  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 225.9k Views 53 Watching
  • G
    G
    Gilles BILLARD
    wrote on last edited by Gilles BILLARD
    #321
    Hy guys; So sorry but the procedure ran just once :-/
    When I reproammed my soldred Pro-Minis (via the radio socket + 1 air wire to the reset pin) none was running as expected; The issue was a kind of permanent reboot..????
    I tried to burn the MinCore bootloader and load my sketch into several brand new boards and the result was the same...
    So I simplified and simplified again the sketches until this one:
    /*This sketch is cycling wether you comment MY-DEBUG.....
    SERIAL MONITOR report:
              2021-04-04 17:20:04.426 Status: MySensors: Node: 20, Sketch Name: Temperature Sensor Test
              2021-04-04 17:20:04.426 Status: MySensors: Node: 20, Sketch Version: G.B.
              2021-04-04 17:20:15.378 (GiBi-Home) Temp (Temptest)
              2021-04-04 17:20:15.368 Status: MySensors: Node: 20, Sketch Name: Temperature Sensor Test
              2021-04-04 17:20:15.368 Status: MySensors: Node: 20, Sketch Version: G.B.
    ......or running as it should do if you uncomment MY-DEBUG
              2021-04-04 17:22:52.558 Status: MySensors: Node: 20, Sketch Name: Temperature Sensor Test
              2021-04-04 17:22:52.558 Status: MySensors: Node: 20, Sketch Version: G.B.
              2021-04-04 17:23:02.654 (GiBi-Home) Temp (Temptest)
              2021-04-04 17:23:12.717 (GiBi-Home) Temp (Temptest)
              2021-04-04 17:23:22.781 (GiBi-Home) Temp (Temptest)
    NOTA: wether bootLoader is ordinary AVR bootloader or MiniCore's one
    //#define MY_DEBUG
    #define MY_RADIO_RF24
    #include <OneWire.h>
    #define ONE_WIRE_BUS 3 // Pin E/S de mesure
    OneWire oneWire(ONE_WIRE_BUS); // Instanciation du OneWire
    DallasTemperature sensors(&oneWire); // Passage de l'instance du OneWire à Dallas Temperature.
    MyMessage msg(0,V_TEMP); // Init temp msg
    void before()
        sensors.begin();// démarre le OneWire
      sendSketchInfo("Temperature Sensor Test", "GB.1.0");
      present(0, S_TEMP);
        float (temperature) = sensors.getTempCByIndex(0);   // acquisition du résultat
        temperature = float(int(temperature * 10)) / 10;    // cast pour 1 seul chiffre après la virgule
        send(msg.setSensor(0).set(temperature,1));
        sensors.requestTemperatures(); // ordre de mesure
        // ************Sleeping test ***************
        #ifdef MY_DEBUG
            delay(10000); // 10 secondes
        #else
            sleep(10000);
    and then this one
    // Simplest test to to highlight my problèm
    // Ordinary delay function used on DEBUG
    // Sleep is used without DEBUG
    // Successiv Serial prints should be printed if loop entered
     Without DEBUG Serial monitor screen copy
     ⸮⸮ `_⸮       ⸮ߟ⸮
    ⸮  ⸮o  ⸮⸮   ⸮/ _⸮⸮⸮` ⸮⸮⸮ ⸮ ⸮⸮ `ߟ⸮  ⸮⸮⸮  ⸮ ⸮⸮`⸮⸮⸮
    ⸮ ⸮⸮/⸮ ⸮ ⸮ ⸮ ⸮_⸮⸮ ⸮ / ⸮ ⸮ `⸮ ⸮/ ⸮⸮⸮/ ⸮`⸮⸮ ⸮⸮⸮/ ⸮⸮⸮
    ⸮⸮⸮  ⸮_⸮⸮⸮⸮, |⸮_⸮⸮/ ⸮⸮ߟ⸮⸮⸮ ⸮⸮⸮_⸮⸮/⸮⸮⸮_/⸮⸮⸮  ⸮⸮⸮⸮/
            ⸮⸮ߟ/`                    `2.3.2
    ⸮é⸮u⸮ ⸮⸮ ⸮⸮⸮⸮
     ⸮⸮  ⸮⸮       ⸮ߟ⸮
    ⸮  ⸮/  ⸮⸮   ⸮/ ⸮⸮⸮⸮  ⸮⸮⸮ ⸮ ⸮⸮  ߟ⸮  ⸮⸮⸮  ⸮ ⸮⸮ ⸮_⸮
    ⸮ ⸮⸮/⸮ ⸮ ⸮`⸮ ܟ⸮⸮ ⸮ / ⸮ ⸮ ⸮⸮`⸮/`⸮⸮⸮/ ⸮ ⸮⸮ ⸮ߟ/ ⸮⸮⸮
    ⸮`⸮ `⸮`⸮ ⸮⸮⸮ ⸮⸮⸮⸮⸮ ⸮ `ߟ/ ⸮`⸮`ܟ⸮ ⸮ `⸮` ⸮ ⸮  ܟ⸮ ⸮
    ⸮⸮⸮ `⸮⸮⸮⸮⸮⸮, ⸮⸮⸮⸮⸮/ ⸮⸮ߟ⸮⸮⸮ ⸮⸮⸮⸮ߟ/ܟ⸮⸮o⸮⸮⸮` ⸮⸮⸮⸮o
     `  ` ` ⸮⸮ߟo`` `  `  `  ``        2.3.2
    ⸮⸮i⸮⸮⸮`⸮⸮`⸮⸮⸮⸮
    ⸮  ⸮/` ⸮⸮ ` ⸮/ ⸮ߟ⸮  ⸮⸮⸮`⸮ ߟ `⸮ߟ `⸮⸮⸮ `⸮`⸮⸮ ⸮ߟ
    ⸮ ⸮⸮/⸮ ⸮ ⸮ ⸮ ⸮ߟ⸮ ⸮ / ⸮ ⸮ ⸮⸮ ⸮o`ߟ⸮/`⸮`⸮⸮ ⸮ߟo ⸮⸮⸮
    ⸮`⸮  ⸮ ⸮ ⸮⸮⸮ ⸮_⸮⸮⸮`⸮``⸮⸮/`⸮ ⸮ ⸮⸮⸮ ⸮ `⸮` ⸮`⸮ `⸮ߟ`⸮
    ⸮⸮⸮` ⸮⸮⸮⸮ߟl`⸮⸮⸮⸮⸮o`⸮ߟ⸮⸮⸮⸮ ⸮⸮⸮ߟ⸮/⸮⸮⸮⸮o⸮⸮⸮ `⸮⸮⸮⸮/
     `      ⸮⸮⸮⸮/   `   ``` ```        2.3.r
    etc....
    * With DEBUG Serial monitor screen copy
    ⸮  ⸮/  ⸮⸮`  ⸮/ ⸮⸮⸮⸮  ߟ⸮`⸮ ⸮⸮` ⸮⸮⸮  ߟ⸮` ⸮ ⸮⸮`⸮⸮⸮
    ⸮ ⸮⸮o⸮ ⸮ ⸮ ⸮ ⸮_⸮⸮ \ / ⸮ ⸮ ⸮_ ⸮/ ⸮⸮⸮/ ⸮ ⸮| ⸮⸮⸮o ⸮⸮⸮
    ⸮ ⸮` ⸮`⸮ ⸮⸮⸮ ⸮⸮_⸮⸮ ⸮  ⸮⸮/ ⸮ ⸮ ⸮⸮⸮`⸮  ⸮ `⸮`⸮` ⸮ߟ ⸮
    ⸮⸮⸮` ⸮⸮⸮ܟ⸮,`⸮⸮ߟ⸮o ⸮ߟ⸮⸮⸮⸮`⸮⸮⸮⸮⸮⸮/\⸮⸮⸮o⸮⸮⸮` ⸮ߟ⸮/
            ⸮ߟ⸮/ ` ` `                2.3.2
    16 ̓⸮:⸮⸮⸮:⸮Ή⸮`⸮⸮⸮⸮,⸮⸮=⸮Ύ΁---,⸮Q=8,⸮⸮⸮=2u5,⸮E⸮=2.3.2
    28 ⸮⸮⸮:⸮⸮⸮⸮
    28 T⸮⸮:⸮⸮⸮:⸮⸮=0
    s6`⸮⸮⸮:⸮Ή⸮:⸮Ӑ ⸮⸮
    38`⸮⸮⸮:⸮I⸮:⸮K,⸮D=25
    40 ⸮⸮⸮z⸮Ё⸮
    45 ?⸮⸮⸮z⸮⸮⸮:⸮⸮⸮⸮,25-25-255-255,⸮=255,⸮=3,⸮=7,⸮t=0,l=0,⸮⸮}0l⸮⸮}0,⸮⸮=⸮⸮:
    10t0`ԓ⸮:⸮⸮⸮:⸮⸮⸮⸮,0-0-25,⸮=255,⸮}3,⸮=x,⸮⸮=1,⸮=1,sg=0:0
    1046 T⸮⸮:⸮⸮⸮:⸮⸮⸮R ⸮⸮,Ʉ=0,⸮=1
    20u4 ⸮⸮⸮:⸮Ё⸮zϋ
    2054 ⸮S⸮:⸮⸮
    2056 ⸮⸮⸮:⸮⸮:⸮⸮
    2058 ԓ⸮:⸮Ќ
    2064 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255l⸮=s,⸮}24l⸮⸮=1,⸮=q,⸮⸮=0,⸮⸮=0l⸮⸮=⸮⸮:1
    2076 ⸮⸮⸮:⸮S⸮:⸮⸮⸮⸮,0-0-25,⸮=255l⸮=3,⸮=25,⸮⸮=1,⸮=1,⸮⸮=0:1
    2082 ⸮S⸮:⸮⸮⸮:⸮⸮⸮⸮ ⸮⸮C⸮,H⸮=1
    2084 ⸮⸮⸮zՐ⸮z⸮⸮
    2086 ⸮⸮⸮:⸮⸮⸮ę:⸮⸮=25,⸮⸮⸮=0,⸮⸮⸮=1
    2099 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255,⸮=3,t=15,⸮⸮=6,⸮=2,⸮⸮=0,⸮⸮=0,⸮⸮=⸮⸮:0100
    2107 ⸮S⸮:⸮Ӈ:⸮Ł⸮,0-0-25,⸮=255,⸮=3,⸮=q5,⸮⸮}6l⸮}2,⸮⸮}0z0q00
    2117 ⸮⸮⸮:⸮Ӈ:⸮Ŏ⸮,ru-25-0m0,⸮=255,⸮=0,⸮=17,⸮⸮=0,⸮}5,⸮⸮}p,⸮⸮=p,⸮⸮}⸮⸮:2.3.2
    21r9 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255,⸮=3,⸮=6,⸮⸮=1,⸮=1,⸮⸮}0,⸮⸮=0l⸮⸮=⸮⸮:p
    2142 ⸮⸮⸮:M⸮⸮:⸮E⸮⸮,p-p-25,⸮=255,⸮}sl⸮}vl⸮⸮}0,⸮=1,s⸮=0:⸮
    2154 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=r55,⸮=3,⸮=11,⸮⸮=0,⸮}9,⸮⸮=0l⸮⸮=0,⸮⸮}⸮⸮z⸮⸮⸮⸮ ⸮⸮⸮⸮
    r1v6 ⸮⸮⸮:⸮⸮⸮:⸮⸮⸮⸮,25m25-0-0l⸮=r55,⸮=3,⸮=12,pt=0,⸮}6l⸮⸮=p,⸮⸮=0,⸮⸮=⸮⸮:⸮⸮.2np
    217t ̓⸮z⸮⸮⸮:⸮⸮Q
    2179 ⸮⸮⸮:M⸮⸮:⸮⸮⸮⸮,25-25-0-0,⸮=255,⸮=3,⸮=26,⸮⸮=1,l=1,⸮⸮=0,⸮⸮=0,⸮⸮}ϋ:2
    2187 ԓ⸮:͓⸮:⸮Ł⸮,p-0m2u,⸮=25u,⸮}3,⸮=27l⸮⸮=1,l=1,⸮⸮=0z1
    r1ys ⸮⸮⸮:Љ⸮z⸮⸮ą`⸮Ň=q
    2q97`⸮⸮⸮:⸮G⸮:⸮T⸮
    2199 ̓⸮z‡⸮:⸮⸮⸮T ⸮⸮,⸮⸮⸮=1
      Serial.begin(115200);
      Serial.println ("Début du test");
      sendSketchInfo("Test Prgm", "GB.2.0"); // Send the sketch version information to the gateway and Controller
    Serial.print (":.");
    #ifdef MY_DEBUG
    #else
            sleep(10000);
    I have included the Domoticz log in the 1st one and the serial monitor report for the 2nd.
    You can see, if "delay(xxx)" is in use, all's Okay, but if "sleep(xxx) is employed, the sketch is cycling in both sketches....
    What is happening?
    Prog.setup
    Test setup
    YveauxY 1 Reply Last reply
    • G Gilles BILLARD
      //#define MY_DEBUG
      void before()
        present(0, S_TEMP);
          #ifdef MY_DEBUG
          #else
              sleep(10000);
      and then this one
       ⸮⸮ `_⸮       ⸮ߟ⸮
              ⸮⸮ߟ/`                    `2.3.2
      ⸮é⸮u⸮ ⸮⸮ ⸮⸮⸮⸮
       ⸮⸮  ⸮⸮       ⸮ߟ⸮
      ⸮⸮i⸮⸮⸮`⸮⸮`⸮⸮⸮⸮
      etc....
              ⸮ߟ⸮/ ` ` `                2.3.2
      28 ⸮⸮⸮:⸮⸮⸮⸮
      28 T⸮⸮:⸮⸮⸮:⸮⸮=0
      s6`⸮⸮⸮:⸮Ή⸮:⸮Ӑ ⸮⸮
      38`⸮⸮⸮:⸮I⸮:⸮K,⸮D=25
      40 ⸮⸮⸮z⸮Ё⸮
      20u4 ⸮⸮⸮:⸮Ё⸮zϋ
      2054 ⸮S⸮:⸮⸮
      2056 ⸮⸮⸮:⸮⸮:⸮⸮
      2058 ԓ⸮:⸮Ќ
      2084 ⸮⸮⸮zՐ⸮z⸮⸮
      217t ̓⸮z⸮⸮⸮:⸮⸮Q
      2q97`⸮⸮⸮:⸮G⸮:⸮T⸮
      #ifdef MY_DEBUG
      #else
              sleep(10000);
      What is happening?
      Prog.setup
      Test setup
      YveauxY
      YveauxY
      @Gilles-BILLARD what pro minis are you using? The 3v3 version only goes to 57600 baud, so 115200 is likely too much
      G 1 Reply Last reply
      • YveauxY Yveaux
        G
        G
        Gilles BILLARD
        @Yveaux Yes Yveaux, you're probably righ, but, if I use AVR bootloader and Test Nb 2 the serial monitor says:
         __  __       ____
                |___/                      2.3.2
        16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=255,VER=2.3.2
        28 TSM:INIT
        28 TSF:WUR:MS=0
        36 TSM:INIT:TSP OK
        38 TSF:SID:OK,ID=20
        40 TSM:FPAR
        45 ?TSF:MSG:SEND,20-20-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        657 TSF:MSG:READ,0-0-20,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        663 TSF:MSG:FPAR OK,ID=0,D=1
        2054 TSM:FPAR:OK
        2054 TSM:ID
        2056 TSM:ID:OK
        2058 TSM:UPL
        2062 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2070 TSF:MSG:READ,0-0-20,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2076 TSF:MSG:PONG RECV,HP=1
        2080 TSM:UPL:OK
        2082 TSM:READY:ID=20,PAR=0,DIS=1
        2086 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2095 TSF:MSG:READ,0-0-20,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        2105 TSF:MSG:SEND,20-20-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
        2115 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        2125 TSF:MSG:READ,0-0-20,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        2134 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=OK:Test Prgm
        2146 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=12,pt=0,l=6,sg=0,ft=0,st=OK:GB.2.0
        2154 MCO:REG:REQ
        2156 TSF:MSG:SEND,20-20-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        2164 TSF:MSG:READ,0-0-20,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        2170 MCO:PIM:NODE REG=1
        2174 MCO:BGN:STP
        Début du test
        2177 MCO:BGN:INIT OK,TSP=1
        and Domoticz log is:
        2021-04-08 08:08:24.328 Status: MySensors: Node: 20, Sketch Name: Test Prgm
        2021-04-08 08:08:24.329 Status: MySensors: Node: 20, Sketch Version: GB.2.0
        NB: On the Sérial monitor, only the last line matters
        One more point: Once the Pro-Minis are burnt with MiniCore library, I'm not able to revert on standard AVR bootloader; They are somehow bricked on MiniCore bootloader
        G skywatchS 2 Replies Last reply
        • G Gilles BILLARD
           __  __       ____
                  |___/                      2.3.2
          28 TSM:INIT
          28 TSF:WUR:MS=0
          36 TSM:INIT:TSP OK
          38 TSF:SID:OK,ID=20
          40 TSM:FPAR
          2054 TSM:FPAR:OK
          2054 TSM:ID
          2056 TSM:ID:OK
          2058 TSM:UPL
          2080 TSM:UPL:OK
          2154 MCO:REG:REQ
          2174 MCO:BGN:STP
          Début du test
          G
          G
          Gilles BILLARD
          @Gilles-BILLARD
          Update: Today, using Arduino UNO as ISP (instead of a ProMini as ISP), I was able to "unbrick" one Pro-Mini and revert to standard AVR bootloader
          • G Gilles BILLARD
             __  __       ____
                    |___/                      2.3.2
            28 TSM:INIT
            28 TSF:WUR:MS=0
            36 TSM:INIT:TSP OK
            38 TSF:SID:OK,ID=20
            40 TSM:FPAR
            2054 TSM:FPAR:OK
            2054 TSM:ID
            2056 TSM:ID:OK
            2058 TSM:UPL
            2080 TSM:UPL:OK
            2154 MCO:REG:REQ
            2174 MCO:BGN:STP
            Début du test
            skywatchS
            skywatchS
            skywatch
            #325
            @Gilles-BILLARD Something is not right with either your set up (wiring etc), settings or installation of arduino IDE/libraries.
            I just tested a 3V pro mini and was able to to back and forth freely between MiniCore and AVR bootloaders without issue. Two blinks for Minicore and one blink for AVR.
            A USB programmer is usually cheaper than an uno, so why not try one and see. That is what I use and the only difference is less cabling and only one arduino in the mix.
            In one photo you show nrf24 - are you using FOTA? Is this connected when bootloading the chip?
            The error you described a week ago about optiboot should not happen and you should not need to change anything. Try reinstalling the MiniCore library again following the instructions to the letter. Have you in any way modified your boards.txt or changed your arduino ide from default settings or installation path in any way?
            G 2 Replies Last reply
            • skywatchS skywatch
              G
              G
              Gilles BILLARD
              #326
              @skywatch When I try to use the red ISP (based on a FT232R ) you can see on the pictures I joined, I receive an error msg like :
              avrdude: Version 6.3-20201216
                       Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                       Copyright (c) 2007-2014 Joerg Wunsch
                       System wide configuration file is "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/avrdude.conf"
                       Using Port                    : usb
                       Using Programmer              : usbasp
              avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
              avrdude done.  Thank you
              That is the reason why I used or Po-Mini Or UNO as ISP.
              I tried to change and test many others drivers for my FTDI (for 2 days) unsuccessfully
              are you using FOTA? Is this connected when bootloading the chip? As you can see on one picture, in the programming section, NRF is NOT wired to the programmed Pro-Mini.
              Neither it was when I tried to reprogram the wired Pro-mini because I was using the NRF socket to acces the Arduino pins.
              .....or installation of arduino IDE/libraries I checked that as well and installed the new Adruino IDE 2.0.0 beta.... same problèms :-//
                G
                G
                Gilles BILLARD
                @skywatch said in 💬 Battery Powered Sensors:
                ....... Two blinks for Minicore and one blink for AVR.....>
                Thay is not my case; 1 blink for AVR and NO BLINK for MiniCore !?!?!?
                • G Gilles BILLARD
                  G
                  G
                  Gilles BILLARD
                  @Gilles-BILLARD Now it is OKay with that blinks; 1 for AVR boot and 2 for MiniCore and I can revert from one to the other and vice-versa.
                  ( I removed all concerning MiniCore and reload it )
                  But sleep() is still giving the same issue
                  skywatchS 1 Reply Last reply
                  • G Gilles BILLARD
                    skywatchS
                    skywatchS
                    skywatch
                    #329
                    @Gilles-BILLARD You remembered to connect the nrf before going to sleep?
                      G
                      G
                      Gilles BILLARD
                      #330
                      skywatch: You remembered to connect the nrf before going to sleep?
                      @skywatch Yes, of course;
                      I'm 67, retired, and after 9 days (part time) on this issue, I give up !
                      I am therefore torn between crushing all that stuff between between a big hammer and my anvil or to discard everything to the trash can.
                      These sensors are useless if consuming 20mA H24-7/7 because they they should normally be used outside (in my greenhouses) powered by a battery 18650 + a solar cell.
                      • G
                        G
                        Gilles BILLARD
                        #331
                        Can anyone let me know if he sees something wrong in that log after a Min-Core bootloader burn in a Pro-Mini 3.3v
                        (I do not!)
                        I ask because it not the same file as the 1st one (the 1st was including the nb "115200" (bauds?) and now it is "38400" )
                        NOTA: Directory is this one:
                        C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1\bootloaders\optiboot_flash\bootloaders\atmega328p\8000000L
                                 Using Port                    : COM8
                                 Using Programmer              : stk500v1
                                 Overriding Baud Rate          : 19200
                                 AVR Part                      : ATmega328P
                                 Chip Erase delay              : 9000 us
                                 PAGEL                         : PD7
                                 BS2                           : PC2
                                 RESET disposition             : dedicated
                                 RETRY pulse                   : SCK
                                 serial program mode           : yes
                                 parallel program mode         : yes
                                 Timeout                       : 200
                                 StabDelay                     : 100
                                 CmdexeDelay                   : 25
                                 SyncLoops                     : 32
                                 ByteDelay                     : 0
                                 PollIndex                     : 3
                                 PollValue                     : 0x53
                                 Memory Detail                 :
                                                          Block Poll               Page                       Polled
                                   Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                                   eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
                                   flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
                                   lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                   hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                   efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                   lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                   calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                                   signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                                 Programmer Type : STK500
                                 Description     : Atmel STK500 Version 1.x firmware
                                 Hardware Version: 2
                                 Firmware Version: 1.18
                                 Topcard         : Unknown
                                 Vtarget         : 0.0 V
                                 Varef           : 0.0 V
                                 Oscillator      : Off
                                 SCK period      : 0.1 us
                        avrdude: AVR device initialized and ready to accept instructions
                        Reading | ################################################## | 100% 0.04s
                        avrdude: Device signature = 0x1e950f (probably m328p)
                        avrdude: erasing chip
                        avrdude: reading input file "0x3f"
                        avrdude: writing lock (1 bytes):
                        Writing | ################################################## | 100% 0.02s
                        avrdude: 1 bytes of lock written
                        avrdude: verifying lock memory against 0x3f:
                        avrdude: load data lock data from input file 0x3f:
                        avrdude: input file 0x3f contains 1 bytes
                        avrdude: reading on-chip lock data:
                        Reading | ################################################## | 100% 0.02s
                        avrdude: verifying ...
                        avrdude: 1 bytes of lock verified
                        avrdude: reading input file "0b11111111"
                        avrdude: writing efuse (1 bytes):
                        avrdude: 1 bytes of efuse written
                        avrdude: verifying efuse memory against 0b11111111:
                        avrdude: load data efuse data from input file 0b11111111:
                        avrdude: input file 0b11111111 contains 1 bytes
                        avrdude: reading on-chip efuse data:
                        avrdude: 1 bytes of efuse verified
                        avrdude: reading input file "0b11011110"
                        avrdude: writing hfuse (1 bytes):
                        avrdude: 1 bytes of hfuse written
                        avrdude: verifying hfuse memory against 0b11011110:
                        avrdude: load data hfuse data from input file 0b11011110:
                        avrdude: input file 0b11011110 contains 1 bytes
                        avrdude: reading on-chip hfuse data:
                        avrdude: 1 bytes of hfuse verified
                        avrdude: reading input file "0xe2"
                        avrdude: writing lfuse (1 bytes):
                        avrdude: 1 bytes of lfuse written
                        avrdude: verifying lfuse memory against 0xe2:
                        avrdude: load data lfuse data from input file 0xe2:
                        avrdude: input file 0xe2 contains 1 bytes
                        avrdude: reading on-chip lfuse data:
                        Reading | ################################################## | 100% 0.01s
                        avrdude: 1 bytes of lfuse verified
                        avrdude done.  Thank you.
                                 Using Port                    : COM8
                                 PAGEL                         : PD7
                                 BS2                           : PC2
                                 RETRY pulse                   : SCK
                                 Timeout                       : 200
                                 StabDelay                     : 100
                                 CmdexeDelay                   : 25
                                 SyncLoops                     : 32
                                 ByteDelay                     : 0
                                 PollIndex                     : 3
                                 PollValue                     : 0x53
                                 Memory Detail                 :
                                 Hardware Version: 2
                                 Topcard         : Unknown
                                 Vtarget         : 0.0 V
                                 Varef           : 0.0 V
                                 Oscillator      : Off
                                 SCK period      : 0.1 us
                        Reading | ################################################## | 100% 0.05s
                        avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
                                 To disable this feature, specify the -D option.
                        avrdude: reading input file "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex"
                        avrdude: writing flash (32768 bytes):
                        Writing | ################################################## | 100% 0.00s
                        avrdude: 32768 bytes of flash written
                        avrdude: verifying flash memory against C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
                        avrdude: load data flash data from input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
                        avrdude: input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex contains 32768 bytes
                        avrdude: reading on-chip flash data:
                        Reading | ################################################## | 100% 0.00s
                        avrdude: 32768 bytes of flash verified
                        avrdude: reading input file "0x0f"
                        Writing | ################################################## | 100% 0.05s
                        avrdude: verifying lock memory against 0x0f:
                        avrdude: load data lock data from input file 0x0f:
                        avrdude: input file 0x0f contains 1 bytes
                        • G Gilles BILLARD
                          skywatchS
                          skywatchS
                          skywatch
                          #332
                          @Gilles-BILLARD I understnad your frustration - I have been there myself.
                          I suggest s simple node to test with, something like the door/window sensor with just one switch.
                          Take your promini, remove leds and power regulator (or cut tracks) then burn MiniCore bootloader with 9600 baud, 3.3V, 8MHz INTERNAL, BoD DISABLED.
                          Then add the radio module (you can try another if you have it - what radio modules are you using? - A link or photo might help, there are bad ones and fakes that could be a problem for you). Load your sketch and try again.
                          You can measure the current to the whole set up and then just the radio to see if radio is not sleeping. ....
                            G
                            G
                            Gilles BILLARD
                            #333
                            I'll do that, but for my thermal sensor the test cannot be more simple
                            ......burn MiniCore bootloader with 9600 baud, 3.3V, 8MHz INTERNAL, BoD DISABLED.
                            I don't have the choice for the baud rate; Where is it located ?
                            I swaped everything I could. (The radio modules that was connected to the single functionning sensor included)
                            Bought from Aliexpress;
                            I have done the whole process hundreds and hundreds of time
                            Yes I'll do that...
                            • G Gilles BILLARD
                              Yes I'll do that...
                              skywatchS
                              skywatchS
                              skywatch
                              @Gilles-BILLARD It's in the sketch when you start serial interface. As an aside have you checked the baud rate the pro mini or uno you are using as a programmer - maybe it is 115200 and that is optimistic for a 3.3V board. Make sure the programmer is using 19200 just to be safe.
                              For inof I am using arduino ide 1.8.13 and musensors 2.3.2 with a £2 aliexpress serial prgrammer and have only encountered warnings about sck (which can safely be ignored)....
                              • G Gilles BILLARD
                                Yes I'll do that...
                                skywatchS
                                skywatchS
                                skywatch
                                @Gilles-BILLARD said in 💬 Battery Powered Sensors:
                                That is not much help.
                                  G
                                  G
                                  Gilles BILLARD
                                  #336
                                  Ha, OKay; I've aslo supposed a pb from that, so I removed the sérial monitor and baud rate config.
                                  And after the bootlaoder burning, the log is OKay.. the MEGA328P ID is also the good one and always the same for all 328
                                    G
                                    G
                                    Gilles BILLARD
                                    @skywatch
                                    1 board
                                    Radio : https://www.amazon.fr/NRF24L01-antenne-module-emetteur-recepteur-sans/dp/B01FLVTY3G/ref=sr_1_21?dchild=1&hvadid=80470576921758&hvbmt=be&hvdev=c&hvqmt=e&keywords=nrf2401&qid=1618066959&sr=8-21
                                      G
                                      G
                                      Gilles BILLARD
                                      ...........have you checked the baud rate the pro mini or uno you are using as a programmer - maybe it is 115200 and that is optimistic for a 3.3V board.
                                      The programmer is loaded with standard Arduino ISP sketch (19200 default baud rate)
                                        G
                                        G
                                        Gilles BILLARD
                                        #339
                                        I did that right away and the result is....
                                        All's OKay without sleep(xxx):
                                        2021-04-10 17:38:22.898 Status: MySensors: Node: 52, Sketch Name: Temperature Sensor Sleep
                                        2021-04-10 17:38:22.899 Status: MySensors: Node: 52, Sketch Version: GB.3.0
                                        2021-04-10 17:40:25.515 (GiBi-Home) Light/Switch (Security Sensor)
                                        2021-04-10 17:40:31.277 (GiBi-Home) Light/Switch (Security Sensor)
                                        Présentation then 2 minutes until I change the input twice
                                        But with sleep() included...
                                        2021-04-10 17:34:12.251 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                                        2021-04-10 17:34:12.251 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                                        2021-04-10 17:34:22.491 (GiBi-Home) Light/Switch (Security Sensor)
                                        2021-04-10 17:34:22.486 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                                        2021-04-10 17:34:22.486 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                                        2021-04-10 17:34:32.561 (GiBi-Home) Light/Switch (Security Sensor)
                                        2021-04-10 17:34:32.556 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                                        2021-04-10 17:34:32.556 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                                        2021-04-10 17:34:42.631 (GiBi-Home) Light/Switch (Security Sensor)
                                        2021-04-10 17:34:42.626 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                                        2021-04-10 17:34:42.626 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                                        2021-04-10 17:34:52.701 (GiBi-Home) Light/Switch (Security Sensor)
                                        2021-04-10 17:34:52.696 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                                        2021-04-10 17:34:52.696 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                                        2021-04-10 17:35:02.772 (GiBi-Home) Light/Switch (Security Sensor)
                                        2021-04-10 17:35:02.767 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                                        2021-04-10 17:35:02.767 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                                        2021-04-10 17:35:12.842 (GiBi-Home) Light/Switch (Security Sensor)
                                        2021-04-10 17:35:12.837 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                                        2021-04-10 17:35:12.837 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                                        2021-04-10 17:35:22.913 (GiBi-Home) Light/Switch (Security Sensor)
                                        2021-04-10 17:35:22.908 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                                        2021-04-10 17:35:22.908 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                                        2021-04-10 17:35:32.984 (GiBi-Home) Light/Switch (Security Sensor)
                                        2021-04-10 17:35:32.979 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                                        2021-04-10 17:35:32.980 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                                        2021-04-10 17:35:43.055 (GiBi-Home) Light/Switch (Security Sensor)
                                        The same kind of reboot up to présentation()
                                        So sad !
                                        NOTA: The sketch is the one provided as an example in BinarySwitchSensor.ino sketch
                                        I've just added sleep( 10000) a the very end.
                                        • G
                                          G
                                          Gilles BILLARD
                                          Please, have a look at the time stamps:
                                          Tests vs sleep time
                                          More or less 10 seconds if sleep time >= 10 000 ms
                                          Only a little more than 3 sec if sleep time = 2 000 ms
                                          Could it help ?
