  2. Announcements
  3. 💬 Door, Window and Push-button Sensor
110 Posts 36 Posters 55.3k Views 32 Watching
    #21
    Not sure if it more battery friendly, but maybe sending a bluetooth low energy beacon is better than a led? Higher nerd factor for sure, but maybe less spouse friendly (depending on how good the ble app on the phone is).
    Seems like it would be possible by using an extra nrf24: https://github.com/floe/BTLE/blob/master/examples/send/send.ino
    On the other hand, if a smartphone is required you might as well open the app for your controller and check the status there :)
    Maybe use a battery-friendly PIR and only light/blink the led when motion is detected?
    • meanmrgreenM
      meanmrgreenM
      meanmrgreen
      You lost me at bluetooth beacon? :)
      Me personally is using the app but wifey and kids ain't really as interested as i am ;)
      So therefore I would need a indicator of some sorts around the mailbox that is about 30 meters from the house in the road up to the house.
      Maybe a solar led light or similar to light up? Or a flag on a servo?
      Will start with building the switch and figure out the indicator later.
      • AteszA
        AteszA
        Atesz
        Hi Everyone
        Be carefull a newby here... :-)
        I have ordered all the parts for my sensor network. My plan is to have battery powered sensor sensing the following: Door/window status AND temp/humidity. Doing all this in a low power fashion.
        My question is: Would these code in the build section be easily combined (dooe switch and temp/hum) in a way that it measures the temp/hum regurarly (every 15-30 min) and if during the sleep a door event happens it sends the door event to the gateway (and probably since we are awake do a temp/hum measurement as well)?
        Every piece of direction, advice is appreciated.
        Atesz
        • AteszA
          AteszA
          Atesz
          Like I said..newby here. Hold back your horses for a moment, I did a deep search and found some interesting forum topics here :-)
          • AteszA Atesz
            @Atesz very welcome to the MySensors community!
            "easily" is in the eye of the beholder, but I'd say yes. https://forum.mysensors.org/topic/2597/combining-mysensors-examples is a great starting poing for combining sketches.
            AteszA 1 Reply Last reply
              AteszA
              AteszA
              Atesz
              @mfalkvidd Thank you very much, it is almost what I've been looking for !
              • TON RIJNAARDT
                TON RIJNAARDT
                TON RIJNAARD
                Goodevening,
                I am new to mysensors (newby) i wil make 3 sensors on my mini pro can some one help me with the sketch.
                I am working a hole day but i can't get it writh help is very use vol.
                One switch (reed contact) is working.
                  Hi Ton,
                  You have to give us a little bit more information here (and please start a new thread for your project).
                  Normally good to give information about:
                  1. What are you trying to accomplish?
                  2. What is working?
                  3. What is not working?
                  4. What did you try yourself before posting?
                  5. What is the expected result?
                  6. Logs from the sensor/gateway/controller.
                  • Svante TegelandS
                    Svante TegelandS
                    Svante Tegeland
                    I had big problems getting this one to work in Domoticz... But then I downgraded the Arduino IDE to IDE 1.6.7 (https://forum.mysensors.org/topic/5164/ethernet-gw-w5100-can-not-connect-to-domoticz/2) and then it worked!
                    • TON RIJNAARDT
                      TON RIJNAARDT
                      TON RIJNAARD
                      @hek,
                      Thanks for the reply.
                      I want to try 3 reed/door contacts on one mini-pro on pin 3,4 and 5
                      What is working?
                      One reed/door contact is working
                      I don't no how i must make a second reed/door contact in the sketch (door/window push button)
                      I am new to programming arduino and don't undertsand how to do that, ik look for a hint how i can implement a second reed/door switch in the sketch
                      I look many sketches on internet and try to copy a copple of line in the working sketch but i don't get a second reed/switch in domoticz. I am trying this a hole day (i am with pension).
                      What is the expected result? a second, thirth reed/sensor in domoticz i see here only the first sensor.
                      The log for the first reed/door switch i see and it is working in domoticz, that is not the problem.
                      Sorry for the bad English.
                      • TON RIJNAARDT
                        TON RIJNAARDT
                        TON RIJNAARD
                        @ Svante
                        Thanks for the reply but is is working well with one reed switch. So that is not the problem I want on the mini/pro a second and thirt switch.
                        • N
                          N
                          nickgosling
                          Hi, New here but stumbled across this.
                          I am planning on re-using an old wired alarm system that has door and window sensors all over my house terminating under my stairs. Can I combine one sketch into multiple door reed switches on one arduino. That seems to have been asked before but there doesn't seem to be an answer. It would be quite annoying to have 8 arduinos next to each other in order to do so.
                          Nick
                          • N nickgosling
                            Nick
                            @nickgosling - no problem if you have 1 wire for each reedswitch you could just add it to different input/pins and have 1 arduno check which pins is high or low.
                            • N
                              N
                              nickgosling
                              Thanks for the response. OK I'm fine with assigning a pin as an input but how would I change the code to reflect this .thanks.
                              • N nickgosling
                                @nickgosling - take the sketch and add one child for each sensor. Define one input for each sensor and in the loop check each pin for a statechange. With a if you can then send the status for each changed pin.
                                • N
                                  N
                                  nickgosling
                                  Thank you I'll give that a go.
                                  • J
                                    J
                                    Justas
                                    Maybe it is a little off-topic here, but maybe you could point me to the right direction: I want to build nice wall switch, and from technological point of view it is not that difficult using mysensors, this part is clear, including battery powering or making some kind of power conversion from AC to DC (in openhardware there are quite a few examples on that). What is bothering me is the switch "enclosure". I have one example from TKB Home:
                                    http://www.ebay.de/itm/TKB-Home-Z-Wave-Plus-Dual-Paddle-Wall-Switch-TZ56D-ZW5-/122201876698?ssPageName=ADME:X:EAC:GB:1120
                                    that I have bought to try with smarttnings controller (which is not intended to work with, now I know), but what it has - it is the enclosure: it is nice switch with 2 micro switches inside (4 in total, since it is dual wall switch), that are not locking in the pressed position - you press up and it clicks one button/switch and returns back to its initial "neutral" position, you press down - again, click and back to "neutral".
                                    I think the similar are are in aliexpress, that are called like wall wireless remote switch Transmitter, but I'm not sure about that, since I didn't bought one to disassemble.
                                    Maybe some one have met something similar for making some nice RF controlled wall switches?
                                    Thanks in advance!
                                    Regards
                                    Nca78N 1 Reply Last reply
                                    • J Justas
                                      Thanks in advance!
                                      Regards
                                      Nca78N
                                      Nca78N
                                      @Justas Hello, please check the dedicated category, if you don't find your hapiness please post there :)
                                      https://forum.mysensors.org/category/42/enclosures-3d-printing
                                      • skywatchS
                                        skywatchS
                                        skywatch
                                        I tried this today and it wouldn't find a parent.
                                        Adding #define MY_NODE_ID 1 seems to have solved the problem, so maybe this (and other) examples need to be updated with this info?
                                        Thanks for the work on this project though, I think it will be a lort of fun when I get it all working! :)
                                        • skywatchS skywatch
                                          @skywatch that shouldn't bee needed. Would it be possible for you to post the entire log from when the node was unable to find parent?
