  2. Announcements
  3. đź’¬ Building a Raspberry Pi Gateway
  • Patrik SöderströmP
    Patrik SöderströmP
    Patrik Söderström
    Any ETA on support for RFM69 ? Need to extend my coverage :)
    • alescA
      alescA
      alesc
      Done:
      1. git clone https://github.com/mysensors/MySensors.git
      2. ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
      3. make.
        Got error:
        In file included from ./MySensors.h:287:0,
        from examples_linux/mysGateway.cpp:70:
        ./drivers/RF24/RF24.cpp: In function âuint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)â:
        ./drivers/RF24/RF24.cpp:65:22: error: âNOPâ was not declared in this scope
        *ptx++ = NOP ;
        Makefile:46: recipe for target 'examples_linux/mysGateway.o' failed
        make: *** [examples_linux/mysGateway.o] Error 1
        Any idea?
      mfalkviddM tekkaT 2 Replies Last reply
      • alescA alesc
        Done:
        3. make.
          Got error:
          *ptx++ = NOP ;
          Any idea?
        #103
        @alesc looks like this commit in the development branch broke the code.
        Do
        git checkout master
        before running configure should get the code to the latest stable release.
        EDIT: Sorry, that won't work because the Raspberry Pi stuff didn't exist when MySensors 2.0 was released. You'll have to do git pull instead, to get tekka's fix.
        • alescA alesc
          Done:
          3. make.
            Got error:
            *ptx++ = NOP ;
            Any idea?
          tekkaT
          tekkaT
          tekka
          wrote on last edited by tekka
          #104
          @alesc @mfalkvidd Thanks for reporting, fixed: https://github.com/mysensors/MySensors/pull/635
          • ben999B
            ben999B
            ben999
            wrote on last edited by ben999
            #105
            Hi Everyone !
            Big thumb up for the amount of work supplied !!!
            After being more or less successful with openHAB1 I had a go with openHAB2 today, via a online install....
            But no success with the "mysGateway" install : should i go back to serial gateway with an arduino ?
            Thanks a lot for your help
            • carlylerC
              carlylerC
              carlyler
              @ben999 try again, because it works great. I assume by online install you mean apt-get; I too had trouble when trying this. However, I tried again following @TimO instructions here:
              wiki, then everything came up nicely. I feel it is some permission issue that I have not tried to figure out yet.
              ben999B 1 Reply Last reply
                marceloaqno
                Code Contributor
                #107
                @ericvdb when running as a service, debug messages are masked and aren't shown in the system logs, but it would be a good idea to have a way to connect to gateway perhaps using telnet and watch the logs. I'll work on something.
                • carlylerC carlyler
                  ben999B
                  ben999B
                  ben999
                  @carlyler
                  Thanks a lot for your message, hope is back on my side :)
                  Actually I had a go with openHABian (i didn't make it clear in my previous message, sorry)
                  The install itself couldn't be easier : OS+openHAB installed in one go, just by formatting SD Card with a tiny img file. One hour later and voilĂ  !
                  So that could be the source of my trouble?
                  I will go with the link you supplied tonight and let you know (lookslike it is a manual install... scary!!)
                  Thank you again for your support
                  • carlylerC
                    carlylerC
                    carlyler
                    @ben999 if you have not already, read through the MySensors OH2 thread. I noticed a recent post by @TimO that talks about setting some permissions and that might be the issue. Otherwise, the manual install is not bad as he gives you step-by-step; I am a new to all this and managed to get it to work...
                      ben999B
                      ben999B
                      ben999
                      @carlyler
                      Smashing
                      Thanks a lot for that hint... I remember reading that...
                      Linux is so damn rigid :laughing:
                      Thank you again for your help
                      • JahFyahhJ
                        JahFyahhJ
                        JahFyahh
                        Either its not stated or I cannot see it, but i was wondering... Is this version 2 voor de rPi?
                        At the moment I am using MySensors version 1.5 with Pimatic as controller. And I would like to use v2.
                        • E
                          E
                          ericvdb
                          @ben999 Yes, version 2
                          • ben999B
                            ben999B
                            ben999
                            #113
                            I feel a bit sorry to come back here for my own little troubles...
                            1- So i installed openhab2 on RPi3 with a fresh SDCard
                            2- I followed tobof 's excellent step-by-step howto
                            3- I installed mysGateway
                            4- With pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d i can see that my motion sensor and my RPi gateway get on well... they do speak to each other, right ?
                            mysGateway: Starting gateway...
                            mysGateway: Protocol version - 2.0.1-beta
                            mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                            mysGateway: TSF:LRT:OK
                            mysGateway: TSM:INIT
                            mysGateway: TSM:INIT:TSP OK
                            mysGateway: TSM:INIT:GW MODE
                            mysGateway: TSM:READY
                            mysGateway: MCO:REG:NOT NEEDED
                            mysGateway: MCO:BGN:STP
                            mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                            mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
                            mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:0
                            5-in things/demo.things" I put this.
                            Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/pts/2", sendDelay=200 ] {  }
                            Right away, it worked (king of the world!) and i could see that bridge in paperUI !!!
                            But i got that after a reboot of RPi
                            openhab> Failed to connect on port: /dev/pts/2 exception:
                            gnu.io.NoSuchPortException
                                    at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273)
                                    at gnu.io.NRSerialPort.connect(NRSerialPort.java:48)
                                    at org.openhab.binding.mysensors.protocol.serial.MySensorsSerialConnection.<init>(MySensorsSerialConnection.java:52)
                                    at org.openhab.binding.mysensors.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:63)
                                    at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:764)
                                    at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)
                                    at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)
                                    at java.util.concurrent.FutureTask.run(FutureTask.java:266)
                                    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
                                    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
                                    at java.lang.Thread.run(Thread.java:745)
                            Wrong serial port ?
                            Juste to make it clear : mysGateway bit of software is the magic that makes RPi believe that there's an arduino acting as a gateway on USB and collects the NRF24 info through GPio ?
                            YveauxY 1 Reply Last reply
                            • ben999B ben999
                              Wrong serial port ?
                              YveauxY
                              YveauxY
                              @ben999 said:
                              Wrong serial port ?
                              Likely ;-)
                              /dev/pts/x are pseudo-terminals , not serial ports.
                              On my (old) Pi running Raspbian the serial port is /dev/ttyAMA0
                              You could run something like
                              dmesg |grep -i tty
                              to get an idea of serial ports on your Pi.
                              • YveauxY Yveaux
                                @ben999 said:
                                Wrong serial port ?
                                Likely ;-)
                                dmesg |grep -i tty
                                ben999B
                                ben999B
                                ben999
                                @Yveaux thanks a lot for your answer. Understanding linux is a slow and painful process :laughing:
                                Here is the output from your command : dmesg |grep -i tty
                                pi@raspberrypi:~ $ dmesg |grep -i tty
                                [    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0xcc3e67e3 smsc95xx.macaddr=B8:27:EB:3E:67:E3 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                [    0.001337] console [tty1] enabled
                                [    1.772114] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
                                What a mess...
                                ttyAMA0 is the one !!!
                                Thanks @Yveaux you got me on the right path !!! Goto next step! :smile:
                                • JahFyahhJ
                                  JahFyahhJ
                                  JahFyahh
                                  I just did a fresh install of pimatic and MsGateway on the pi. But pimatic does not seem to get de messages. i started the gateway via the daemon method, is there a way to see if the sensor is reaching the gateway?
                                  M 1 Reply Last reply
                                  • H
                                    H
                                    hausinger
                                    @b0rmann
                                    Do you still using the rs485 usb "dongle" to connect the rs485 nodes to the rpi? Do you attached some more nodes to your rs485 rpi Gateway?
                                    Is it stable?
                                    How do you do the configuration for it?
                                    • JahFyahhJ JahFyahh
                                      marceloaqno
                                      Code Contributor
                                      @JahFyahh To view messages being exchanged with the sensors, run the gateway in debug mode:
                                      mysGateway -d
                                      • JahFyahhJ
                                        JahFyahhJ
                                        JahFyahh
                                        @marceloaqno thank you for the reply, I tried that and I receive "mysGateway: acce[t: Bad file descriptor" Any idea what this means?
                                          marceloaqno
                                          Code Contributor
                                          @JahFyahh Could you provide the full debug log?
                                          With your input, this post could be even better đź’—
