  3. NodeMcu & NRF WiFi connection issue
1 Posts 1 Posters 1.3k Views 1 Watching
  • J
    J
    jeti
    Hi Guys,
    i do have right now a problem with me NodeMcu NRF Gateway,
    it was working for some time ok but after one reboot (yes it did work before) i did not come back up this is the code i am using:
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
     * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
     * LED purposes:
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
     * GND        GND
      * Inclusion mode button:
    #include <EEPROM.h>
    #define MY_BAUD_RATE 9600
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "correctnetwork"
    #define MY_ESP8266_PASSWORD "correctpassword"
    // Enable UDP communication
    //#define MY_USE_UDP
    // #define MY_ESP8266_HOSTNAME "wifi-sensor-gateway"
    #define MY_IP_ADDRESS 192,168,1,81
    #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 77
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
      #include <WiFiUDP.h>
    #else
      #include <ESP8266WiFi.h>
    void presentation() {
    and this is the seriel monitor output:
    0‚~?–4“Ò¶£ÿOK Zþû0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 7
    cnt
    chg_B1:-40
    connected with jandj, channel 11
    dhcp client start...
    0;255;3;0;9;TSM:READY
    f r-40, scandone
    ...................pm open,type:2 0
    The dotted ilne will go forever
    It seams that it still wants to get a DHCP adress which i do not want.
    I already tried using older ESP Versions in the Board Manager but this resulted in a error during compiling
    I also did a eeprom clean with the Mysensors: ClearEepromConfig.ino
    A normal blinking scetch does work on the NodeMcu
    Any ideas?
    thanks
