  3. Node only connect to Serial Gateway if DEBUG is enabled in the gateway
1 Posts 1 Posters 800 Views 2 Watching
  • rb3rgR
    rb3rgR
    rb3rg
    I just installed a fresh version MySensors library (2.0.?) and going through some tests here.
    I have a Serial gateway with Nano+nRF24 powered with external +3.3v regulator, with enough juice.
    And a node Nano+nRF24+DHT22.
    Everything works fine “if” I keep the debug enabled (#define MY_DEBUG) in the gateway.
    If I disable debug ( // #define MY_DEBUG) in the gateway then I get an error in the Node:
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=4)
    TSM:FPAR
    TSP:MSG:SEND 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-4 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=4)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    !TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    As i said before, the weird thing is that if debug enabled in the gateway, it works.
    How can I start troubleshooting this issue?
    Thanks.
