  3. 💬 MDMSNode "Lighting"
nrf24l01rfm69arduinomysensorslight switchlightacdc
37 Posts 11 Posters 14.7k Views 10 Watching
  • kalinaK Offline
    kalinaK Offline
    kalina
    Hi, I want to share good news in the my project. Lighting has become more safer.
    Instead the enclosure, I use a heat shrink tubing 3M MDT-A-32/7.5.
    Here's result.
    • jeremushkaJ Offline
      jeremushkaJ Offline
      jeremushka
      Your system works with phase and neutral wires? Will you make it compatible without neutral as well? In my house installation no neutral behind the wall switch only phase. And o the lamp side only neutral and the return wire from the wall switch.
      kalinaK 1 Reply Last reply
      • jeremushkaJ jeremushka
        kalinaK Offline
        kalinaK Offline
        kalina
        wrote on last edited by kalina
        #23
        Yes.
        Actually, no. Why do you plan put this into the wall switch area? As for me, i am going to put "Lighting" near the lamp. Wall switch must be as a push button (normally closed). When you press button circuit opens (on short time) and Atmega328 resets and toggles lamp state. It means that "Lighting" always is conneted to the AC line. You can also change lamp state directly from your controller at any time. See picture below.
        jeremushkaJ 1 Reply Last reply
        • tonnerre33T Offline
          tonnerre33T Offline
          tonnerre33
          wrote on last edited by tonnerre33
          #24
          I didn't know this method ;)
          Do we have a limite time for circuit open ?
          How do you do this in the sketch ?
          Where can we find the sketch ?
          What are the consequences for the components life ?
          With this use, the reboot time will impact the response time bewtween the command and the lamp power , isn't it ?
          • tonnerre33T tonnerre33
            kalinaK Offline
            kalinaK Offline
            kalina
            #25
            Yes, of course. In my opinion, this time we can determine in practice, i don't know how can it be calculated. I haven't done it yet, I will try to do it on weekend.
            I have no answers on this questions, it is certainly disadvantages of this method, but i wont use wall switch very often, i prefer to operate via controller. No need reboot uC in this case.
            • kalinaK kalina
              Yes.
              jeremushkaJ Offline
              jeremushkaJ Offline
              jeremushka
              @kalina : your solution is quite interesting when push button are installed. Yes, i would like to put the system in the wall switch. For the moment, i connect the switch of the house on the arduino. The system is powered by phase and neutral in the garage as behind the switch i had the neutral wire. However, in the house no neutral like on your picture. So, im checking about using leakage current which should be enough to power on the system.... Not sure.
                kalinaK Offline
                kalinaK Offline
                kalina
                @jeremushka said:
                So, im checking about using leakage current which should be enough to power on the >system.... Not sure.
                I would be interested to hear about your results
                • B Offline
                  B Offline
                  bilbolodz
                  How about dimming? Due to lack of "zero crossing detection" it could be a problem!
                  • B bilbolodz
                    #29
                    @bilbolodz see earlier posts in this thread. The node does not support dimming, but it does support zero crossing.
                      jeremushkaJ Offline
                      jeremushka
                      @Kalina, does your project still alive? do you still have some samples for sales ?
                        kalinaK Offline
                        kalinaK Offline
                        kalina
                        #31
                        @jeremushka This project has some shortcomings. For this reason I have released a new, more advanced version - MDMSNode "Lighting" Rev 1.1. If you are interested, I have more than 10 pcs in stock.
                        • kalinaK kalina
                          @kalina would you mind adding a link to the new version in the description of the old one?
                            kalinaK Offline
                            kalinaK Offline
                            kalina
                            @mfalkvidd Easy)) Already done.
                              jeremushkaJ Offline
                              jeremushka
                              @ Kalina: Thanks :) Which kind of shortcomings did you get? load switch issue ? safety issue ?
                                kalinaK Offline
                                kalinaK Offline
                                kalina
                                @jeremushka Please look at the description MDMSNode "Lighting" Rev 1.1, everything is indicated there...
                                • A Offline
                                  A Offline
                                  aramko aramko
                                  Banned
                                  wrote on last edited by aramko aramko
                                  #36
                                  This post is deleted!
                                  • A aramko aramko
                                    kalinaK Offline
                                    kalinaK Offline
                                    kalina
                                    Hi @aramko-aramko.
                                    Unfortunately, this model is already sold. You can look at the upgraded version of this device - MDMSNode "Lighting" Rev 1.1.
