  3. [SOLVED] Cannot get GwWS5100MQTT to connect to cloudmqtt.com
9 Posts 5 Posters 5.6k Views 5 Watching
  • bgunnarbB
    bgunnarbB
    bgunnarb
    Hi!
    I have been tinkering with MySensors for a while now and the goal is to build a HA-system using OpenHAB. For that purpose I want to use a public MQTT broker at cloudmqtt.com. I have built the WS5100MQTT client downloaded from GitHub, using an Arduino Nano and MySensors 2.0 API. I have also built and tested a few sensors which work fine.
    It all works fine part from the issue that I cannot get the client to connect to the cloudmqtt server (m21.cloudmqtt.com) It just tries and tries about every second and on the cloudmqtt log I can see the connection attempts. Cloudmqtt assigns various ports and you cannot choose port number. Ports I have used are e.g. 15536 and 19946. They are not SSL ports.
    I have also tried to connect to a test broker at broker.hivemq.com port 1883 and there the client connects immediately and starts publishing topics.
    I have tried both the Arduino 1.6.11 release and now the 1.6.9 release, both on Windows and Mac.
    So, I have reached the end of the road as far as my knowledge goes. Any ideas are appreciated.
    I have never been so busy since I retired!
    • bgunnarbB bgunnarb
      Hi!
      Welcome to the NySensors community @bgunnarb! Does the serial debug output say anything interesting?
      • bgunnarbB
        bgunnarbB
        bgunnarb
        Here is a printout at startup:
        IP: 192.168.1.210
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:RADIO:OK
        0;255;3;0;9;TSM:GW MODE
        0;255;3;0;9;TSM:READY
        IP: 192.168.1.210
        IP: 192.168.1.210
        IP: 192.168.1.210
        IP: 192.168.1.210
        IP: 192.168.1.210
        I am using a fixed IP but have also tried with DHCP without success.
        • bgunnarbB
          bgunnarbB
          bgunnarb
          Here is a copy of the parameter setup in the sketch:
          #define MY_MQTT_USER "xxxxxxxx"
          #define MY_MQTT_PASSWORD "yyyyyyyyy"
          #define MY_IP_ADDRESS 192,168,1,210
          #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
          #define MY_CONTROLLER_URL_ADDRESS "m21.cloudmqtt.com"
          //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 201
          #define MY_PORT 19946
            Could it be something blocking in your router?
            • bgunnarbB
              bgunnarbB
              bgunnarb
              I have tried opening the port e.g. 19946 to tcp-traffic but no change. Should the port be open to udp as well?
              YveauxY 1 Reply Last reply
              • E
                E
                elmezie
                I get the same error, using cloudmqtt and also using a python mqtt broker that i have locally installed. It never completes the connect part. Using 2.0 API
                  YveauxY
                  YveauxY
                  @bgunnarb maybe the mqtt version of the mysensors client is not supported by the broker. I remember a similar issue in the past where RPI contained an older version of mosquitto and that also silently failed.
                  Could also be the reason why it works with one broker and fails on another.
                  Can you find out the mqtt protocol versions supported by the various brokers?
                  bgunnarbB 1 Reply Last reply
                  • YveauxY Yveaux
                    bgunnarbB
                    bgunnarbB
                    bgunnarb
                    @Yveaux I am so terribly embarrassed! In order to rule out something wrong with the WS5100 I rebuilt the GW using an old Arduino UNO with an Ethernet shield. Still same problem. Then to really make sure I pasted/copied username and password from the cloudmqtt into the sketch. Immediate success! It turned out that I had misread an uppercase I (indigo) for a lower case l (lima). Still the suggestions from the community were good since I could iron out one possible cause after another. Thanks for the support!
