pointbre, @mfalkvidd is right, MDMSGate uses firmware based on MySensors library by default, but if you look at MDMSGate as a hardware device - you can develop you own firmware. Оf course, you can connect MDMSGate to Raspberry via USB (linux already has drivers for CP2102 chip) or Ethernet.
            • R RonnieMace
              Hello Kalina, I'm new to the whole gateway and sensors world. Can I connect this gateway to a raspberry pi and then use the wifi and 868MHz at the same time? So I can use different types of sensors. Thanks in advance.
              kalinaK
              kalinaK
              kalina
              #46
              @RonnieMace said in 💬 MDMSGate:
              Hi @RonnieMace, sorry, but i will answer for your question some later, I want to draw a picture that explains the modes of operation and connection MDMSGate and i need some time. Right now I want to present my new device - MDMSNode "Power"....
              • R
                R
                RonnieMace
                Ok thanks. It's just that I wonder if it 's possible to have one sensor via wifi and and an other via 868MHz. I'Il wait for your drawing. TThe gateway looks very nice btw.
                kalinaK 1 Reply Last reply
                • R RonnieMace
                  kalinaK
                  kalinaK
                  kalina
                  #48
                  @RonnieMace
                  USB, Wi-Fi and Ethernet are using only for connection to controller and you can't use it with different types of sensors. Instead this, you can build gateway which you need, just change jumpers position (and if you want to change radio network you have to change radios). I am drawing two examples of using gateway below.
                  • P
                    P
                    pointbre
                    Hi Kalina,
                    Do you stocks now? I'd like to give a try with your RF gateway.
                    • P pointbre
                      Hi Kalina,
                      kalinaK
                      kalinaK
                      kalina
                      #50
                      @pointbre Yes, you can buy MDMSGate by this link. But keep in mind, that NRF24 radio soldered in MDMSGate. If you need RFM69 you have to inform about this and pay additional 2.5$ (because RFM69 more expensive).
                      • R
                        R
                        RonnieMace
                        Thanks for the drawing. I understand that the gateway uses or wifi or 868MHz. If I want both I need 2 gateways and connect them to the raspberry controller. Is my assumption correct?
                        • R RonnieMace
                          kalinaK
                          kalinaK
                          kalina
                          You can use Wi-Fi and 868MHz at the same time, but Wi-Fi is intended for connection to controller only!!! 868MHz is intended for connection to different types of sensors or actuators. You can't establish a connection to any types of sensors via Wi-Fi.
                          No.
                          • P
                            P
                            pointbre
                            HI Kalina, Would you please let me know how I could pay the extra $2.5 for RFM69 module? I'd like to make a purchase today.
                            • P pointbre
                              kalinaK
                              kalinaK
                              kalina
                              @pointbre Hi, i am sending to you a PM. Check it pls in a few minutes...
                              • fisherF
                                fisherF
                                fisher
                                Hi @kalina:
                                Is it possible to buy board only without plastic enclosure?
                                • kalinaK
                                  kalinaK
                                  kalina
                                  Hi @fisher, yes it is possible.
                                  • fisherF
                                    fisherF
                                    fisher
                                    Hi, Finally the parcel from Kalina has arrived. It took two weeks to deliver from Ukraine to Poland (it stuck for 9 days in post office somewhere in Poland)
                                    The gateway works ok, the box enclosure is tiny and looks really good.
                                    I highly reccomend Kalina's goods!
                                    Kalina, thx for your support and for the bonus :)
                                    1_1496086270578_IMG_20170529_205502.jpg 0_1496086270578_IMG_20170529_205441.jpg
                                    • fisherF fisher
                                      kalinaK
                                      kalinaK
                                      kalina
                                      @fisher, Thanks for feedback! :simple_smile:
                                      AnticimexA 1 Reply Last reply
                                      • kalinaK kalina
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @kalina please provide the required documentation for the CERN license. See here if anything is unclear.
                                        • AnticimexA Anticimex
                                          kalinaK
                                          kalinaK
                                          kalina
                                          @Anticimex , I have already uploaded the necessary license files.
