  2. Announcements
  3. Converting a sketch from 1.5.x to 2.0.x
52 Posts 21 Posters 38.0k Views 26 Watching
  • scalzS
    scalzS
    @pascalgauthier
    yes it's better non blocking. for non blocking it's better to use "if" like. for beginning, I advise you to look at "blink without delay" concept. then learning a bit how a state machine works etc...could be useful to you. but it's a bit more advanced, or not..
    pascalgauthierP 1 Reply Last reply
    • scalzS scalz
      @pascalgauthier
      pascalgauthierP
      pascalgauthierP
      pascalgauthier
      @scalz @AWI
      Thanks for your help ! :)
        moskovskiy82
        Little bit confused. reading through the release notes...
        Deprecated variables: V_DIMMER (use V_PERCENTAGE), V_HEATER (use V_HVAC_FLOW_STATE), V_LIGHT (use V_STATUS)
        Now back to the API page for 2.0...
        S_DIMMER	4	Dimmable device of some kind	V_STATUS (on/off), V_DIMMER (dimmer level 0-100), V_WATT
        WHICH ONE TRUST?!
        YveauxY 1 Reply Last reply
          moskovskiy82
          And if my loop statement consists only of
          { gw.process(); }
          Rewrite like
          void loop() { }
          or exclude loop completely?
          • M moskovskiy82
            { gw.process(); }
            Rewrite like
            void loop() { }
            YveauxY
            YveauxY
            @moskovskiy82 said:
            Rewrite like
            void loop() { }
            That's correct
            • M moskovskiy82
              WHICH ONE TRUST?!
              YveauxY
              YveauxY
              @moskovskiy82 said:
              WHICH ONE TRUST?!
              The release notes (as I added this statement ;-) )
              • Maurizio ColluM
                Maurizio ColluM
                Maurizio Collu
                Dear all, I'm a bit lost.
                I upgraded the library in Arduino to 2.0.0 and now I am having big problems.
                I downloaded the sketch for the relay from the MySensors website:
                https://www.mysensors.org/build/relay
                but I suppose this is still for 1.5
                I tried to modify the sketch as suggested - I do not receive any compiling error, but the skectch simply does not do anything. If I use the "monitor" in Arduino IDE, I do not see anything 0_1469262004446_RelayActuator2.ino
                There must be something fundamentally wrong in my code, can anyone help?
                mfalkviddM Boots33B 2 Replies Last reply
                • Maurizio ColluM Maurizio Collu
                  @Maurizio-Collu the examples for 2.0 are included in the library. They can be opened directly fromthe Examples menu in the Arduino IDE. It is also possible to fetch the examples from github, see https://github.com/mysensors/MySensors/tree/development/examples/RelayActuator For the relay example.
                  Maurizio ColluM 1 Reply Last reply
                    Boots33B
                    Boots33B
                    Boots33
                    @Maurizio-Collu
                    You have a few mistakes in your sketch, Download the V2 sketch that @mfalkvidd has pointed you to and compare the two side by side. you will soon see where you have gone wrong. don't forget you will need to update your gateway to V2 as well, a version 1.5 gateway will not connect with a version 2 node.
                      Maurizio ColluM
                      Maurizio ColluM
                      Maurizio Collu
                      @mfalkvidd @Boots33
                      Thanks a lot, I knew I was missing something basic. For the newbies like me, it would be good to mention this somewhere (if you have not done so already and I missed it).
                      In the Home Assistant website it is mentioned that they only support 1.4 and 1.5. I'm trying with 2.0.
                      Thanks Again
                        @mfalkvidd @Boots33
                        Thanks Again
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @Maurizio-Collu
                        2.0 should work with home assistant, but all new features of 2.0 are not supported yet. WIP.
                        • rchampR
                          rchampR
                          rchamp
                          wrote on last edited by rchamp
                          #32
                          I'm trying to upgrade my gateway to 2.0, but every time I go to upload, I get a 'error' not in sync.
                          I'm using just a standard nano w/ NRF24.
                          Note, my hardware profile is set properly to nano, 328p and proper com.
                          I restart app, and switched to my APM hardware profile and loaded my new 2.0 sensor code into my new APM node (DHT11 + motion) and was able to upload no problem.
                          Is there something i'm missing for the gateway?
                          Idon'tunderstandwhatwouldcauseittostopbeingabletocommunicate,
                            Are you able to upload some other sketch to the nano?
                            Or has something bad happen to the FTDI chip on your nano perhaps?
                            rchampR 1 Reply Last reply
                              moskovskiy82
                              Just for clarification. V2.0 gateway (MQTT client esp8266) - will it work with the 1.5/1.6 sensors? Or everything needs to be flashed as soon as possible?
                                rchampR
                                rchampR
                                rchamp
                                @hek it's actually a close nano with an FTDI board connected via serial inputs. I had this directly connected to my Vera, and communication with my old sensors was working just fine.
                                EDIT: Fixed. All in all, it was user error. I was trying to connect through FTDI adapter. I unplugged FTDI board, connected USB directly to nano clone, and upload worked fine.
                                Do I need to update mysensors plugin as well on Vera UI5?
                                  No, shouldn't be necessary.
                                    You could try, but the recommendation is to update the nodes as well.
                                      @Maurizio-Collu
                                      Maurizio ColluM
                                      Maurizio ColluM
                                      Maurizio Collu
                                      @martinhjelmare
                                      Thanks Martin.
                                      I uploaded the GatewaySerial to the arduino working as gateway, but if I upload the sketch and I open the monitor, I obtain this error:
                                      0;255;3;0;9;TSM:INIT
                                      0;255;3;0;9;!TSM:RADIO:FAIL
                                      0;255;3;0;9;!TSM:FAILURE
                                      0;255;3;0;9;TSM:PDT
                                      What does it mean?
                                      Maurizio ColluM martinhjelmareM 2 Replies Last reply
                                        @martinhjelmare
                                        Thanks Martin.
                                        0;255;3;0;9;TSM:PDT
                                        What does it mean?
                                        Maurizio ColluM
                                        Maurizio ColluM
                                        Maurizio Collu
                                        @martinhjelmare
                                        Plus, when starting home assistant, I get this error
                                        16-07-26 23:03:44 homeassistant.bootstrap: Error during setup of component mysensors
                                        Traceback (most recent call last):
                                        File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 62, in setup_gateway
                                        socket.inet_aton(device)
                                        OSError: illegal IP address string passed to inet_aton
                                        During handling of the above exception, another exception occurred:
                                        File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 150, in _setup_component
                                        if not component.setup(hass, config):
                                        File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 109, in setup
                                        device, persistence_file, baud_rate, tcp_port)
                                        File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 73, in setup_gateway
                                        baud=baud_rate)
                                        File "/home/pi/.homeassistant/deps/mysensors/mysensors.py", line 326, in init
                                        persistence_file, protocol_version)
                                        File "/home/pi/.homeassistant/deps/mysensors/mysensors.py", line 40, in init
                                        self.const = _const
                                        UnboundLocalError: local variable '_const' referenced before assignment
                                          @martinhjelmare
                                          baud=baud_rate)
                                          self.const = _const
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          #40
                                          @Maurizio-Collu
                                          Regarding the error in home assistant, that's a bug, due to specifying mysensors version other than 1.4 or 1.5. Use 1.5 and you should be fine. The bug is fixed in the dev branch of pymysensors and will be fixed in home assistant when real mysensors 2.0 support is merged. WIP.
                                          Please post home assistant topics in the home assistant category under controllers. This is off topic in this thread.
