  3. Upgrading to 2.0 sketch dificulty
11 Posts 6 Posters 4.2k Views 4 Watching
  • andmasterA
    andmasterA
    andmaster
    wrote on last edited by andmaster
    Hi all,
    i've been trying for the last few hours to convert a multirelaywithbutton actuator to 2.0 with no sucess...
    the most i get is a "random" id of the relays in domoticz, and the buttons dont work properly..
    As so, i've founded an example in 2.0 but to a single relay.
    the sketch i've found in examples is:
     * Version 1.0 - Henrik Ekblad
     * Example sketch for a "light switch" where you can control light or something
     * else from both HA controller and a local physical button
     * (connected between digital pin 3 and GND).
     * This node also works as a repeader for other nodes
    // Enabled repeater feature for this node
    #define MY_REPEATER_FEATURE
    #include <Bounce2.h>
    #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    MyMessage msg(CHILD_ID,V_LIGHT);
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      pinMode(RELAY_PIN, OUTPUT);
      state = loadState(CHILD_ID);
    void presentation()  {
      sendSketchInfo("Relay & Button", "1.0");
      present(CHILD_ID, S_LIGHT);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          send(msg.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         saveState(CHILD_ID, state);
         // Write some debug info
         Serial.print(message.sensor);
    Can anyone help geting this so i can have:
    4 relays
    4 buttons
    domoticz also controling each one?
    Many thanks in advance.
    mfalkviddM N 2 Replies Last reply
    • andmasterA andmaster
      Hi all,
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue=0;
      bool state;
        // Setup the button
        debouncer.update();
        oldValue = value;
      4 relays
      4 buttons
      @andmaster use the relay example for MySensors 2.0 (which is included with the library) and follow the instructions in the code comments and you should be all set.
      andmasterA 1 Reply Last reply
        andmasterA
        andmasterA
        andmaster
        @mfalkvidd this is the example 😃
          @andmaster no.
          The sketch you posted does not have these instructions:
          • andmasterA
            andmasterA
            andmaster
            @mfalkvidd the example is provided here: https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/RelayWithButtonActuator/RelayWithButtonActuator.ino
            what you are mentioning is the example where you can put multiple relays, but without any button actuator.
            • scalzS
              scalzS
              @andmaster
              in fact @mfalkvidd is right, you have to "mix" the two sketch if you want multi relay with multiple buttons.
              could be fast to do, but i have no time.
              if you want show us your non working sketch, so we can tell what to do ;)
                Hi all,
                #define RELAY_ON 1
                #define RELAY_OFF 0
                int oldValue=0;
                bool state;
                  // Setup the button
                  debouncer.update();
                  oldValue = value;
                4 relays
                4 buttons
                N
                N
                niccodemi
                @andmaster
                I've used below sketch with 1.6 development version; it compiles also with 2.0.0 but I have not tested it. This sketch uses toggle buttons.
                //MultiRelayButton Sketch, MySensors 1.6, toggle switch
                #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
                #define RELAY_OFF 1                     // switch around for ACTIVE LOW / ACTIVE HIGH relay
                #define noRelays 4                     //2-4, define number of relays
                const int relayPin[] = {14,15,16,17};          //  relay pins - should match noRelays
                const int buttonPin[] = {3,4,5,6};      //  button pins - should match noRelays
                class Relay             // relay class, store all relevant data (equivalent to struct)
                public:
                  int buttonPin;                   // physical pin number of button
                  int relayPin;             // physical pin number of relay
                  boolean relayState;               // relay status (also stored in EEPROM)
                Relay Relays[noRelays];
                Bounce debouncer[noRelays];
                MyMessage msg[noRelays];
                void setup(){
                    sendHeartbeat();
                    wait(100);
                    // Initialize Relays with corresponding buttons
                    for (int i = 0; i < noRelays; i++){
                    Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                    Relays[i].relayPin = relayPin[i];
                    msg[i].sensor = i;                                   // initialize messages
                    msg[i].type = V_LIGHT;
                    pinMode(Relays[i].buttonPin, INPUT_PULLUP);
                    wait(100);
                    Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                    digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF);   // and set relays accordingly
                    send(msg[i].set(Relays[i].relayState? true : false));                  // make controller aware of last status
                    wait(50);
                    debouncer[i] = Bounce();                        // initialize debouncer
                    debouncer[i].attach(buttonPin[i]);
                    debouncer[i].interval(20);
                    wait(50);
                      sendSketchInfo("MultiRelayButton", "1.0");
                      wait(100);
                      present(i, S_LIGHT);                               // present sensor to gateway
                      wait(100);
                    for (byte i = 0; i < noRelays; i++) {
                        if (debouncer[i].update()) {
                            digitalWrite(Relays[i].relayPin, Relays[i].relayState?RELAY_ON:RELAY_OFF);
                            // save sensor state in EEPROM (location == sensor number)
                            saveState( i, Relays[i].relayState );
                    wait(20);
                // process incoming message
                void receive(const MyMessage &message){
                   if (message.type == V_LIGHT){
                   if (message.sensor <noRelays){            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                   digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
                   saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                  wait(20);
                andredtsA 1 Reply Last reply
                • andmasterA
                  andmasterA
                  andmaster
                  hi @niccodemi that did the trick.
                  I've made a quick comparison and i guess the issue was that i've defined my button without a proper array.
                  this also has a change i think is important. i had a push button, and i wanted a toggle :)
                  Just made a change. i want relay on to be 1 (high) and off to be 0 (low).
                  This way, it starts every time at 0
                  many thanks!!
                  • N niccodemi
                    @andmaster
                    public:
                    void setup(){
                        sendHeartbeat();
                        wait(100);
                        wait(100);
                        wait(50);
                        wait(50);
                          wait(100);
                          wait(100);
                        wait(20);
                      wait(20);
                    andredtsA
                    andredtsA
                    andredts
                    @niccodemi
                    Hi, I know that this is quite old topic, but only now I´m updating my home from version 1.5.4 to 2.*, most because reability issues. One thing I notice with you skecth is that if by any chance the gateway is not present the nodes can´t be used anymore after a power loss, I mean, one can not use the fisical buttons to switch the relays, because they will not respond. My question is if there is a way to keep the node up with out the gateway, in case it dies?
                    Boots33B 1 Reply Last reply
                    • andredtsA andredts
                      @niccodemi
                      Boots33B
                      Boots33B
                      Boots33
                      @andredts As you have discovered version 2.1 nodes while booting will not proceed to the loop part of the sketch if the gateway is not found. You can however force them to move on. The line of code you need is...
                      #define MY_TRANSPORT_WAIT_READY_MS 3000
                      This code tells the node how long to wait for the uplink to be established before moving on to the rest of the sketch. The number at the end is how long to wait in milliseconds, in this case 3000ms (3 seconds). You can set this to a time of your choosing.
                      if the node establishes the uplink it will move on without any delay.
                      The above line is placed near the top of your sketch somewhere before
                      have a look at these for a bit more detail....
                      MY_TRANSPORT_DONT_CARE_MODE
                      Synchronising Light switch
                      • Boots33B Boots33
                        andredtsA
                        andredtsA
                        andredts
                        @Boots33 Thanks, that was exactly what I needed. Synchronizing was a great bonus.
