  2. Announcements
  • eyesoftE
    eyesoftE
    eyesoft
    @Oli ... try :
    ./configure
    make
    sudo make install
    • OliO
      OliO
      Oli
      @eyesoft same errors
      jirmJ 1 Reply Last reply
      • eyesoftE
        eyesoftE
        eyesoft
        @Oli see commands above how to Install and Build, with git checkout master you are on master if you :
        cat README.md
        MySensors Library v2.1.0
        default on git clone you are on development :
        cat README.md
        MySensors Library v2.2.0-beta
        • OliO Oli
          jirmJ
          jirmJ
          jirm
          wrote on last edited by jirm
          #224
          @Oli First you need delete all Mysensors directory on your machine.
          Then use step by step the guide on Mysensors Gateway installation process:
          https://www.mysensors.org/build/raspberry
          Dont forget put command sudo on sentences if needed.
          Regards
          • OliO
            OliO
            Oli
            I wanna update not to re install of MySensors. I thought about something like ./updaterelease or ./updatebeta... I spend hours of make it work before, so I leave it as it is. No time or nerves for fighting next couple of days.
            mfalkviddM jirmJ 2 Replies Last reply
            • OliO Oli
              #226
              @Oli what did you have to do to make it work? It should just be a matter of following the instructions that @jirm linked to.
              EDIT: Since you already have the MySensors repo cloned from git, you can update by running
              pi@raspberrypi ~/MySensors $ git pull
              Than run configure, make, etc as per the original instructions.
              • OliO
                OliO
                Oli
                @mfalkvidd I could not find ttyMySensorsGateway on Domoticz. Only ttyUSB0, ttyUSB20 and ttyAMA0. Even after I did ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                • OliO Oli
                  @Oli so what did you do to make it work?
                  • OliO Oli
                    jirmJ
                    jirmJ
                    jirm
                    #229
                    @Oli I´m thinking is hard to "only" update (changing from develop to master branch) directly from github if the repository is not been previously prepared to do this kind of updates... but maybe I´m wrong.
                    Will be good you give feedback if you get it.
                    Cheers
                    • OliO
                      OliO
                      Oli
                      @mfalkvidd hah... thats a good question, don't know. After dozen or more reinstallations, spending hours on Google I finally make it work. Got some notes but frankly I am worrying it will happen again. Hahaha
                      • OliO Oli
                        @Oli ah, ok. Then I'd recommend backing up everything before doing git pull, configure, make, etc so you can restore if it stops working.
                        • jirmJ jirm
                          Cheers
                          jirmJ
                          jirmJ
                          jirm
                          #232
                          @Oli :-) :-)
                          Good !
                          I like when people can make something work that nobody even knows what it is :-)
                          For me it usually happens just the opposite I am not able to make work even the things I know perfectly well ... maybe it will be a matter of "bad karma" :-)
                          • OliO
                            OliO
                            Oli
                            OK, I did it, I f....g did it, and guess what...
                            s...t happened again.
                            Everything went as it should, no errors at all, but no ttyUSBMySensorsGateway...
                            log error message:
                            2017-01-03 19:56:38.784 MySensors: Using serial port: /dev/ttyUSBMySensorsGateway
                            2017-01-03 19:56:38.785 Error: MySensors: Error opening serial port!
                            2017-01-03 19:56:39.785 MySensors: retrying in 30 seconds...
                            and again...
                            and again...
                            any help would be appreciated.
                            luizrrochaL 1 Reply Last reply
                            • J
                              J
                              jacikaas
                              wrote on last edited by jacikaas
                              #234
                              Could someone answer: if i have RPi NRF24 GW, how I could connect MYSController from other computer (for example from Windows computer)?
                              1. Is it possible to make that type connection with RPi NRF24 GW?
                              2. May I use some integrated web server for this type of connection in RPi to make it work? Is there are easier solutions?
                              EDIT: no matter, already answered it by myself :)
                              Its easy becose it's like Ethernet GW.
                              • OliO Oli
                                log error message:
                                and again...
                                and again...
                                luizrrochaL
                                luizrrochaL
                                luizrrocha
                                @Oli: when you do a "ls /dev" is ttyUSBMySensorsGateway shown ?
                                • luizrrochaL luizrrocha
                                  luizrrochaL
                                  luizrrochaL
                                  luizrrocha
                                  @Oli: by the way, the name of the port you used is ttyMySensorsGateway, not ttyUSBMySensorsGateway:
                                  Is the gateway running, ie, "ps -ef "grep my" shows a process there ?
                                  Cheers,
                                  Luiz
                                    Cheers,
                                    Luiz
                                    luizrrochaL
                                    luizrrochaL
                                    luizrrocha
                                    @Oli: sorry, correct syntax is ps -ef | grep my
                                    OliO 1 Reply Last reply
                                      OliO
                                      OliO
                                      Oli
                                      @luizrrocha
                                      pi@raspberrypi ~ $ ls /dev
                                      autofs mmcblk0p1 stderr tty36 ttyAMA0
                                      block mmcblk0p2 stdin tty37 ttyMySensorsGateway
                                      btrfs-control net stdout tty38 ttyprintk
                                      bus network_latency tty tty39 ttyUSB0
                                      cachefiles network_throughput tty0 tty4 ttyUSB20
                                      char null tty1 tty40 uhid
                                      console ppp tty10 tty41 uinput
                                      cpu_dma_latency ptmx tty11 tty42 urandom
                                      cuse pts tty12 tty43 vc-cma
                                      disk ram0 tty13 tty44 vchiq
                                      fb0 ram1 tty14 tty45 vcio
                                      fd ram10 tty15 tty46 vc-mem
                                      full ram11 tty16 tty47 vcs
                                      fuse ram12 tty17 tty48 vcs1
                                      gpiomem ram13 tty18 tty49 vcs2
                                      hwrng ram14 tty19 tty5 vcs3
                                      i2c-1 ram15 tty2 tty50 vcs4
                                      input ram2 tty20 tty51 vcs5
                                      kmsg ram3 tty21 tty52 vcs6
                                      log ram4 tty22 tty53 vcsa
                                      loop0 ram5 tty23 tty54 vcsa1
                                      loop1 ram6 tty24 tty55 vcsa2
                                      loop2 ram7 tty25 tty56 vcsa3
                                      loop3 ram8 tty26 tty57 vcsa4
                                      loop4 ram9 tty27 tty58 vcsa5
                                      loop5 random tty28 tty59 vcsa6
                                      loop6 raw tty29 tty6 vhci
                                      loop7 root tty3 tty60 watchdog
                                      loop-control serial tty30 tty61 watchdog0
                                      MAKEDEV shm tty31 tty62 xconsole
                                      mapper snd tty32 tty63 zero
                                      mem sndstat tty33 tty7
                                      memory_bandwidth spidev0.0 tty34 tty8
                                      mmcblk0 spidev0.1 tty35 tty9
                                      pi@raspberrypi ~ $ ps -ef | grep my
                                      root 2079 1 1 18:40 ? 00:02:49 /usr/local/bin/mysgw -b
                                      pi 4214 4181 0 21:25 pts/2 00:00:00 grep --color=auto my
                                      • OliO Oli
                                        @luizrrocha
                                        luizrrochaL
                                        luizrrochaL
                                        luizrrocha
                                        @Oli : the port name is actually ttyMySensorsGateway, you have to correct the definition of the gateway on Domoticz to use it....
                                        Luiz
                                        • J jacikaas
                                          luizrrochaL
                                          luizrrochaL
                                          luizrrocha
                                          @jacikaas : on MYSController go to Settings -> Gateway -> TCP/IP and add the IP address of the Gateway and use port 5003. It works even if the gateway is feeding data to Domoticz, so you can monitor your sensors in "raw" mode.
                                          Cheers,
                                          Luiz
