  3. Dimmable LED kitchen light (Arduino, APDS-9960, RGBWW led)
arduinoapds-9960
37 Posts 13 Posters 17.1k Views 12 Watching
  • O Offline
    O Offline
    openhardware.io
    https://www.openhardware.io/view/122/Dimmable-LED-kitchen-light-Arduino-APDS-9960-RGBWW-led
    • mfalkviddM Offline
      https://youtu.be/sNI6H9fURsY
      (wasn't able to add the video on the OpenHardware side)
        https://youtu.be/yKYG3J3u9cU
        • S Offline
          @mfalkvidd excellent, nice work :thumbsup:
          • hekH Offline
            hekH Offline
            Wow! That's nice!
            • T Offline
              T Offline
              TheoL
              Love it. Have you tried the APDS-9930? I have them laying around, but haven't got time to try them
              • T TheoL
                @TheoL I didn't know they existed. What's the difference?
                B T 2 Replies Last reply
                  B Offline
                  B Offline
                  BartE
                  @mfalkvidd a video with cool 8 bit music :-) nice
                  • Boots33B Offline
                    Boots33B Offline
                    Boots33
                    Great looking light setup...... now if you could just get the the sensor to control the kids as well I might be able to get them to do the washing up too. ;)
                      T Offline
                      T Offline
                      TheoL
                      @mfalkvidd Haven't checked all details. But for most less accurate but much cheaper. I believe I paid about 8 times less for the 9930 an aliexpress.
                      N 1 Reply Last reply
                      • greglG Offline
                        greglG Offline
                        gregl
                        @mfalkvidd - Nice work.
                        Q: How close to the sensor does your hand need to be? and can this distance be controlled?
                        • T TheoL
                          N Offline
                          N Offline
                          wrote on last edited by Nca78
                          Great project, I have ordered a 9960 and I can't wait to receive it and play with it, this could be a good start.
                          I didn't know about this one, thank you about the information ! From what I see quickly the 9930 is only a proximity detection sensor, it cannot sense movement like the 9960. It can sense distance so it could be used for this application but it has shorter range, 10cm instead of 10 to 20 for the 9960.
                          • Cliff KarlssonC Offline
                            Cliff Karlsson
                            Could this also have been done using a ultrasonic distance sensor?
                            • greglG gregl
                              The sensor starts registering at about 25cm/10in distance and reports maximum proximity at about 5cm/2in (anything closer than that results in a reading of 255).
                              setProximityGain might affect this, but I haven't tried.
                                My experience with the HC-SR04 is that consecutive readings vary too much. A smoothening algorithm (take the median of 5 readings for example) might work, but one reading of the HC-SR04 takes 60 ms which already is 3 times longer than the sample rate I use for the ADPS-9960 so the dimming would probably "stutter" a lot. The speed of sound is simply too slow :)
                                • S Offline
                                  @mfalkvidd - Great work! This is exactly what I had in mind - now i can follow this great example and spare me some hours! Thanks!
                                    I would like to remove the need for holding still to "lock" the light level, but it is a bit hard since the sensor will get several readings while I remove my hand which will set the light level at all sorts of values.
                                    Setting a timeout that "resets" the level to an earlier value when the sensor stops detecting should be possible, but will require some experimenting to get right.
                                    Implementing a PID regulator might be useful as well, but would require revisiting some long forgotten math skills.
                                    Y 1 Reply Last reply
                                      Y Offline
                                      Y Offline
                                      @mfalkvidd Nice project man!
                                      Did you consider protecting the sensor somehow from direct air contact? Kitchen stuff stends to get real greasy over time...
                                      • Y Yveaux
                                        Thanks!
                                        I did not consider that. I think the sensor will sense transparent plastic and glass but I haven't tested, so maybe it is possible to put some protection in front of it.
                                        T 1 Reply Last reply
                                          Thanks!
                                          T Offline
                                          T Offline
                                          TheoL
                                          @mfalkvidd I have so far not been able to cover the sensor. It's very sensitive. So if somebody knows a material that can cover the sensor while keeping it operating, I'll be be much obliged.
